Like Tree2Likes
Old 03-16-2013, 03:28 AM   #601 (permalink)
Originally Posted by ddhuans View Post
Replace those failure tail shaft bearings... look like I have to buy new tail case too.
That's a strange one. Belt too tight???
pani is offline        Reply With Quote Quick reply to this message
Old 03-16-2013, 06:30 AM   #602 (permalink)
The belt is not tight, and my HS is just around 2550-2600. But I havent replaced those bearing for year...
ddhuans is offline        Reply With Quote Quick reply to this message
Old 03-16-2013, 06:37 AM   #603 (permalink)
Default What did you do with your PRÔTOS today?
What did I do? Flew it! For the first time.
Still Crashing, Still Learning
6HV-U, Logo550 & Protos all vbar
Bee_random is offline        Reply With Quote Quick reply to this message
Old 03-16-2013, 08:41 AM   #604 (permalink)
That looks familiar. When that bearing let go on mine, I ended up replacing the tail shaft as well because the inner bearing race was galled to the shaft. The bearing must've got hot as my tail case was slightly melted around the bearing. Very slightly. Just enough that the bearing didn't sit in the cup snugly.
karl k is offline        Reply With Quote Quick reply to this message
Old 03-16-2013, 09:01 AM   #605 (permalink)
That's exactly what happened to me!! My 5x10x4 bearing is not sit snugly in my tail case anymore, there's slop there. But luckily I can insert a 5x11x4 bearing from my 450Pro main shaft block,it fit perfectly! Have 4 flights today, everything ok now!
Old 03-16-2013, 09:46 PM   #606 (permalink)
Those bearings spin very fast and carry a lot of load, including shock loads. They should be lubed routinely to extend their service life. Mine have about 210 flights on them and I lube them every 10-15 packs.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 10:04 AM   #607 (permalink)
I was going to make the same point. Oil your bearings!
Please don't confuse my experience with pessimism!
Protos 500, HCP100S, Raptor 50, many more!
babyuh1 is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 02:57 PM   #608 (permalink)
took the protos up in the air for the first time just a hover is all i attempted . i was shacking like no ones business sweaty palms and all.
i was really supprised how well it hovered .
TitaniumFreak is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 05:32 PM   #609 (permalink)
Took the Protos out and messed with the ESC governor gains. Raised the gain too much and tossed the belt a half dozen times giving me some quick recovery and auto practice. Actually it was kind of fun other then having to reinstall the belt every other pack....After the sixth belt toss I dropped the gains down a level and all is good again....
OXY / Lynx Team Pilot
mtuccio is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 06:47 PM   #610 (permalink)
Why would high gain result in belt coming off?
Chief
RC Chief Hobbies
MSH Protos 500 Flybar, Gaui 200 V2 Flybar,V120D01, V120D02S,MCPx (retired)
Boating Fleet: Toysport Syncron and Triton Monos, 1/10 scale 1967 Miss Bardahl Shovelnose Hydro, Executone semiscale Hydro, OPC Tunnel, Miss Geico Cat
BHChieftain is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 07:26 PM   #611 (permalink)
Too much gain causing a jolt in the drivetrain?
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 10:42 PM   #612 (permalink)
You were lucky 6x mtuccio. The loose belt could've jammed the main pulley against the frame... No auto possible.
Man I'm jealous... The weather has been terrible here for a couple weeks. I snuck in a few flights on Friday, but it wasn't on the Protos... Perhaps next Friday.
Goblin Speed | iKon
Old 03-18-2013, 06:45 AM   #613 (permalink)
Chief
It's a combination of a few things happening at the same time:
  • Motor reacts and pulses the drivetrain given a very tight condition on the input but a loose condition on the output
  • Hard collective move is trying to slow the blades down and this goes against the motor trying to speed things up.
  • Frame flex. The front of the protos isn't the strongest around the motor area. I do not have the Y-brace installed because I'm running a 15T pinion right now.
I know I was lucky x6 times....I was just trying to see if I could come up with a belt tension that worked for this setting. The weather in NY hasn't been much better and we are actually supposed to be getting snow this afternoon....
Old 03-18-2013, 05:49 PM   #614 (permalink)
What did I do with my Protos today? Assessed rekit style crash damage from its third flight ever, lol :S.
