Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 09-04-2015, 06:57 PM   #21
Steve Graham
Ha, Pilots aren't slow to learn generally it's just a cliche based on the fact that at one time or another most RC guys have had someone come to the field who flew full scale and basically said "I fly full scale so I'm SURE this wont be a problem" usually followed by an impressive, if short, little airshow Sad cause the embarrassment after the fact may prevent them from coming back. It's a wonderful hobby with great people and lots of opportunity for meeting cool folks.
Honestly a foundation in aerodynamics and the effects of wind on flying machines proves quite helpful. Small, cheap quads can be a lot of fun and are indeed quite good orientation trainers if not exactly the same as CP helis.
Steve Graham is online now        Reply With Quote
Old 09-22-2015, 09:35 PM   #22
Fizzy
Default Good read
Really enjoyed this read, well done
Fizzy is offline        Reply With Quote
Old 09-26-2015, 01:48 PM   #23
slamdance
Add one more that I see even "seasoned pro's/experts" don't follow:
-Do a warm-up flight. (I see so many experts! just go right into their 4 minute hard 3d....then crash!!!)
No matter how good you are you cannot predict flight problems and electromechanical failures. You can even catch a bad motor if you listen carefully.
PS: Also, your follow up comment about flying "...in a small space/box.." is an excellent idea. I learned to master all my turns flying in a parking lot keeping in the space of 2 car parking space flying at 5 ft. You really learn to "force" the turns doing both turning and braking action at the same time. Flying in a big field tends to make you do planker/aileron turns, where more speed is needed to maintain altitude.
slamdance is offline        Reply With Quote
Old 03-12-2016, 01:31 AM   #24
Jon_PDX
Ryan,
I'm a little late to the party but wanted to thank you for the list.
I've already learned a few things from your list.......Some the hard way.
I also have a Nano QX and I agree it's been a great learning tool.
My progression has been as follows....
Try it on sim
Try it on the Nano QX (sometime I skip the sim though)
Then on my micro CP
Then on to the 230s
I sure that has saved me a few $$$ along the way.
I think I will print out your list so I have it handy as I progress in this hobby.
Jon...
Jon_PDX is offline        Reply With Quote
Old 03-23-2016, 02:55 PM   #25
ryanha
Glad you liked the post! Sounds like you are doing things the right way.
Eventually you will have to add a 450 to the mix since some moves will be really hard on the 230 but you will have a great foundation when that day comes!!!
--Ryan
Goblin 700 w/vBar, Gaui X5 w/vBar, TRex 450L w/AR7200 BX, Dx9. Retired Helis: Blade 300x, Nano CPX, MCPX-BL, Nano QX.
ryanha is offline        Reply With Quote
Old 04-02-2016, 11:21 AM   #26
Koopyetz
Thank you for all you have written. Preflight check of screws has proven to be very helpful. I just started flying my first build ( 450 ) and through checking tail grips for movement noticed that bolt holding one grip started to back out.
They are amazing machines and fun to fly.
Regards and clear skies
Rick
Koopyetz is offline        Reply With Quote
Old 05-03-2016, 12:54 AM   #27
Unihiron
I'm new to the forum. New to the AMA, FAA, etc. Not even a year old pilot but my goal was heli/multirotor flight right off the start. It's good write-up for a first time newbie. I'm in the market to begin my first 450 build. It's good to know i'm on the right track. I have the sim, multi rotors, built my first big built quad and v977. I won't go into much detail. Kudos to the poster for sure!
Now time for some dancing bacon.
Unihiron is offline        Reply With Quote
Old 05-23-2016, 06:26 PM   #28
Blade Scraper
I can add one to this list:
On a torque tube tail, rotate the mains during pre-flight to confirm the tail blades spin too and therefore that the TT is engaged. Could have averted a crash by doing just that. First crash on that heli too and totally preventable.
