Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 08-28-2016, 04:26 AM   #541
Grumpy_Old_Man
Thee 85mm blades would give you less thrust than two 95mm blades, so that would seem like a strange way to go?
If the object of the exercise is to increase the hold of the tail then I'd expect to have to use three blades of the same size as the two blade tail (95mm).. which should give a roughly 30% increase in tail thrust.
KDS Agile 7.2 | Goblin 770 Carb. Comp | Goblin 630 Comp | Trex 600Pro (626 stretch) | Kasama Dune 600 | Compass 7HV U | Trex 700X | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 08-30-2016, 04:35 PM   #542
jmtyndall
Didn't bother doing any sort of calcs. Sometimes going to a three blade setup necessitates dropping a blade size. Just an off-hand suggestion made while drinking a beer and eating dinner
[Prtos][Prtos Max V2][Brain Flybarless][DX9]
MSH USA/Brain Team Pilot
jmtyndall is online now        Reply With Quote
Old 08-30-2016, 05:28 PM   #543
Grumpy_Old_Man
I'm an engineer, I have to do calcs!..
A quick fag-packet calc says you would loose some tail authority with a 3 blade 85mm tail over the standard two blade 95mm tail... So it would be a step backward on a heli already short of tail authority.
Three 95mm blades would be fine i'm sure. I run two 105mm blades on mine and it works great but needs a boom stretch to be safe.
Old 08-30-2016, 06:33 PM   #544
Heli.Maniac
On other helis with 2 bladed tail and good tail ratio and blade size, doing a 3 bladed tail conversion would normally mean to either drop the tail ratio or go down on blade size. But on the 600 we want to increase the tail authority and keeping same blade size will probably bring us right at the sweet spot of available tail thrust even for lower headspeeds. Now for guys that frequently do headspeeds of 2400+ there may be some issues on the long term with material fatigue, especially the tail gears. Either way for headspeeds that high, tail authority doesn't seem to be an issue already so maybe a 3b conversion may not be worth it in those cases (except for bling factor).
Andreas (formerly known as anmatheextreme)
Compass 7HVU
Logo 600SX CF
Blade 450X
Heli.Maniac is offline        Reply With Quote
Old 09-01-2016, 03:56 PM   #545
apper001
Isn't there some maths/calc you can do to check main rpm, main thrust versus tail ratio, tail thrust to get a nice rpm range to fly with a secure tail all the time.
need to check that darkhorse calc...
apper001 is offline        Reply With Quote
Old 09-01-2016, 08:42 PM   #546
jmtyndall
Me too, but after work I just don't feel like doing any more haha
Old 09-02-2016, 07:25 PM   #547
cobieg
Is the nitro auto gear mod. being used in this config. If so could 85mm blades be used?
I didn't crash. I just ran out of airspeed, altitude, and idea's all at the same time.
cobieg is offline        Reply With Quote
Old 09-27-2016, 02:11 PM   #548
Grumpy_Old_Man
I'm not sure about the nitro gears but the gears from the older ESP version have been used which speed up the tail allowing stock 95mm tails to be used at less than screaming headspeed. You wouldnt want to use 85mm tails on a 600.
Old 09-27-2016, 05:30 PM   #549
cobieg
I was thinking of a scale model with lower head speed say, 1500 rpm.
I run my 4 blade scale 600 with the nitro/esp gear ( I think they are the same ) and have to use 105mm. The tail will try to come around on a hard collective input. I found out that it doesn't like tic-tocks! It does loops and rolls nice though.
