Old 06-13-2007, 10:53 PM   #21
helis101
Mercuriell
I cant get your videos to work this message comes up (Cannot make directory email systems adminsitrator)EDIT:Its working now
Jeff - Microbeast/Ikon , Logo 550SX ,Protos 500 , Protos 700 V2
helis101 is offline        Reply With Quote
Old 06-23-2007, 05:55 AM   #22
Mercuriell
Burnt out the clutch lining on the 600N so put together a video on relining the clutch - not gonna win me an Oscar but if you never tried this might give some idea of what to expect. No fault of the 600N - fired up the wrong model on the Tx which threw the governor settings out - had to hang onto the rotor disk at about 1/2 throttle till I ripped the fuel line off
You need to take out the self tappers each side into the fan housing and the video takes it from there. I think the fan must flex significantly during flight as it is pretty scored and the base of the GV-1 sensor was damaged (fixed with epoxy)
Clutch relining - 23MB
John
Mercuriell is offline        Reply With Quote
Old 06-23-2007, 05:57 AM   #23
benzmaster
yeah cooooooll that was just what i was looking for !! merci beaucoup mon ami !
T-rex SE V2
Hacker A20-6XL motor - Hs65MG's - ESC 35X - GY401 - Gorrilla gear & tail paddles
T-rex 600N - OS 50hyper - GY401 and s9254
9451 on cyclic - Hatori muffler - 2 in 1 reg -Multigov
benzmaster is offline        Reply With Quote
Old 06-29-2007, 02:13 AM   #24
Mercuriell
After another clutch burnout (no one's fault 'cept moi ) I thought I'd video erniefritz' method of clutch removal from the top ! Nice one Ernie
Clutch removal from the top - 16MB
John
Old 06-29-2007, 04:50 AM   #25
benzmaster
Question : once you have loosen the screw and every thing is done, do you put loctite before tighten them back ?
personally I put blue loctite on every screw, even self taping screws.
I've replaced my liner, but I did it without removing the clutch bell housing.
just unmounted the motor, and placed the heli upside down on my knees.
this is for me the simple way
T-rex SE V2
Old 06-29-2007, 04:59 AM   #26
Mercuriell
Yes put Loctite on all metal to metal threads - after cleaning oil off if necessary. For load bearing self tappers into plastic I would use CA as there is rumour Loctite rots plastic though haven't seen it myself. For non-load bearing eg fan shrouding I'm not convinced any locking compund is necessary.
John
Old 06-29-2007, 05:05 AM   #27
benzmaster
my local shop told me that green loctite rots plastic, but blue does not. they put blue loctite everywhere.
T-rex SE V2
Old 07-04-2007, 03:24 PM   #28
Bobbyk
Location: Born in London, Live in ATL, Heritage from Ghana
Thanks for taking time out in creating these very informative vids, they are of great help to me and I'm sure other will agree with me....
Keep up the good work!
Thanks again John.
Robert
<<< Ashlyn, daddy loves you more than his heli's, don't mind mummy >>>
<<< ..............MA Spectra G (Supporting Made in USA), DX7.............. >>>
Bobbyk is offline        Reply With Quote
Old 07-04-2007, 05:49 PM   #29
Test005
These videos are great Mercuriell. Thanks for sharing.
I'm new to this forum, and one reason I signed up was to get access to the build videos of the 600N.
Test005 is offline        Reply With Quote
Old 07-13-2007, 06:58 PM   #30
EddieNewYork
Thanks for the vids John!
And, what is an External BEC Glow Driver RCE-B6X used for?
EddieNewYork is offline        Reply With Quote
Old 07-13-2007, 08:12 PM   #31
Mercuriell
Its a 2 in one step down regulator - 7.4V in from a 2S lipo and 5.9V out for the radio electrics and 1.5V out for the glowplug when starting the engine - saves having to lug around an extra power source for the glowplus together with adaptor leads etc - it works well and saves stuffing around
John
Old 07-13-2007, 08:55 PM   #32
EddieNewYork
Does this replace a glow starter?
Old 07-13-2007, 11:13 PM   #33
Finless
Team Taco VP
NO! you still want the step down to 5.2 for the tail servo! Tail servos on a 401 (9253) or the 611 (9256) need the lower voltage for reliability and longivity....
Eddie... welcome to HF! About time you started looking for answers at the place that gives the best answers
Bob
Old 07-14-2007, 12:55 AM   #34
EddieNewYork
Hahahaha, glad to be here Bob and thanks for the warm welcome!
Old 07-14-2007, 07:18 AM   #35
Mercuriell
Yes - works very well and doesn't seem to draw much from the lipo to my surprise. Still carry a glow starter as back up though
John
Old 07-14-2007, 06:31 PM   #36
EddieNewYork
Cool, thanks mate.
Old 09-12-2007, 06:11 PM   #37
Mercuriell
Redone the link page and added in beginners tail & gyro setup and also covered crash repair and rebuild rotor assembly - instaallation of metal grips and new feathering shaft included in the latter.
John
Old 12-02-2007, 06:00 PM   #38
yoadrian
Default .50 Hyper repair
Hey Mercuriell, I don't know if this would be the right place for it but I'm looking for a do and don't on taking apart and cleaning out an OS .50 Hyper. I have never taken one apart and don't want to screw it up any more than I already have. I am still breaking it in and took it out to a site that had just been graded, and it kicked up a huge cloud of red dirt and now I can get the Hyper to turn over. Am I truly buggered or will cleaning it out do any good? Any advice would be appreciated.
Adrian
yoadrian is offline        Reply With Quote
Old 12-03-2007, 04:40 PM   #39
Mercuriell
Wayne Brown has written a how-to on OS strip down and bearing change http://www.helifreak.com/showthread.php?t=11277 I would think that a break down and clean out would be likely to fix your motor and it's not too hard as long as you're careful
John
Old 12-07-2007, 10:16 AM   #40
yoadrian
Default Build & repair videos 600 Nitro & E - by Mercuriell
Thanks, I'll check it out. Is it normal to feel resistance when turning the piston over? Is there a rule of thumb on what to look for?
Adrian
