Old 05-10-2015, 09:35 PM   #1 (permalink)
Default nano with HH brushless
i have not been to happy with the nano lately,,,a lot of bogging even with brand new eflight 45c batterys..it seems like it's got a high screech gear sound even with a brand new main gear...is it possible the main motor is finally getting tired,,i got it last summer,,not sure how many flights are on it,,i sure don't recall it acting this doggy when i installed it...is it possible to just purchase the motor
elmobster is offline        Reply With Quote Quick reply to this message
Old 05-11-2015, 04:53 PM   #2 (permalink)
Screeching sounds like a bearing crying for oil.
If its fixed don't break it!
Old 05-11-2015, 05:09 PM   #3 (permalink)
thats what i thought but its not,,,i oil the bearings everytime before i fly..
Old 05-11-2015, 05:43 PM   #4 (permalink)
If you have the HH brushless upgrade motor, you can buy it separately from the ESC...
You might want to loose the motor screws then tighten them again to eliminate any chance that they are meshed too tightly
http://www.ebay.com/itm/BLADE-Replac...item25a2151d23
Old 05-11-2015, 06:28 PM   #5 (permalink)
the noise its making sounds like the gears are to tight..whats weird it just started doing that
Old 05-11-2015, 07:15 PM   #6 (permalink)
on the nano there is no motor screws..the motor just slides in
Old 05-11-2015, 07:22 PM   #7 (permalink)
Ah yes, that's right...
Have you checked the pinion gear and main gear closely? might have been an improper mesh that pooched one or the other
Old 05-11-2015, 07:32 PM   #8 (permalink)
im thinkin it might be the motor pinion..it does it with every main gear i try..it just seems kinda loud for a little heli...and plus the bogging...maybe thats me..the better i get maybe im pushing it to far to quick
Old 05-11-2015, 07:41 PM   #9 (permalink)
What is your servo travel on the pitch channel?
Somewhere in the 65-75 range the bogging should be eliminated
Old 05-11-2015, 09:49 PM   #10 (permalink)
Are u oiling the motor as well?
A noisy bearing is usually a bad bearing beyond being helped with oil.
One thing you can do is take the main gear off and spool up and see if the noise is still there. At least you'll know whether its in the motor or main bearings.
Old 05-12-2015, 07:56 AM   #11 (permalink)
yes i do oil the motor,,,maybe i'm expecting to much out of the Horizon kit..i have a Mcpx Bl and a Mcpx converted to brushless and both are well over %50 quieter
Old 05-15-2015, 09:56 AM   #12 (permalink)
UPDATE!!! after reading about soldering the brushless converter to the board i decided to give it a try....HOLY COW!!!...this isnt even the same nano...headspeed increased a noticeable amount and the bogging is at a minimum ..its like i bought a different motor...the flips are crazy!!...now i have to calm this thing down lol
Old 05-16-2015, 04:41 AM   #13 (permalink)
Got any pics man? Im not familiar much with the HH brushless kit.
Old 05-16-2015, 06:29 AM   #14 (permalink)
here
http://www.ebay.com/itm/NEW-Blade-BL...item4d1dbfcb4b
Old 05-30-2015, 06:28 PM   #15 (permalink)
cool
Nano cpx ... mcx2...Devo-10 tx running deviation firmware
Hondawasaki is offline        Reply With Quote Quick reply to this message
Old 07-19-2015, 07:08 AM   #16 (permalink)
I had same bogging with mine started within a couple of min of flight on 45c, finally found by checking the pitch at full stick i had 17 degrees +/-. reduced the pitch travel to 83% on DX7s now i have +/-12 degrees. Had no negative impact on the flipping ability but no more bogging and much longer flight times (like +1.30minute after fix). I can hear headspeed is noticably higher. Can still do constant flips without bogging after 5 minutes on miniaviation 220mah 45C now Too much pitch is probably robbing the headspeed, try it.
Also i now run throttle curve slight V 100% 95% 90% 95% 100%.
timmy1234 is offline        Reply With Quote Quick reply to this message
