Go Back   HeliFreak > R/C Helicopters > Cyclone Blades - 715, 695, 615, 555, 505
Cyclone Blades - 715, 695, 615, 555, 505 Factory Support and Discussion Forum
Old 07-16-2015, 08:42 PM   #1
10pilot
Default For Logo 480 xxtreme guys...
If you're wondering if 80mm cyclone tail blades works with cyclone 505's, here's the proof. It works for me. I'll keep this setup until I find out it doesn't work, but I really doubt I'll have any problems.
This is a completely stock Logo 480 xxtreme. I was just curious if it would work because I wanted more tail authority. The only thing I had to add was 3mm adapters in the root holes on the 505's. They're 4mm and the 480 blade grips are 3mm.
10pilot is offline        Reply With Quote
Old 07-21-2015, 02:37 PM   #2
Beersy
Looks great.
Where did I get the 4mm to 3mm adapter?
Travis
Team Mikado USA
OptiPower - Lynx Heli Innovations
Beersy is offline        Reply With Quote
Old 08-17-2015, 07:40 AM   #3
Chep
So, no problems flying 505 blades with a stock 480? No stretching, nothing? That's good to know.
T-Rex 700 HV DFC, Logo 550SX, Logo 480Xx
JR Forza 450, G380, OXY 285
I'm proud of my crashing skills!
Chep is offline        Reply With Quote
Old 10-12-2015, 03:43 PM   #4
oliver1071
Originally Posted by Beersy View Post
Looks great.
Yeah what he said where does someone pick up the 4mm to 3mm adapter? I'm about to buy new blades and was thinking of going 505's since I'm already running 80mm tails.
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote
Old 10-12-2015, 05:44 PM   #5
Lu523
Subbed. I would like to know also.
I found this: http://www.mcmaster.com/#catalog/121/152/=zc8hdt part number 50415k21
Lynx Team Test Pilot
Heli's :mCX2, mSR X, Gaui X3, Logo 480, Goblin 420
Vbar Control
Lu523 is offline        Reply With Quote
Old 10-13-2015, 07:26 PM   #6
Dirtyburd
Good to know. Was planning to stretch to run 505 after I crash but looks like I can run on stock setup. What degree pitch are you running?
Dirtyburd is online now        Reply With Quote
Old 10-13-2015, 07:47 PM   #7
oliver1071
I was going to with this recent crash but I couldn't find the root hole spacers. Looks like they come with my new switch blades so I'll probably try my g500 blades on it for a test before buying the 505's.
__________
Old 12-27-2015, 01:07 AM   #8
DarkSyd3D
Where did u get the 4mm adapters for the blades from?
Logo 480 xxtreme with Cyclone 505/80mm Cyclone Blades - YouTube
Hobbywing NA Support/Team Pilot, BK Servo, Spartan RC, Lynx, Team Oxy, Helioption, Team XNOVA CITIZEN 284, I JUST WANT TO FLY!
DarkSyd3D is online now        Reply With Quote
Old 12-27-2015, 07:29 AM   #9
oliver1071
I never did find them myself. It was just easier for me to get the $12 logo 500 blade grips.
__________
Old 12-27-2015, 07:46 AM   #10
Lu523
Same here.
Vbar Control
Old 12-27-2015, 11:47 AM   #11
DarkSyd3D
Sounds like a good idea. Does it change the pitch settings at all between the two grips or are they virtually identical other than the bold hole size?
Old 12-27-2015, 12:33 PM   #12
oliver1071
They're identical. Same bearings and all just tha hole size
__________
Old 04-10-2016, 11:09 AM   #13
smittylube
500 blades fit without issues? Without stretching?
I have some 500 (actually old 600) grips laying around.
I might need to try this...
smittylube is online now        Reply With Quote
Old 04-10-2016, 11:45 AM   #14
oliver1071
Yup! but I did eventually stretch it after a crash why not if you're buying a boom and belt might as well. But it was fine before hand with the 500 Sab blades and 80mm tail.
__________
Old 04-10-2016, 06:19 PM   #15
smittylube
Stock main gear as well?
I don't fly super hard and have always tried to fly smooth.
Stock form I get sooo much flight time, and the motor is super cool after.
I went as far as flying with 2600's and still get 6 minutes, but I have some 33 and 3700's as well.
Just ordered 503's and 80's for the tail. Have to dig up my 500 grips...
Old 04-10-2016, 09:00 PM   #16
oliver1071
Yeah I haven't had any issue with the gear so far 305 flights on the stretched 480 so far.
__________
Old 04-10-2016, 10:58 PM   #17
smittylube
Thanks Oliver. I'll let you know how it goes.
Also the longer belts are a bit beefier / wider, stronger.
Old 04-18-2016, 08:28 AM   #18
smittylube
Had a chance to get 2 flights and I love it.
The tail isn't 100% correct yet so I'll need to sort that out hopefully
5 or 5.5 minutes and only put 1700 mah back into the packs.
I lowered my HS to 2100/2200 thinking I like the 2100 better.
The longer skinny boom seemed weaker in flight with the stock struts so I grabbed my 550sx struts and put those on.
Tail tweaking today.
Old 05-12-2016, 10:53 AM   #19
smittylube
Sorted out my tail. Loving mine stretched w 523's.
Old 06-13-2016, 07:03 PM   #20
10pilot
