Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters > 700 Aftermarket Upgrades
700 Aftermarket Upgrades Align T-REX 700 Aftermarket Upgrades by HF Vendors and Supporters
Old 07-01-2009, 01:29 PM   #1
Finless
Team Taco VP
Default NEW - Four Axis Mod1 Maingear install and setup video - No longer in production
OK I had done a review of Miro's Four Axis Design main gear and you can find that here:
http://www.helifreak.com/showthread.php?t=144263
Miro sent me the updated kit which now includes an Alignment tool and a new bearing block that is adjustable. This helps get your pinion mesh perfect and reduces noise that a mod 1 gear can make.
Here is a install and setup video.
Video Link ->Four Axis Designs Trex700 Mod 1 Maingear Install and Setup (55 Megs)
Enjoy,
Bob
Old 07-01-2009, 10:03 PM   #2
mapleleafs
thanks for the video Bob, very smart method they used to adjust the gear mesh and engine alignment....
Vbar Trex 700, Vbar Protos 500, Vbar Logo400 Trex 450 Pro
mapleleafs is offline        Reply With Quote
Old 07-05-2009, 10:40 PM   #3
Kinger
So with the adjustable motor mount, I'm assuming you have to slot the carbon bottom plate screw holes to allow it to fit correctly on the adjusted mount?
Team Synergy
Kinger is offline        Reply With Quote
Old 07-06-2009, 12:04 PM   #4
mapleleafs
either that, or just leave those screws out and use the other 4 used to put the landing gear on.
Old 07-06-2009, 12:47 PM   #5
Finless
Team Taco VP
Yes I slotted the screw holes for the bottom plate. It wasnt that far off and was no problem.
Bob
Old 07-22-2009, 02:29 PM   #6
Miro Novy
Hello,
You actually don't have to slot the bottom frame plate holes. We include 6 bolts with washers with the engine adjustable brackets, so you can use 2 on the bottom plate.
Thanks,
Miro
Miro
Miro Novy is offline        Reply With Quote
Old 07-24-2009, 07:11 AM   #7
Altec
Is anyone else having this problem with there main gear? See pics below, as you can see the gear is wearing out on the top, almost like its flexing under loads...
I already broke it down and there is nothing that I can see that causing the problem.
Altec is offline        Reply With Quote
Old 07-24-2009, 10:10 AM   #8
cation3
Look at the inside of your canopy - its probably rubbing on the gear. My (Align) -1 gear looks the same as yours after I put on a Canomod Striker canopy. I shaved part of the fiberglass from the back and now it (mostly) clears the gears.
I'm still running the same gear. I think its probably a little weaker, but I'm running it anyway.
HTH,
-Drew
cation3 is offline        Reply With Quote
Old 07-28-2009, 02:08 PM   #9
Miro Novy
Yes it looks to me like it's the canopy as well. There is no reason for it to wear like that except the canopy.
Miro
Old 07-28-2009, 06:05 PM   #10
Altec
yea it was the canopy...I didn't notice the black on it till you mentioned it Drew, thanks
I was just getting worried it was flexing
Old 11-08-2009, 10:14 AM   #11
watso
Default gear
are you guys getting lots of flights on these gears with no problems?
vibe 50nex ys56
trex 700 le
avant aurora ys91sr
watso is offline        Reply With Quote
Old 06-08-2010, 06:06 PM   #12
Dano8592
Where do you buy the mod 1 gear and motor mount set up I have looked all over for it and can't seem to find any one that has them....
Dano8592
Dano8592 is offline        Reply With Quote
Old 06-08-2010, 06:08 PM   #13
Dano8592
I ment the four axis design mod 1 gear and motor mount.. Not the Align one....
Dano8592
Old 06-10-2010, 02:42 PM   #14
Yogi1
They are no longer in business best alternative is a KDE main gear and Align clutch pinion as for adjustable motor mount and clutch block the G-Force one works nice.Yogi
Velocity is a State of Grace Get Some !!!!
Trex700eV2 SK720 Trex700n DFC
Trex500Pro DFC 7200/BeastX
Chaos600e BeastX Trex450seV2 ZYX
Yogi1 is offline        Reply With Quote
Old 12-23-2011, 08:38 PM   #15
DDragon
Hi
Does anyone have a 15T pinion by Miro they'd like to sell? PM if you have one.
Cheers, Deron.
Still lovin' it after all these years
DDragon is offline        Reply With Quote