  • Comprehensive build info
  • Maiden flight video
  • 2nd flight video
  • 3rd flight video including crash
  • 3rd flight aftermath video
  • Damage assessment with pics - rekit
  • Revised build info from 2nd kit
All here in one thread: https://www.helifreak.com/showthread...56#post4832256
RAW 420 / RAW 580 / Kraken 580 Nitro / Goblin 700 / 2x RAW 700 / Kraken 700 S
VBC-t & Neo Pro / Scorpion motors & ESCs / MKS HBL575 SL & HBL980 / Supra X D4, D6 & S6 / OptiPower / Revolectrix 2x Bump & 5x PL8v2
https://www.youtube.com/kjoer
kjoer is offline        Reply With Quote Quick reply to this message
Old 03-19-2013, 01:42 PM   #615 (permalink)
started the rebuild last nite
installed new main bearings, installed new motor a Scorpion HK3226-900Kv Motor
replaced all the broken bits almost done
Then I noticed my belt was missing a few teeth
kind of glad it's not nice out
Spending time, Paying attention
Bladefx is offline        Reply With Quote Quick reply to this message
Old 03-19-2013, 06:44 PM   #616 (permalink)
Jus Got me a New dx7s, had a trusty dx6i since I started. I have set it up the protos almost a week and was beggin for a break in the weather to get her up in the air. Well today I got it. This was another chance to test my SL on the IKON.. worked great returned to a upright hover every-time.. gains were a lill high first time out.. O and I had my max angle at 30*.. lol need a lil more than that. at least for me , Ill try 36 to 38.. max is 45.. I'm thinkin I need it a lil tight so I can check me undies if I need to use it.. LOL.. sorry for long post.. Guy's hope your birds are back up soon. Spring is cominggggg.. O and So far I am enjoying the dx7's I'm taking it apart to install a blue backlight so wish me luck..
Dx7s, exi 450 pro(I swear it's a trex by now lol)
MSH Prôtos: 500 fbl,MSH Prôtos 450 fbl
Blackout 250
ZMR 250
Dazhim is offline        Reply With Quote Quick reply to this message
Old 03-19-2013, 07:45 PM   #617 (permalink)
I am currently in the midst of building my Protos 500 Carbon and one thing that has concerned me a great deal is the volume of loose metal shavings I have discovered in the parts bags. Some appear to me from milling, others metal appears to be from the bearing assembly process(ie..excess material left around the inner race). I have tried to be careful to lookout and remove any material that I find. Unfortunately, I have already had to purchase a second Main shaft collar, as I ended up striping it's threads when it was not tightening around the shaft. After close examination I found an aluminum shaving within the narrow split of the collar. This was preventing the ring from closing around the shaft.
loknar28 is offline        Reply With Quote Quick reply to this message
Old 03-20-2013, 07:24 AM   #618 (permalink)
Aha! I think you've solved a mystery that came up for me a week ago. When oiling the motor, I found a metal shaving about 4mm square, painted black on one side, gray metal on the other. It was magnetic and sticking to the windings. I couldn't believe it! The damage that could have (did?) to the motor was scary. I thought maybe it had been picked up at the field I've been flying at, but maybe it was there from the start. Sloppy! Anyone else find something like this?
matthewcornell is offline        Reply With Quote Quick reply to this message
Old 03-22-2013, 09:27 PM   #619 (permalink)
Yup just started my build and also noticed some metal shavings and chips in some bags. I have been really meticulous with the build and now i will keep an eye out for stray metal chips. By the way this is my first build and the fit and finish is amazing.Got up to the flybar cage (I know) and going to do the grips and rest of the head this weekend, cant wait to get it in the air
Blade 400 hs-65hb, Spartan Quark, Ino-lab Hg-d261hb dimension sport BEC Steath blades
MSH Protos 500 Futaba 9650, Bavarian Demon 3x, MKS ds760p
Logo 600se, 12s , kontronic Pyro, 80 hv, Spartan nano
refused is offline        Reply With Quote Quick reply to this message
Old 03-24-2013, 06:04 PM   #620 (permalink)
As grey as it was today we had a Blast out flyin.. Finally got the gonads to flip dat dang thing over and actually fly it.. I pulled off some inverted backwards and forward circuits.. made me feel tons better inside all that simming was not in vain.. even had the 450 go thru the motions.. O yea self leveling on the IKON works like a champ.. used it twice.. good times and all helis came home intact.. again a GREAT day
Blackout 250
ZMR 250
