Old 03-11-2014, 04:29 PM   #1 (permalink)
Default Protos or Mini Protos?
I'm either gonna get one or the other..
Which one?
Protos
http://www.msh-direct.com/products/p...-msh51200.html
Or
Mini Protos
http://www.msh-direct.com/products/m...-msh41504.html
Servos:
Mks Ds93 cyclic
Mks Ds95i tail
I don't know which are the best or good servos for a 500 size heli?
Thanks!
||Mikado Logo 480XXtreme||
|Trex 450|
~Futaba 14SG~
_Kyle_ is offline        Reply With Quote Quick reply to this message
Old 03-11-2014, 07:20 PM   #2 (permalink)
I used these on my 500
tail servo here
http://www.msh-direct.com/products/d...-oz-in-6v.html
cyclic servos here
others will voice their opinions also
that tail servo is lighting fast!
also the 500 will be more stable in the air then the 450 but its also quite a bit larger, depends on where you will fly it and how comfortable you are, i dont have personal experience with the mini protos but i can tell you my protos is ALOT quieter than my 300x and my 450
M&P_Hooligan is offline        Reply With Quote Quick reply to this message
Old 03-11-2014, 08:56 PM   #3 (permalink)
If I could only have one I would choose the P500. It's less fiddly to work on and flies better. Plus you already have a 450.
Those MKS servos are very good, one of the best you can get for the protos. But my Protos flies great with plain old Savox 1250s (same as align ds510) and an Align ds650.
Protos Max Leggero 700, Logo 600SE, Blade 230s
DX9
flint723 is offline        Reply With Quote Quick reply to this message
Old 03-11-2014, 09:09 PM   #4 (permalink)
Ok Protos it is!
I was looking for a 6s 450 but decided against it.. If I get a 6s 450 it will be a Gaui X3 since I'm getting this Protos..
On the thing it says it's stretched but I will need a couple more upgrades to run 470 blades?
|Trex 450|
~Futaba 14SG~
Old 03-11-2014, 09:18 PM   #5 (permalink)
Originally Posted by _Kyle_ View Post
Ok Protos it is!
Yes that kit has the stretch tail boom. All you need to run 470s are the 18t tail pulley, long motor shaft for 14t pinion, a 14t pinion, and the Y pinion support bearing I believe. I think it says the part numbers you need on msh-direct.
I prefer the Protos with 470s, it isn't even a contest. But I prefer helis with lower disk loading in general.
But I think you should just fly it stock for a while and see how you like it.
DX9
Old 03-12-2014, 03:50 AM   #6 (permalink)
Hey welcome to the club
Both are very nice machines. The argument that the bigger heli is more stable is not so valid anymore when they are flybarless. For smooth flight and hovers they both do very well. I have flown my mini in some incredible strong winds and still had a lot of fun. The 500 is really light for its size and would also be affected by the wind. Not much of a difference there.
The mini can be faster on pitch and roll, and on the 500 it is easier to slow your maneuvers down. That is where the main difference between the two will be.
If you go for the bigger one you will need a bit more space to fly, but if you keep to stationary rolls, flips, tic-tocs, little rainbows you can fly in the same space the mini likes.
MSH miniPRÔTOS & PRÔTOS 500 a better way to fly
GAUI
Hurricane 425 night rig & 550 the monster
sp00fman is offline        Reply With Quote Quick reply to this message
Old 03-12-2014, 04:54 AM   #7 (permalink)
Yep both nice machines. My Mini is stretched, Protos not and although they are not that much different in size the Protos is quite a bit more powerful. I agree with spoof that you can fly it in a space for a 450 but it is really more fun when you can stretch its legs. You should also consider that you have to have sufficient charging equipment for the biggger 6S packs for the Protos. Re servos: I´m also using the MKS 9660a+ for cyclic (and a std size Fut 9254 on tail), can´t say a bad thing about them.
Can´t go wrong either way!
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 03-12-2014, 03:17 PM   #8 (permalink)
I have a huge field a couple minutes walk from my house.. Could probably fly an 800 in it if I wanted! So Protos it is!
|Trex 450|
~Futaba 14SG~
Old 03-14-2014, 07:02 AM   #9 (permalink)
I have both stretched as well, Started with the Protos then got the mini too
As stated in couple other responses, great heli, you have the room, just hold off on another 450, you may just ant a mini! It's my micro
BTW, Bill is great at MSH-Direct and you cannot go wrong with MKS servos
Welcome!!
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 03-21-2014, 10:11 PM   #10 (permalink)
I'm able to fly my Protos 500 in a small school field (about the size of a soccer field) tamely. Then in a big field I can do big air. I think it is the perfect "smaller" 500 heli out there... (smaller than trex 500).
And if you decide you want bigger you can always stretch it.
Chief
RC Chief Hobbies
MSH Protos 500 Flybar, Gaui 200 V2 Flybar,V120D01, V120D02S,MCPx (retired)
Boating Fleet: Toysport Syncron and Triton Monos, 1/10 scale 1967 Miss Bardahl Shovelnose Hydro, Executone semiscale Hydro, OPC Tunnel, Miss Geico Cat
BHChieftain is offline        Reply With Quote Quick reply to this message