KDS Chase 360 - μBeast+ - Scorpion - HW 50A - KST 215MG - MKS DS95i
Blade 230S / 180 CFX / mSR X / mSR
XK K110 / Phoenix / DX6i
Blade Scraper is offline        Reply With Quote
Old 07-12-2016, 04:33 PM   #29
Kingfish3r1
Thats a great list, and a motivational one for new CP fliers like me. For the past few weeks, I've been simply dealing with a problem after another with my SR. Just off and on and learning things about it and my flysky Fs-T6 transmitter. And so far I still can't get it off the ground on its own power. But little by little, Im understanding more about it and what went wrong previous times before. I hear a lot of people saying the SR is quite hard to fly despite it being the "perfect transition from a coax heli" as HH says. And I agree, thats a bunch of very misleading words lol.
Kingfish3r1 is offline        Reply With Quote
Old 07-12-2016, 05:34 PM   #30
ryanha
Glad you liked the post.
I don't have any experience with the SR, but I do know that dealing with problem after problem on a heli is no fun at all.
Is there a local club or at least a local hobby store you can visit to get help on getting your bird in the air? Having someone to talk to f2f is immensely helpful.
When (if?) you end up going to a larger CP heli (e.g. 300+) you will definitely benefit from having someone local to check out your setup. It will likely save you many, many crashes.
It is a tough balance because you want to become self-sufficient, but at the same time having someone that has the experience of a lot of hard lessons that you can learn from is extremely valuable.
Good luck and let me know if you need any more free advice
--Ryan
Old 09-05-2016, 01:46 PM   #31
SacrificetotheGravityGods
Smile Top 10 hits the mark
Great list! I'll keep it close for reference. As a former plank flyer, making the transition to Helis has been a hair-pulling, fun challenge. About 2 years ago, I tried to make the transition on a 450-size that was a disaster, only to later find out a bearing on the tail would lock under load. After a "I can't do this" layoff, I'm back at giving it a try on a Blade 230s. I have been flying in my front yard, using a 4'x4' plywood take-0ff and landing pad. It's a somewhat limited flight envelope, but it is teaching me to maintain tight control. To all the other newbies, like me, keep at it and as the "top 10" says, practice, practice, practice the basics.
SacrificetotheGravityGods is offline        Reply With Quote
Old 09-12-2016, 11:15 AM   #32
Marc_RC Heli
Default EXcellent list!
I've rebuilt my 230S about 5 times now, and am waiting to be able to do 3D w/o crashing bef3oreni fly the Goblin 500 that's sitting in my shop...all the points you made will come in handy as a checklist...even a pre-flight checklist!
Marc_RC Heli is offline        Reply With Quote
Old 12-14-2016, 07:35 AM   #33
R12NDS
What a fantastic post! Thanks for taking the time to type it. I have quit a couple of times because it is so hard...but each time i hang my helis i cant them out of my head. Its addictive and your guidance is bang on the money! :-)
Sent from my LG-H955 using Tapatalk
Thank the Lord for Pheonix RC and ACCU-RC!
Blade: 600x | 450 3d | 300CFX with BEC & SAVOX upgrade
Align: 450 DFC Super Combo | 250 DFC Super Combo
In or near Bedfordshire, UK? Give me a shout!
R12NDS is offline        Reply With Quote
Old 12-18-2016, 10:00 AM   #34
11bDad
Thanks for the great read. Had to laugh about not having to duck on a sim. Hopefully that will be a Xmas goodie from the wife. I know now I would had climber fewer trees, bought fewer parts, and been less frustrated if I'd gotten the sim earlier. It all started innocently enough.....rec'd a Nano CPS RTF as a present. Well everyone knows I had to upgrade the TX (DX6). Then I needed something larger & easier to see (230s). Along comes more batteries, a proper charger, and repair parts. My wife thinks I've lost my mind, but I just tell her I'm old and having fun. This site has been invaluable to me. Thanks
11bDad is online now        Reply With Quote
Old 12-18-2016, 07:27 PM   #35
babyuh1
I would like to add something that I discovered while learning to fly helis.
Step one, fixed pitch helis, dont! They just teach you bad habits that make flying a CP harder than it should be. Skip that step and you'll be better off in the long run.
Start out on the SIM and/or one of the stabilized CPs and don't look back!
Please don't confuse my experience with pessimism!
babyuh1 is offline        Reply With Quote
