Old 07-07-2016, 08:32 AM   #1
Ignatjev
Default TRex 600N maintenance and upgrade
This is my first nitro heli which I bought used, so I have some questions:
1. Align RCE-B6T regulator, could it cause any problems and what should I use instead of it? Dont like connector from battery to this regulator, shall I change and to what, or better upgrade to other regulator? Now there is old Align 1900mah 2S Lipo, better upgrade to what?
2. There is some small fuel leakage from header tank, where silicone fuel line goes out of the tank, is it a common problem and what to do - try to change fastener or purchase another tank.
3. Heli is flybarred, is there a huge increase in performance going to FBL (I have FBL head, but have not decided on FBL system, maybe Spirit as I`m very satisfied with it on my electric TRex 500). Motor is Align 50 (is it the same as OS50SX..?) I`m running 30% nitro fuel w/18% synth oil.
4. Pipe is Curtis Youngblood MP5, is it better than stock Align ?
5. What maintenance, after flight and how much regular, any after run oil or could I use some WD40 spray into cylinder and turn it some turns with starter (without glow plug)?
6. I cant get GP750 to correctly set my rudder travel limits, tried several times and each time it goes full travel until servo screams. But in flight rudder is very responsive.
7. My TX is Spektrum DX8, is it ok to use it with JR DSM2 receiver R9 or better smth else DSMX. Asking because cant get working governor channel - gyro is on governor channel, how to change channels (in TX or simply try plugging into different AUX ports of RX).
ID:	660831   Click image for larger version
ID:	660832   Click image for larger version
ID:	660833   Click image for larger version
ID:	660834   Click image for larger version
Trex600N Pro Trex 500 Tarot 450 HCP100S Heli-X DX8 iCharger206B Spirit
Ignatjev is offline        Reply With Quote
Old 07-07-2016, 04:16 PM   #2
dchekas
1. If your model is flybarred, this is likely an older 2-in-1. These had issues with the switches failing. I would update to a newer 2-in-1 or change to a different glow igniter/voltage regulator setup.
2. You need to determine where the leakage is coming from to determine a course of action. Pressurize the empty header tank with some air (Blow into it with clean fuel tubing and plug outlet holes with your finger) and submerge underwater. You will see bubbles if its leaking.
3. Yes, tremendous benefit. Less drag from the rotor head will make the model feel more powerful. It will fly cleaner and more true.
4. The MP5 was a solid pipe in the day. The Hatori SAB-50 would be an upgrade.
5. No comment here, I do not use after run oil. I do recommend filling your tank with fuel to expel exhaust fumes, and then plugging the exhaust deflector with a plug to prevent moisture from entering. Close the carburetor arm fully when storing as well.
6. I have not used the GP750 in quite some time, but I recall Finless Bob has some setup videos that should address either the GP750 or one of its very close relatives in his T-Rex build videos.
7. Can't help you there.
dchekas is online now        Reply With Quote
Old 07-07-2016, 06:34 PM   #3
Dawiev
If you are considering the Spirit, look on the forums for specific requirements for the magnets. They have improved the governor code too, so it might just work this time with IC engines. ..
Else consider the Ikon / Brain that has a very good IC governor
Dawiev is offline        Reply With Quote
Old 07-20-2016, 04:07 PM   #4
Ignatjev
Thanks to all, now I have a problem that I can`t start the motor because starter shaft is slipping, what shaft is needed, with or without one way bearing?
Old 07-20-2016, 10:50 PM   #5
dchekas
Is the starter shaft slipping in the clutch, or is the starter hex cup spinning on the shaft itself?
Old 07-21-2016, 01:43 AM   #6
Ignatjev
Starter hex cup is slipping on the shaft. In manual it`s called starter coupling. So do I need to order this - http://www.fast-lad.co.uk/store/hn60...ft-p-1751.html
and change coupling or do I need to change starter shaft?
Old 07-21-2016, 07:05 AM   #7
dchekas
Yes, you will need to order that part.
