Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600/600 PRO Aftermarket Upgrades and Mods
600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support
Old 07-23-2012, 06:59 PM   #1
relax1
Default trex600efl after market main rotor housing
The main rotor housing on the head keeps developing a lot of slop. This is a poor design by align just having one 3mm bolt holding the head . It works fine on the smaller machines 450.500,550, but the 600efl on a 12cell setup takes a lot of stress. All the new design on other manufacturers have two additional bottom bolt pinching the main shaft.
Any one knows of an aftermarket housing i can use?
Luis
relax1 is offline        Reply With Quote
Old 07-23-2012, 07:09 PM   #2
ke6d
Check here:
http://www.kdedirect.com/600EPROSeriesProducts.html
This is the part you want
AT550/600-MRHFB
Current Fleet: TRex-700/500/450/250 Vbar, Logo 600SE/600/500 VBar, Outrage Fusion 50/G5 VBar/FB, Blade mCPx x 2
ke6d is offline        Reply With Quote
Old 07-23-2012, 07:21 PM   #3
relax1
Thats what im looking for.
Luis
Old 07-23-2012, 09:15 PM   #4
relax1
Is anyone using it that can comment on it?
Old 07-23-2012, 11:47 PM   #5
Commodore8888
I've heard very good things about the KDE stuff. Personally I run their motors and have a few bits of theirs in my 600 and 450.
Rotor head wise though went I went from FB to FBL on the 600PRO I went with the Trac-X/Compass 6HV head(this time from Nankin Hobby. I think experience has it too now). Center locking bolt, and two on the sides. I've never seen one come off a heli without the whole mainshaft going along for the ride.
"You need more rockets. Everything is better with rawkets"
E5-S KDE 600XF / N7 Tweaked 1.05
X3 / BRAIN'd MXS-C
Mike Dipalo--Synergy RC, MKS Electronics
Commodore8888 is offline        Reply With Quote
Old 08-22-2012, 03:21 AM   #6
taoY
I used the KDE head for about 10 months on my 550 and 600 pro. Work great to me. Went through numerous crashes. The heads are still true. I just switched to the XT version (for DFC setup) about 2 months ago. Work as good as the non-XT version.
Go for it, you will like it,
TDR II, 2xTDR, Logo 700 XXtreme, Logo 550SX V2, Trioblin 700Comp w/KDE upgrades. KDE motors on all helis
taoY is online now        Reply With Quote
Old 10-10-2012, 02:19 PM   #7
Luvmyhelis
Same here, the 6hv out of all the head designs except Bobs impressive design at RcTek are def the way to go. I outfitted mine with the 6hv direct grip head also and it is impressive. Plus on all my 6s and 12s 420mm stretched 450s I abandoned the stock align head entirely for one that had 2 grip bolts and the shaft set bolt to control the head. All the align's, even and especially their new dfc heads sucked.
Jeti//800Triabolo/Gob700/SHS800/Frankenheli600/Chase420/Compass/Coax/Sk720B/540/360 YGE/YEP/HW/MKS/Outrage/Turnigy/Mibl/Soko/KollDubroRcTek/Boca/Herc/Gryphon/ScottGray Scorp/KDE/Kontronik/TP/Tenax/Lynx
Luvmyhelis is offline        Reply With Quote
