Old 02-20-2014, 02:46 PM   #21 (permalink)
Originally Posted by Nelsonisms View Post
Lest there be any doubters, watch this video by jmcneil. It shows about how quick you have to be on sticks to pull off an autorotation landing with the 300X. There's not much time to react. But if you have enough height, give it just the right amount of negative pitch and flare right on the deck it is possible.
That is sooo cool! Especially the last one. Great piloting!
thruster is offline        Reply With Quote Quick reply to this message
Old 02-20-2014, 10:16 PM   #22 (permalink)
I always want to know how things work...so I found this article explaining one-way-bearings...at least the type found in larger .90 size nitro powered helis is what this person is talking about.
http://rc.runryder.com/helicopter/t55473p1/
Perhaps I will need to disassemble a Lynx OWB to see if it works the same way. Well I'll see when mine soon arrives.
Old 02-21-2014, 07:19 AM   #23 (permalink)
And now you know why a OWB helps ever so slightly "center" an out-of-round main gear and reduce constant impacting shock on the mainshaft jesus bolt.
Old 02-21-2014, 10:21 PM   #24 (permalink)
just bought the lynx one way. hopefully it was worth it.
Hello My Name Is Joe
Blade 130X - Lynx EOX / Blade 300x - AR7200BX, 2213-3585 / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX / TSA 600e Pro - AR7200BX, 700MX / TBS Discovery FPV - APM, Sunnysky 980kv/ DX8
jabu32 is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 12:20 AM   #25 (permalink)
Mine came in today, I installed it and spooled her up on my test board I made, I really liked how it worked, couldn't fly yet because I'm waiting on a tail shaft and ball links to come in. I'm uslig the stock gear untill I get better because STOCK GEAR $6, LYNX GEAR $16, catch my drift
AMA Member
120 SR, Nano QX, Nano CPX, MSR X, MCX Tandem, MCX2, AXE 100 CP, Blade 300X, Blade 500 3D, DX6i, TX-610
KellyVB is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 01:28 AM   #26 (permalink)
I noticed some of the less crashing pilots still using the stock gear as well. That's good enough for me as I'm still a loose cannon on the sticks.
Old 02-24-2014, 06:49 PM   #27 (permalink)
Parts came in today, Installed and took her out for a fly, All I can say is That OWB is SWEET, Made her much smoother IMO, Flew 3 batts, had to come in cuz it got DARK . No crashes or close calls either, Think I had her about 100ft up this time. Learning more every flight, Hopefully I will try some slow piros soon.
AMA Member
Old 02-25-2014, 09:16 PM   #28 (permalink)
Default Re: One Way Bearing
How many shims did everyone's come with. Just installed mine. It had for shims.
Old 02-25-2014, 10:37 PM   #29 (permalink)
I don't recall having any shims included nor do I need them . Just pull your main shaft up as far as it will go then tighten up the grub screws on the collar. Just make sure to install the lower Jesus bolt through the OWB and the mainshaft first.
nartac is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 01:28 AM   #30 (permalink)
Mine had 4, I left them on.
AMA Member
Old 02-26-2014, 01:54 AM   #31 (permalink)
Same here 4.
terryv83 is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 04:23 AM   #32 (permalink)
I dont remember any either
BLADE 500Xc, 300X, MCPX V2 BL, 130x Red Bull, Hubsan X4 Quadcopter, DX7s
sn00p is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 05:37 AM   #33 (permalink)
They're inside the assembly, if you didn't dismantle it you wouldn't have seen them. They all go inside anyway, so really it's not a problem.
Old 02-26-2014, 07:27 AM   #34 (permalink)
Default One Way Bearing
That explains it. I'll pull them apart next time if I need a main gear replacement and check them out.
Old 02-26-2014, 05:38 PM   #35 (permalink)
flew today with my new owb and slanted main gear, i felt no difference, but i like how it spools down now.
it's harder to get the belt on, that's the only difference i saw.
XLPower Specter V2 - Rotorflight - ELRS
OMP M2 Explore - Rotorflight - ELRS
TX: Fr-Sky X9 Lite S / RM Pocket - EdgeTX - ELRS
P.I.Engineer is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 05:59 PM   #36 (permalink)
Yeah I bought it to be proactive. Wish it didn't cost so damn much but I guess I do get some stickers.....if I put one on my car you think I'll get 85mpg? ?
Old 03-01-2014, 12:11 AM   #37 (permalink)
Ya, thought I'd never get the belt around the pulley , but I fussed with it and finally she went on...Then I turned the gear and it was REALLY out of round so I knew I had messed something up and had to take the whole thing apart again. Upon a close inspection of the main gear I saw that I didn't tighten down 2 of the screws to the hub all the way on the main gear. Once I did that and fought to get everything back together AGAIN, Now she was super smooth as it should be.
AMA Member
Old 07-20-2014, 11:00 AM   #38 (permalink)
Pretty much a very fast controlled landing not a true auto at all, these helis are to small to do a real auto. there is no flare at the bottom. the heli is still dropping.
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 07-20-2014, 04:27 PM   #39 (permalink)
The Airetic
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 10:04 AM   #40 (permalink)
I would argue that if the power has been cut and the heli didn't come crashing to Earth it is by definition a "true auto". If there were no flare then the heli would have been buried. It was a very smooth and accurate flare with zero margin of error. They're certainly not the most beautiful autos I've ever seen, but the argument that they aren't true is ludicrous.
Watch the video again and tell me you don't think what you're seeing at about 1:00 counts as a flare.
[ame]http://youtu.be/vG9E163pjY8?t=55s[/ame]
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
