Old 09-27-2016, 06:28 PM   #41
mr_squiggle
Originally Posted by Ignatjev View Post
I want to change standard clunk to MOAS, how to remove old one without damaging the tank nipple..?
Assuming the rubber is in good condition just remove it carefully & reasonably slowly. It's easier if everything is warm as well so the rubber isn't too stiff. I "wiggled" mine by working the old nipple in a slightly circular motion whilst pulling on it.
186
mr_squiggle is offline        Reply With Quote
Old 10-05-2016, 08:21 AM   #42
Ignatjev
Thanks!
Decided to do flybarless conversion after some time, got VCTRC FBL head and Brain (first version). What else do I need, wire for Brain governor?
Ditch Align governor, 2 in 1 regulator..? What would be the best affordable setup and most reliable? Running LiFe pack directly?
Trex600N Pro Trex 500 Tarot 450 HCP100S Heli-X DX8 iCharger206B Spirit
Ignatjev is offline        Reply With Quote
Old 10-05-2016, 08:31 AM   #43
Number
LiFe direct or in my case a LiPo and BEC.
Number is online now        Reply With Quote
Old 10-14-2016, 08:39 AM   #44
Ignatjev
Life direct into Brain unit..? What connectors to use. And how to connect Align RPM sensor to Brain, I have first gen unit.
So, in my case I take out - standard RX, gyro, Align governor and then mount Brain unit with 2 Lemon DSMX sats, then attach Align RPM sensor. And what tape better for nitro, will 3M be ok?
Old 10-14-2016, 09:30 AM   #45
Number
Servo connectors with wires connecting them to the connector on the LiFe
and this
https://www.amainhobbies.com/futaba-...utq1000/p11561
Old 10-15-2016, 08:06 PM   #46
907Heli
3M gray tape works fine on nitros. I tried other tape and it led to odd things happening because it allowed the flybarless unit to move. I switched it out with 3M gray tape and all my problems went away. All the fbl units on all my helis, and all my friends helis are mounted with 3M gray on all electrics and nitros.
"If at first you don't succeed, skydiving is not for you."
TREX 600N, Goblin 570, Gaui X3L, DX7G2, AMA#970963 Citizen 420
907Heli is online now        Reply With Quote
Old 10-18-2016, 11:20 AM   #47
ticedoff8
To hook the Align magnetic sensor to the Brain 1, plug it directly into the Brain's gov port on the side.
The Brain uses the same micro-JST plug as the Align sensor
You may have to swap the red / black wires
If you have a different RPM sensor, then you need the adapter:
https://www.mshusa.com/collections/b...nor-cable-90mm
I use the Futaba gyro pad on my Trex 600N and 700N.
On my two nitro helis, the Futaba gyro pads were the difference between Rescue working predictably and "crashing".
If Rescue is not important, then use any good quality gyro mounting tape.
For all your Brain questions, look at the MSH Brain forum on HF.
http://www.helifreak.com/forumdisplay.php?f=308
ticedoff8 is offline        Reply With Quote
Old 10-18-2016, 11:43 AM   #48
907Heli
There are two align rpm sensors with different connectors. I'm having trouble finding the older one but this one has the end you're talking'll about.
https://www.amainhobbies.com/align-b...gbp001/p505962
The older ones had a standard servo lead like this
https://www.amainhobbies.com/aerospi...aor110/p168164
This is the adapter cable
https://www.amainhobbies.com/msheli-...h51605/p511321
Old 10-31-2016, 12:39 PM   #49
Ignatjev
Thanks! Now I'm converting to FBL shall mixing arms be parallel swashplate when at zero with Brain setup? At least it seems logical to me shall I change main shaft to shorter one?
Sent from my FRD-L09 using Tapatalk
Old 10-31-2016, 12:48 PM   #50
Number
Doesn't really matter. They do not affect the pitch, all they do is drive the swash. As long as you have 0 pitch at mid stick it's all good.
Old 10-31-2016, 03:47 PM   #51
907Heli
Yep, just move the swash to the limits and check for binding or the possibility of an arm camming over, and if not, you're good to go.
Old 10-31-2016, 09:16 PM   #52
Dawiev
Be sure to choose the right orientation in menu 9 of the setup.
Dawiev is offline        Reply With Quote
Old 11-01-2016, 10:40 AM   #53
meowguy
Yes, use the short shaft. Also use the 2.5mm linkage rod set with the heavy duty ball links.
meowguy is offline        Reply With Quote
Old 11-19-2016, 07:40 AM   #54
Ignatjev
How to put back fuel tank into the frame?
ps. simply removed the upper part of rubber inserted tank and placed rubber back again.
