Go Back   HeliFreak > R/C Helicopters > Zeal Rotor Blades
Zeal Rotor Blades Zeal Rotor Blades Support and Discussion
Old 04-23-2016, 12:06 PM   #21
wrench567
I had a 325mm Energy blade failure the other day. I also have a giant scar in an oak tree from the failed blades. I was doing some laps around my yard when the left aileron servo locked up in a left turn and I didn't have time to adjust or even hit TH. 4 feet high on an oak tree there is a gash more than a half inch deep. The Zeal blades stayed together but shattered the whole length. Damage was light for the hit it took. Both rotor blades, feathering shaft, and canopy. I took apart the failed servo and found a brass tooth jammed between two other gears. The servo was probably damaged in a previous crash and finally failed on this flight.
The hit these blades took and stayed together is a miracle. I have had other blades fly apart with a minor hit. Hitting an Oak tree about a foot in diameter would have shattered with pieces flying any other rotor blade.
I will buy anther set of these.
Pete
I started with nothing and still have most of that left.
DX7, 450 Frankenbird, 500 Align, Blade Nano CPs, Blade Inductrix. Chase 360 on the bench.
wrench567 is offline        Reply With Quote
Old 04-24-2016, 10:31 PM   #22
Dylan Hudock
Sounds more like you had a crash than a blade failure!
KBDD Team Pilot Trex 700-500-450, Gaui X3
Dylan Hudock is offline        Reply With Quote
Old 05-01-2016, 06:14 PM   #23
Solmanbandit
The Zeal blades are as reliable as anything else on the market. Every single blade manufacturer has had defective blades. To state that they are somehow less reliable than anything else is simply untrue. There are thousands of sets of Zeal blades with hundreds of flights on them that never have an issue.
Show me where other manufacturers have as many posts on failures as Zeal does. I looked in the Cyclone forum and didn't see a single negative review. Only other blade that I heard of that had issues was Spin Blades. I haven't heard whether they are still having issues or have since fixed the problem of breaking at the root.
Trex 700 DFC Ikon / Trex 500L Ikon / Trex 500 ESP Ikon / HD Cell 500 - Ikon 2
Solmanbandit is offline        Reply With Quote
Old 05-01-2016, 06:29 PM   #24
Number
I think that was a praise post
Number is online now        Reply With Quote
Old 05-02-2016, 05:19 PM   #25
Johnny31297
I asked him before, no response, because he can't say anything. At least Fun-Key is 100% bulletproof and they have been around since like 2006.
Jonas
LOGO 690 SX, LOGO 600 SX, Forza 450, Oblivion 300+
(***WARNING*** Stop Spamming Helifreak)
Johnny31297 is offline        Reply With Quote
Old 05-31-2016, 07:28 AM   #26
Acko71
Thumbs down Crash :-(
Hello to all off you, new member here.
Bought a set of Zeal blades 2 weeks ago and flew with it last Thursday, had a blade failure mid flight where one of the main rotorblade broke resulting in bad crash and no heli left :-( . Im not a 3D pilot so it cant be anything else than bad manufacturing. The tip of the blades are undamaged and the tailbom is undamaged so its not a bomstrike. Sent email to Fastlad and Heard nothing . Just want to send strong warning to anyone thinking of buying Zealblades.
My heli was a Soxos 700 with Zeal 690mm blades....
Acko71 is offline        Reply With Quote
Old 05-31-2016, 02:18 PM   #27
Dylan Hudock
They seem to work great for some people, but it is a given fact that they have a higher failure rate than other blades out there. If you like them, more power to you! But I, and a few others I fly with, have made the decision to stop flying them because of the risk.
Old 05-31-2016, 02:29 PM   #28
Number
I fly the small blades because they're cheap. They're the best blades for the Trex 250 by far, and the Zeal 380s are basically half the price of the Switch 383. I've never had a problem with the small ones. But the forces on big helicopters are exponentially bigger compared to small helicopters, and I am not comfortable trusting them.
