Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-12-2016, 04:06 AM   #1
apper001
Default Lucky Bastard...
Got meself a tuned 700MX and 600L Dominator kit, so time to strip the old bugger today and look what i found....
Gotta admit that we had a couple of rough flights lately
ID:	675425   Click image for larger version
ID:	675426   Click image for larger version
apper001 is online now        Reply With Quote
Old 10-12-2016, 04:30 AM   #2
apper001
Default motor pinion
Pinion looks pretty new, motor looks good but hear a bearing noise.
No idea what todo with the 600mx...
ID:	675428   Click image for larger version
ID:	675429   Click image for larger version
ID:	675430   Click image for larger version
Old 10-12-2016, 12:02 PM   #3
cobieg
is this from a crash?
I didn't crash. I just ran out of airspeed, altitude, and idea's all at the same time.
cobieg is offline        Reply With Quote
Old 10-12-2016, 04:33 PM   #4
apper001
semi crash and wear&tear over 5 years of flying. semi crash came when packs died during flight and triggered an inverted "landing".
Old 10-13-2016, 02:40 PM   #5
Heli.Maniac
I busted both frame sides in the same way after a crash. Turns out stiffening the frame to prevent servo flex does have its downsides. But that is nothing that some high strength epoxy can't fix.
Andreas (formerly known as anmatheextreme)
Compass 7HVU
Logo 600SX CF
Blade 450X
Heli.Maniac is online now        Reply With Quote
Old 10-13-2016, 04:40 PM   #6
apper001
Got the new 600l kit today, looks nice and spanky! And now got a whole bunch of spares, will take a couple of days to assemble and then see what goes with my tuned 1.5mm 510KV 700MX. Like the new blue/red/white canopy, althought could be a bit thicker and stiffer.
setup:
tuned 700MX
pinion 14?
80CC or 120HV
3SX
1x/2x 1700 mah lifepo4 Rx pack
Align 600/95mm to start, maybe chop some 105mm to 100mm, and might upgrade to VTX
