Old 10-05-2014, 10:24 PM   #1
SRJay
Default Some 450L mods
I've had my Dominator for about 2 months now and am really liking it. I did a few mods I thought I'd share I feel improve the heli. The first mod was to change out the landing gear, IMO the tail sits way to low stock. I made the gear from an original set of landing gear from my Goblin 630 comp. It worked out well and all but the center mounting hole were pre-existing in the part.
The other thing I changed was the balls on the servo horns. I did not like the way the stock links sit at an angle. I used a set of extended balls from a TRex 550 DFC on the servo horns to achieve 90 deg push rod geometry.
I also dremeled out the plastic pieces in the frame sides in such a way that allows removal of the front boom housing without spreading the frame halves. I don't currently have pictures of that and it isn't readily visible on the finished model. I will get some pics of that next time I have it apart. It makes changing the front tail drive gears much easier as the hex's are no longer "keyed" into the frame sides completely. Though I haven't stripped a tail gear since switching the gear out gaining all that tail clearance.
Goblin 630 Comp / Spartan VX1 N Fbl
Goblin 700 Comp / Spartan VX1 N Fbl
TRex 550 DFC Pro stock w/Spartan VX1 N Fbl
TRex 450l Dominator stock w/Spartan VX1 E Fbl
SRJay is offline        Reply With Quote
Old 10-06-2014, 10:55 AM   #2
crashnrox
The skid mod is pretty much needed on the 450l ,align didnt want to create a new skid for this bird so they just went with off the shelf 450 skids. I only had problems stripping front tt gears during setup. So the keyed plastic pieces did make it harder to change the gears. My question is....did you only remove the rear facing part of the white plastic on the inside portion of the frame so the tramsmission still has the spacer between the tranmission and the frame but slides out to the rear without spreading the frame? Hope that makes sence to you. Ive ben hesitant to cut off the white plastic key reciever as ive seen someone else has done . Removing all the white plastic would result in messing with spacers between frame and transmission . Not a good solution in my mind.
450 pro . 450L oxy 3
crashnrox is online now        Reply With Quote
Old 10-06-2014, 02:12 PM   #3
SRJay
You are correct. Just the rearward facing portion of the hex socket was removed. Align was also too lazy to make a new front tail case the correct width.
Old 10-07-2014, 09:31 PM   #4
Colin Broughton
Skids are sick haha, good job man. How about posting a picture of the entire heli so we can get a better idea of how she looks.
MSH USA PILOT - MSH BRAIN FLIGHT TEAM - CYCLONE BLADES - XNOVA - XPERT
MSH Protos Max v2 - MSH Protos v2 770 Evoluzione - MSH Protos 380 - Jeti DS14
Colin Broughton is online now        Reply With Quote
Old 10-08-2014, 11:55 AM   #5
mamartin
Here's a mod I did on mine to fit the KDE450FX motor in between the frames on mineClick image for larger version
Sent from my SAMSUNG-SM-N900A using Tapatalk
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote
Old 10-09-2014, 11:12 AM   #6
BP58
I built my first heli last december "the 450L" and every time I've set up blade pitch I've had to put the stock landing on gear so the main shaft isn't at an angle. Boy did I feel dumb after pulling out my hair wondering why things were so off the first crash rebuild. Just had a thought, would it work to zero the digital pitch gauge to the bottom of frame?
BP58 is offline        Reply With Quote
Old 10-09-2014, 12:30 PM   #7
SRJay
Usually with this type of layout you zero out the pitch gauge while sitting on top of the motor. Shaft doesn't need to be 90deg off table, if that were the case every Goblin made would have problems as they sit with a slight forward stance like this.
Old 10-09-2014, 01:33 PM   #8
BP58
Ahh, of course. Thanks for the tip.
Old 10-11-2014, 01:09 AM   #9
AlvaSpeed
I did the ball link mod on mine too.
Like the landing gear on your heli...
Time for a TDR style canopy....................
Goblin Speed, Goblin 500 LE-12S, RJX 500, Goblin 380, Warp 360, Trex 450L-6S, Trex 250 Pro, 2x 180CFX, MCPx. Quads: Foxtech 300 Hex on 6S !
AlvaSpeed is offline        Reply With Quote
Old 11-04-2015, 07:52 PM   #10
bwijk
could you please show in a short video with the longer ball links how they flex? I have done it but i do not like the way the servo horn flexxes when i put my thumb onder the horn and push the link rod where it sits on the ball on the swash down, with my index finger. ( i hope you understand what i mean ) this way i simulate down force on the longer ballink when the swash pushes down on the linkage rod that connects the swash with the servo horn.
bwijk is offline        Reply With Quote
Old 01-06-2017, 11:33 PM   #11
jmerritt
the 470L landing gear will bolt directly to the 450L! raises tail up much better.
jmerritt is offline        Reply With Quote
