Old 02-02-2014, 08:52 PM   #21 (permalink)
"What's a decent BEC that would work on 12S? "
Here's one:
http://www.western-robotics.com/herc...BECPRO_hp.html
It can be installed using two output leads (as shown on the photograph of my Atom 5.5 above) or, in demanding situations like 700 sized helicopters, it can be installed using its built-in power bus.
Old 02-02-2014, 09:06 PM   #22 (permalink)
Default CC PRO BEC power
Yep, that's what I run!
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 02-03-2014, 08:49 AM   #23 (permalink)
i have talked with CC and they said not to use a 2s lipo with a bec pro. its much much safer to run a 3 or 4s with it. just shoot them an email and they will give you the run down all about it.
also as far as wight goes, that should be the last thing on your mind. your talking about 700 after all. adding anything less than 1 pound would be un noticeable i would think....
Blade 130X, Nano CPX "AKA JUNK", DX9
TREX 150DFC, TREX 550 DFC w/AR7200BX
TREX 600N DFC w/3GX
TREX 700E PRO DFC w/AR7200BX
songer121 is offline        Reply With Quote Quick reply to this message
Old 02-03-2014, 09:42 AM   #24 (permalink)
Gonna have to look into that, used a 2s oack on my 50 and 90 so guess ill email them and see why, ready to just run the 615s off 2s like i did with my 610s and see what happens, they held up for years off 2s
Trex 700e
hamstar78 is offline        Reply With Quote Quick reply to this message
Old 02-03-2014, 10:25 AM   #25 (permalink)
Your point as to weight might generally true, but not for wild flying in Germany - we have a 5kg borderline - anything beyond that is not allowed and not insured. My 700 weighs 4.993 g - so there's not much room to add more weight.
PetJumper is offline        Reply With Quote Quick reply to this message
Old 02-06-2014, 03:33 PM   #26 (permalink)
Got a response from cc and they said 2s is fine and they reason they recomend 3s is to be able to use a smaller pack. I might just go with the hyperion life pack though, little cheaper than the bec
Trex 700e
Old 02-07-2014, 07:35 AM   #27 (permalink)
A life pack will sag a little under load. I use one on my 550. It sags down to 5.5v from 6.5v. Not that big a deal but something to be aware of. The BEC should regulate the voltage a little better and have less sags under load since with 2s lipo you have 8ish volts coming in and only 6.5v going out.
AUSS1E is offline        Reply With Quote Quick reply to this message
Old 02-07-2014, 08:49 AM   #28 (permalink)
that's strange... getting 2 different answers is worry-sum to me lol....
im not gonna lie, i ran a 2s all last season before i contacted them and thats when i switched it up because of them telling me that.
im about to just buy some torq servos and be done with it... or the new align 800 servos.
only problem is they are just so dang expensive.... i could sell mine i have now but i dont think they go for that much anymore....
what would some brand new like, only around 10-15 flights 700 and 750 hv's go for?
TREX 600N DFC w/3GX
Old 02-07-2014, 10:46 AM   #29 (permalink)
No clue as I would never buy used servos. I simply wouldn't trust 'em. The Graupner/SJ HBS 860s I use in both birds are about 55 Euros(65 US $) a piece, strong, fast and reliable.
Old 02-07-2014, 12:52 PM   #30 (permalink)
Even used hv servos were out of my budget for just cyclic around 280 to $300 thats why i went 615 cause im a cheapskate and the 610s never let me down so these should do the trick
Trex 700e
Old 02-07-2014, 05:07 PM   #31 (permalink)
I attached telemetry data of my T-Rex 550E (DS610 servos) with a 1100mAh LiFe pack (Zippy) as Rx pack. I changed the pack between flights. It pretty much stays around 6.5V and it was some fairly hard flying with (bad) tic tocs.
700E Pro DFC, 550SX v2, 450 Pro DFC, mCPX BL, DX8
Crowbar is offline        Reply With Quote Quick reply to this message
Old 02-07-2014, 07:23 PM   #32 (permalink)
Well thats good to know, hmmm what to go with bec or life. Decisions decisions. When you say hard flying do you mean continuosly hard flying or hard flying mixed in with some other stuff? On second thought after looking at the graph ima go bec. The voltage dips here and there and just dont want a brown out, or risk of one. Aahh who cares all these decisions are making me nuts. Ima close my eyes and order and be done with it. Lol
Trex 700e
Old 02-08-2014, 04:23 AM   #33 (permalink)
Check this out, hamstar http://www.vstabi.info/en/node/1331
The mikado people did a thorough and careful test of a number of servo power options. A regular 2s battery will give in up to 2 V. From an RX perspective that is pretty save.
Does it hamper servo performance? The best performing BEC in this test drops by 1 Volt. Do you feel the difference? I don't. One of my birds operates at 8.4 V, the other (identical setup) at 7.4 V. They feel absolutely the same.
Old 02-08-2014, 06:22 AM   #34 (permalink)
Cool thanks
Trex 700e
