Old 05-13-2010, 01:36 AM   #41
RMKinWI
I am building the 450Pro following the videos to the letter. I just bought my kit it has the 780 gyro. When building the long links my manual says they should be 20.9mm inside and 43.5mm center to center. In the videos Bob builds the long links to 23mm inside. What should I do? I download another manual and it says 23mm. Maybe the manual has been updated?
Matthew Lust - Mount Horeb, WI
Trex 550e -- Trex 450 Pro -- Phoenix Simulator -- JR X9503
April 2010 - First Flight w/Nothing Broken
RMKinWI is offline        Reply With Quote
Old 05-13-2010, 09:38 AM   #42
Ah Clem
I would follow Bob's recommendations.
Ah Clem is online now        Reply With Quote
Old 05-28-2010, 05:34 PM   #43
dandnl333
I am soo glad I found this forum, I am building a T-Rex 450 Pro using Bob's awesome videos. This is my first direct drive tail rotor, and am learning a lot!
Dan
dandnl333 is offline        Reply With Quote
Old 05-29-2010, 11:56 AM   #44
Kraanwater
Bob i would like to thank you for the video's! Just build my trex 450 pro (first heli ever) with your video's and it was easy . I only need to setup my transmittor and then i am ready to go.
Greetings from the Netherlands!
Kraanwater is offline        Reply With Quote
Old 06-12-2010, 04:23 PM   #45
helidude71
Also found the videos very helpfull.
The newer Align 450 PRO combo uses the GP780 gyro. (Not the GP750 any more like Bob used in his video.)
If you do the flip grip mod there is no need to put the ballink on 8 mm.
This is needed with the older GP750 and not with the GP780 gyro.
Other than the rudder control rod being 6 mm too short, no problems here.
(Should be 336 mm, ALIGN FIX THAT PLEASE.)
And yes, it's a great flying bird!
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote
Old 10-04-2010, 01:38 PM   #46
ClownTrigger
Thanks for these! Great job!
ClownTrigger is offline        Reply With Quote
Old 10-28-2010, 11:21 AM   #47
DMEN
I am also in the middle of my new build. Was wondering if the recent kits were any different from Bob's vids from last year. Thanks Bob and helidude!
DMEN is offline        Reply With Quote
Old 10-28-2010, 04:33 PM   #48
Finless
Team Taco VP
I am unaware of any drastic changes on the Pro from last year to now.
Bob
Old 10-29-2010, 11:23 AM   #49
DMEN
Thanks Bob. I am using your videos and glad to have watched all of them before beginning assembly. It saved time because I went ahead and did the flip grip the first time around
Old 12-14-2010, 11:43 AM   #50
maRRRco
hi everyone
exist a correct position for the tail rod guides on the boom ?
in the pictures i see that everyone place them when prefer
but perhaps is better a solution where the rod flexes less then possible
it's a good idea separate in 3 identical part the rod ...
or is better leave a longer part free near the servo and place the guides more back to have only two identical part of the rod ??
i don't know if i explane well, sorry for the lack of english
T-Rex 450 Pro - Blade mCPX - Blade mSR - E-flite Sbach 342
Parkzone Sukhoi 26Xp
maRRRco is offline        Reply With Quote
Old 12-29-2010, 09:14 PM   #51
kamolsf
Big Thanks
kamolsf is offline        Reply With Quote
Old 02-20-2011, 10:07 AM   #52
yoi.nick
hi BOB! hi know there are lots of lipos out there, do you have a favourite for your T rex 450 pro! ? gonna buy an anti taco too> seems very sensible!
yoi.nick is offline        Reply With Quote
Old 04-10-2011, 10:07 AM   #53
daddoo
My post has moved to techroom
daddoo is offline        Reply With Quote
Old 04-27-2011, 06:48 AM   #54
DJ Jakarta
Thanks for the Videos Bob, fantasitic, really loving the tail grip flip mod.
DJ
DJ Jakarta is offline        Reply With Quote
Old 04-30-2011, 08:05 PM   #55
SkinnyMcGee
sorry
Trex 450 Pro-Radix Paddles-Edge tail blades- Radix Blades- ICE 50-12t- Hitec HS-65MG
Trex 250 SE-Scorpion HK-2206-3900-Castle 25A-Jr 3500g-GY520
Outrage Fusion 50 FBL-V-Bar 5.1
SkinnyMcGee is offline        Reply With Quote
Old 05-06-2011, 03:16 AM   #56
erisaman
DJ
My thanks also ..... just one query re the grip-flip.
Is it equally advisable/beneficial to do the flip when using a BeastX contoller rather than the GP780?
If you don't stand for something - you'll fall for anything!
erisaman is offline        Reply With Quote
Old 06-24-2011, 05:15 PM   #57
carlsona
Default gyro channel
I'm setting up the tail and in your "Setting up the tail and gyro STOCK" video you turn the gear channel down to 40%. Do you have the gyro plugged into the gear channel? I thought I was suppose to plugged in to Aux2 (that's what the manual shows).
Thanks!
carlsona is offline        Reply With Quote
Old 09-07-2011, 03:11 PM   #58
jetfinn
Default Newbie here
Happy to find this site, i have bought trex 450 and trex700 now. like to build these things
jetfinn is offline        Reply With Quote
Old 10-04-2011, 11:18 AM   #59
cpmboy
mine uses the GP780 also and I use the 1st hole (close to centre skrew) on the tailservo arm..Now I'm into tail and gyro setup. So...meaning if I do the 'FLIP-THE-GRIP thing....I dont need to adjust the ball links right?......
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote
Old 10-04-2011, 11:29 AM   #60
suresharp
That is correct. Check centering of tail anyways after completion and push rod and links are not binding
suresharp is offline        Reply With Quote
