550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
04-24-2014, 05:47 AM | #1 (permalink) |
H55061 and HN6052 Tail servo linkage ball problem
Are ball A same lenght ?
On my 550 dfc ( the last one with 730mx) on tail servo I have a problem. Ball A is not safetely closed with the nut ( only little touch) using standard plastic servo arm. Should I use a longer one ? Which one ? thx |
04-24-2014, 06:31 AM | #2 (permalink) |
I have the same problem. I just sand down the servo horn a little bit to have enough for the nut to grab and use loctite.
04-24-2014, 09:59 AM | #3 (permalink) |
Same problem as well. I opted to thread it in good with CA acting as locktite. I was hesitant to cut/sand down the horn. I'm probably going to remove it and do that though. I really don't like it not being nut-secured.
Nano CPx BL -- T-Rex 150 -- 300x Mini vBar -- T-Rex 450 Pro V2 3GX -- Gaui X3 Brain -- T-Rex 550E Pro iKon |
