Go Back   HeliFreak > R/C Helicopters > Cyclone Blades - 715, 695, 615, 555, 505
Cyclone Blades - 715, 695, 615, 555, 505 Factory Support and Discussion Forum
Old 10-18-2015, 04:26 PM   #1
KefirHeli
Default Cyclone 695s
Anyone know if there's a way to get ahold of a SINGLE Cyclone Blade 695mm?
I need a single blade.
THanks
KefirHeli is offline        Reply With Quote
Old 10-18-2015, 09:01 PM   #2
TheBum
Have you checked here?
http://www.helifreak.com/forumdisplay.php?f=352
It's very doubtful you'll get one from the manufacturer. Your best bet is to hang onto it until you break another single.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is offline        Reply With Quote
Old 07-03-2016, 08:11 PM   #3
msallua
I crash two sets , and now i have two perfect blades but different set.
Can I mix blades from different set?
Align 800e PRO DFC // Align 700N DFC, 105HZ-R HV // Goblin 700Comp // Goblin 420 // Align 700E DFC HV.// Futaba 14Sgh - RealFlight 7.5 // neXt - Powered by Pulse - IKON's // Castle ESC's
msallua is offline        Reply With Quote
Old 07-04-2016, 01:39 PM   #4
Johnny31297
If you balance them, yes.
Jonas
LOGO 690 SX, LOGO 600 SX, Forza 450, Oblivion 300+
(***WARNING*** Stop Spamming Helifreak)
Johnny31297 is offline        Reply With Quote
Old 07-04-2016, 02:31 PM   #5
TheBum
+1. You typically only need to balance the lighter blade to the heavier one. Adjust for CG first (by adding tape near the root or tip, depending on which way the CG needs to move) and then for equal blade weight (by adding tape centered on the CG point).
HeliFreak Support
