Go Back   HeliFreak > R/C Helicopters > Low Head Speed Helicopters
Low Head Speed Helicopters Low Head Speed Helicopter Setups and Flying info
Old 07-18-2016, 02:44 PM   #1
bgymr
Default Logo 400se stretch low headspeed
So last year I had a logo 400se i ran on 480mm blades. Loved it but sold it. Regretted it so I bought one again.
This time I streteched it using a Logo 10 belt and Logo 480xx boom. Now it runs 500mm mains.
I outfitted it with really light gear, like a goblin 380 motor, some plastic case jr servos, a smaller esc. Only place I didn't look for a weight savings was on the BLS251 tail servo.
Anyway, in this video you can see that it will run for 7 minutes easy. It only puts back about 1800mah into this pack. It's a very old battery and can't really take the abuse anymore. I believe if I had a 3300mah pack where I could get 2500mah into it after a flight, I would be able to push nine minutes. It's running 1700rpm vbar governed.
Jr3717hv
bls251
KDE500XF-925-G3
Hobbywing 60a v4
vbarish
zeal 500 and 80mm
19t pinion mod.5
bgymr is online now        Reply With Quote
Old 07-18-2016, 03:08 PM   #2
im4711
nice flight -> with 500 mm blades you should be able to bring HS down even further. Also I noticed at that blade size that the switch and rail blades had a wider chord giving you more lift at low rpm.
Kontronik, Switch Blades, Bavarian Demon, HD-Helicopters, TDR, Diabolo, HeliBaby, Takumi and Banshee
im4711 is online now        Reply With Quote
Old 07-18-2016, 03:22 PM   #3
bgymr
Thanks bud. I appreciate it.
That was my third flight with it. I ran it a couple times at 1600. It flies and can barely notice the difference in flight from 1700. But if I get in trouble I want the extra little umpth there to dig out. The formula shows that ideal HS governed is a little higher than 1700. If I find a 18 tooth pinion, I'll run it lower.
I have a 3s pack I'll try on it as well. I think it will fly at 1200 or even lower. But not anything worth flying unless its a hover competition.
Old 07-21-2016, 02:13 AM   #4
apper001
very nice flight man!!
with my standard 480 i get 6/7 minutes of flight with a 3K 6S pack. don't have a HS number
guesstimate 1850 rpm.
guess the best weight savier might be the pack weight.
did you weigh your setup with pack?
apper001 is offline        Reply With Quote
Old 09-10-2016, 09:31 PM   #5
MHN777
Funny post.
Sorry if I sound like a troll. But what you're running now, is the original Logo 10 or Logo 10 SE setup ... It was king in terms of flight times and reliability in its hey-day.
But thanks for your post- because I've been trying to look for a good low head speed e-heli...
TEAM MFS FLYBAR
Hummingbird FP (sold) | MS Hornet 2 ( RIP) | Swift 16 (Retired) | Protos 500 (Sold) | Protos 500 (Sold) | Pheonixtech TT360 Beast X V3 (Sold) | Laheli MaxiR (Sold) | ARK "480" Plus (Still Tweaking) | Forza 450 Ex (NiB)
MHN777 is offline        Reply With Quote
Old 09-12-2016, 10:09 AM   #6
bgymr
I'm glad it was amusing.
It's a tough heli. And I mean tough. I can't believe the main gear doesnt strip after two crashes. I think the low headspeed helps because there isn't as much to energy to dissipate.
I love flying it. It's a great practice heli.
Old 09-12-2016, 03:41 PM   #7
Koopyetz
Nice flying, you're a good pilot. Seeing the possibilities of what you can do with 400 ( stretch) is encouraging.
Thanks for video and setup info.
Koopyetz is offline        Reply With Quote
Old 09-18-2016, 09:52 AM   #8
MHN777
Just saw your video...
I'm just gonna keep it hush hush and start saving up for a logo 400.
I'm a fan of light builds with good useable long flight time... I hadn't realised you put in a Goblin 380 motor... What battery pack were you using?
TEAM MFS FLYBAR
