Go Back   HeliFreak > R/C Helicopters > Cyclone Blades - 715, 695, 615, 555, 505
Cyclone Blades - 715, 695, 615, 555, 505 Factory Support and Discussion Forum
Old 11-18-2015, 07:22 PM   #1
Constant
Default Large scale and 4-blade rotorhead.
On my Assault 700E DFC, with 45% Align parts, the 695/105mm blades are outstanding, period I am no acro-man but scale flying is what I like. My latest project is a Marvel Craft Agusta A109 Power with KDS Agile 7.2 V2 mech, Scorpion HK 4535-450Kv, 12S (14S?), Commander V 59V 160A ESC, Monster 4-blade RH-CCR, Neuhaus Electronics sound modul and MTW 8,5 Kg/18 lb.
But: which main-tailblades for a governer headspeed 1300-1450?? I tend to use also the 715 and tail 115mm (120mm would be nice).
Pls. advice, anyone (Tim?) having experience with Cyclone and 4-blade on low HS? I do mild 3D (A109 inverted, no way) and like fast forward flight. Increase HS? 695 versus 715mm on 4-blade head?
Then, is it feasible to special order blades with a solid color, white or black due to the looks of a scale model. I'll put Cyclone-decals on the fuse I hesitate to sanding them off and spraypaint for apparent reason, weight differences and CG. Regards
PS.: stock in Europe is alarming low
Constant is offline        Reply With Quote
