Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4G3
4G3 Walkera 4G3 Helicopter Support
Old 02-15-2009, 11:28 PM   #1 (permalink)
Default Tools?
Where can I get a pitch gauge that fits? Everybody seems to be out! Any other brands that work? How about a good way to level the swash? Just do it by eye?
Jeeperfreek is offline        Reply With Quote Quick reply to this message
Old 02-16-2009, 12:34 AM   #2 (permalink)
Any pitch gauge that's not too big will work. I use a Copter-X pitch gauge.
To level the swash, take off and see which way the heli goes, then adjust links accordingly
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote Quick reply to this message
Old 02-16-2009, 04:07 PM   #3 (permalink)
Just trail and error then? I have an Esky pitch gauge and its to big and assumed that most were the same size.
Old 02-16-2009, 05:06 PM   #4 (permalink)
Dont forget these two.
Tools (3 min 20 sec)
Gmoney
Gmoney is offline        Reply With Quote Quick reply to this message
Old 02-16-2009, 05:12 PM   #5 (permalink)
I would have thought most pitch gauges would be the same size too, the copter-x one works anyway. But you don't really need one for this heli. You can eyeball 0 degrees at mid stick (in idle-up) (BTW if you switch on the TX, switch into idle up mode, then plug in the battery, the blades will not spin up. If you don't want to do that then just unplug the motors) then spin up the blades with the heli in your hand (at a safe distance).Then re-initialise with the motors plugged in, flick the idle up switch and you should be able to tell if there is equal + and - pitch at full + and - collective by the amount the motor bogs down by at each extent of the collective.
The max pitch you can use is then determined by how well the tail holds. For a good description of how to set the heli up you should read what buildem336 says here:
https://www.helifreak.com/showthread.php?t=116075