I would change both parts. I would also recommend using a dremel to grind flat spots on the shaft for the set screws to bite on to. This will prevent it from slipping in the future.
Old 07-21-2016, 09:37 AM   #8
Ignatjev
Thanks! Ordered both parts.
Old 07-25-2016, 06:02 AM   #9
Ignatjev
I am going to order new bearings for motor - what to choose from, are stainless steel any help with longevity/rust problems ..? Motor is Align 50, suppose - same as OS .50
Old 07-25-2016, 08:31 AM   #10
907Heli
I buy the stainless bearings, no need for ceramic. To the best of my knowledge the align 50 is identical to the os 50.
Here's a helpful tech tip I always refer to.
http://www.rchelination.com/changing...a-nitro-motor/
"If at first you don't succeed, skydiving is not for you."
TREX 600N, Goblin 570, Gaui X3L, DX7G2, AMA#970963 Citizen 420
907Heli is offline        Reply With Quote
Old 07-25-2016, 09:18 AM   #11
Ignatjev
Thanks! Boca are rather expensive are there any cheaper alternatives..?
Sent from my HTC One using Tapatalk
Old 07-25-2016, 05:16 PM   #12
907Heli
Rc bearings has good quality and prices, I tried these last time and so far so good.
https://www.amazon.com/gp/aw/d/B00PN...?ie=UTF8&psc=1
Old 07-26-2016, 04:11 AM   #13
Ignatjev
Thanks, how many gallons have you put through since? It seems I`m after stainless one ...
Old 07-26-2016, 05:55 AM   #14
907Heli
About a gallon and a half, I just rebuilt in last month and it's been raining a lot.
Old 07-28-2016, 03:36 AM   #15
Ignatjev
I think I have to check bearings etc. internals of the motor, how better remove it from heli?
Dont want to take muffler off..
And what battery to get for receiver, is LiFe better than LiPo, like this one from HK - http://www.hobbyking.com/hobbyking/s...dproduct=32567
Now there`s an old Align 2S Lipo pack I dont trust
Old 07-28-2016, 04:39 AM   #16
907Heli
The first thing to do is pull the muffler off. Then rotate the engine by hand and looking in through the exhaust port at the cylinder, piston and ring. Pull the back plate off, inspect it, and the back of the case and rear bearing. After that you have to remove the engine to inspect any further.
I run a life pack currently, but now I've gone to high voltage servos and I'm going back to this lipo.
http://www.hobbyking.com/hobbyking/s...iver_Pack.html
If you don't have servos rated for high voltage, stick with a life pack.
Old 07-31-2016, 02:29 PM   #17
Ignatjev
How to remove existing fuel line from the fuel tank and change it to MOAS clunk V2 purchased recently. I also removed old header tank because it was leaking, and do I need to install a new header tank (also ordered new one).
Or could I go on with only MOAS in main tank (without header tank)..?
Old 07-31-2016, 10:53 PM   #18
907Heli
I prefer running a header tank but it's not necessary, just remember you have less fuel capacity and adjust your timer accordingly. I currently don't have a header and just run a MOAS. You have to be careful when putting in a new clunk because the line will sell and get longer and can get stuck in the corners of the tank. You must soak the lone and then check to make sure it moves freely.
I had trouble getting the fuel nipple out of my tank and cracked it, but Lynx makes an aluminum replacement that I really like.
Old 08-01-2016, 02:37 AM   #19
Ignatjev
Ok where can I get that aluminium replacement? Thanks
Old 08-01-2016, 12:49 PM   #20
jiminator
I like this the best but he is out of stock right now:
http://www.ronlund.com/rcheli-prod/TREXSTOPPER.html
here is the Lynx
http://grandrc.com/p50237/Lynx-:-ALI...duct_info.html
Might be easier to get the Lynx part here
https://www.lynxheli.com/advanced_se...b45969df91ab6e
jiminator is offline        Reply With Quote
