Go Back   HeliFreak > R/C Helicopters > R/C Helicopter Tools and Supplies
R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters
Old 03-24-2016, 05:59 PM   #1
Phoebe
Default Ball Link Removal
Other than proper pliers are there preferred methods/tricks/makeshift tools you use?
Make America Great Again!
Phoebe is offline        Reply With Quote
Old 03-24-2016, 10:17 PM   #2
Gyropilot
In some configurations, large forceps (a.k.a.: tweezers) can be used. The tip of the forceps are placed behind the ball link and pried (popped) off.
Blade 120SR (callsign: The No-Wind Heli)
Lynx (Blade) 450Xv2 w/Microbeast Plus Pro-Edition FBL unit (callsign: The Money Pit)
DX6i, DX9
Rotor thumping member of the AMA
Gyropilot is offline        Reply With Quote
Old 03-25-2016, 10:04 AM   #3
Puttputt maru
I know that is not what you are asking but nothing like the right tools to do the job. this is the best combo I have found to cover all basis ans sizes.
TDR-IIto build, Triabolo, 2 X TDR, Kasama Srimok,90e FAIFA, T-Rex 700e DFC, Goblin700, BD 3SX, Jeti DC-16, Mezon,HW,Kosmik
CompArf 330 SC 2.6 BME 110, Ultimate Aeroworks 20-300, DA 170, CB200, Cortex, Q80-8M in a 91" EF Extra ++
Puttputt maru is offline        Reply With Quote
Old 03-25-2016, 10:50 AM   #4
Phoebe
Couldn't agree more. I'm waiting for a pair of the FBL's as we speak!
Old 03-25-2016, 09:04 PM   #5
curmudgeon
I also use those two ball link pliers. I prefer the KDE/FBL Rotor pliers best because the bronze tip will not scratch the aluminum balls. However, the tips are thick, so sometimes I need to use the thinner JR link pliers with the green handles for ball links in tighter places like the inner balls of the swashplate. I also use a curve ball link pliers for hard to reach places where straight pliers cannot be accommodated in the correct angle.
Synergy 806 & E5s/Logo 700 & 550SX V2/Goblin 700 KSE, G380 KSE, G380; Kontronik ESCs; Spirit Pros; MKS/Futaba/XPERT/BK servos; KDE/Xnova/Kontronik/Scorpion motors
Sims on Mac:
neXt/RF7.5/Phoenix 5/RC7
Jeti DS-16C
& DX8 Gen 2, Citizen 259
curmudgeon is offline        Reply With Quote
Old 05-30-2016, 06:44 AM   #6
tony#1
Will the KDE tool handle ball links for small helis? The quoted ball link size on the KDE website is 4.75mm to 6.00mm. Too big for my Blade 300X ?
Any information gratefully received,
Tony
tony#1 is offline        Reply With Quote
Old 05-30-2016, 08:28 AM   #7
AndrewJHawes
Location: Fitzroy North, Melbourne, Victoria, Australia
I have never flown Align helicopters, but it seems that the balls on Trex 450 are 4.75 mm in diameter on the swash, and on the Trex 250, the equivalent are only 3.5 mm in diameter.
So it seems the KDE will be good down to the 450 size. Maybe, there may be other smaller helicopters than the 450 which will also have at least 4.75 mm balls?
Personally, with my big ugly hands and fingers, I have given up trying to work on 450's and smaller!
If I could currently order a pair of KDE pliers here in Australia, they would get my business, but the international postage is the straw that has broken the camel's back!
Andy
Andy
Australian JETI model & BavarianDEMON Distributor
www.jetiaustralia.com
www.demonrc.com.au
AndrewJHawes is online now        Reply With Quote
Old 06-01-2016, 05:37 AM   #8
AndrewJHawes
I have just tried to use my existing set of ball link pliers on my 3-blade Compass Chronos swashplate. The cheap, relatively soft pair which I bent before (with the grey jaws - not black, and red/black plasticised limbs), would hardly fit behind the balls, so anything thicker would be a waste of time. Indeed my existing ones are too wide to tackle the upper swash.
I have been forced to wedge these behind the link and twist the Compass link off. This is precisely the manoeuvre which bent the jaws the last time. Furthermore, I have ended up having to compress a gouge wound on my little finger as a result, to stop it from continuing to bleed!
I currently hate this aspect of work on the helicopter, and desperately need a better solution.
The jaws need to be narrow, thin, and strong, and I seriously doubt whether these even exist!
Andy
www.demonrc.com.au
Old 06-01-2016, 08:53 AM   #9
AndrewJHawes
If anybody has a pair of the JR green pliers that they could accurately measure the jaws on, I would be most grateful, in order to see whether they would fit any better than my current pair. Width and thickness would be most helpful, especially of the jaw to fit behind the ball link in removing the link.
Many thanks,
Andy
Andy
www.demonrc.com.au
Old 06-04-2016, 01:52 AM   #10
AndrewJHawes
Puttputt Maru,
Appreciate your original picture of the KDE and JR pliers.
I have ordered a couple of pairs of cheepie chinese which look a bit like the HeliMax ones, to be able to grind down to size, but would appreciate some dimensions of the JR if you would care to measure (jaw width, length and thickness). Much appreciated.
Andy
Andy
www.demonrc.com.au
Old 06-04-2016, 06:52 AM   #11
Puttputt maru
I will be back in town tomorrow, if no one has answered before I will give you measurements AH. It will be metric.
Old 06-04-2016, 11:03 PM   #12
AndrewJHawes
Thanks Puttputt maru!
Andy
www.demonrc.com.au
Old 06-05-2016, 09:24 AM   #13
Puttputt maru
ok here we go in mm:
JR:
Jaw width: 8.96
Jaw thickness when both closed at tip: 1.98
Jaw thickness at tip of "U" shape jaw: 0.97
Jaw thickness other end: 1.01
Jaw length from bottom of "U" to tip: 9.85
Spread between the "U" end: 5.06
Thickness of on of the "U" end: 1.95
FBLrotors unlimited
Jaw width: 9.75
Jaw thickness when both closed at tip: 3.14
Jaw thickness at tip of "U" shape jaw: 1.74
Jaw thickness other end: 1.20
The two thickness do not add up as for Jr because I have a bit of a gap when closed and due to the thickness of the FBL tool I cannot make them come together unless I force my caliper.
Jaw length from bottom of "U" to tip: 9.92
Spread between the "U" end: 5.95
Thickness of on of the "U" end: 1.90
I do get some variance of .01 to .02 when I measure again
Hope this help AH
Old 06-06-2016, 05:00 AM   #14
AndrewJHawes
That is great help thank you Puttputt maru! I am tired of scratching my new swash plate with badly designed and poor quality pliers. I will measure the space available to access these ball links and, hopefully, make my choice.
Much appreciated.
Regards,
Andy
Andy
www.demonrc.com.au
Old 11-25-2016, 05:29 AM   #15
Wizza
I bought the FBL Rotors ball-link pliers, and the "dont" fit up to 6mm balls as advertised, and the after sales support is terrible. Mine were only about 5.48mm in the U of the tips. I threw my money down the drain there...
Regards, Mark R (#248)
TRex 700E V-Bar NEO, BLS251, DS8915's, HJive120, JLog, VControl Carbon
TDR 710 CYs, V-Bar NEO, MPH83s, Jive 120, JLog, R2 Buffer, VControl Carbon
Logo600SX 600 CYs, V-Bar NEO, 8715s, Jive120, JLog, R2 Buffer, VControl Carbon
Wizza is offline        Reply With Quote
