Go Back   HeliFreak > R/C Helicopter Support > Audacity
Audacity Audacity Pantera Helicopters Support
Old 08-10-2016, 11:17 PM   #1
0nemildot
Default Pantera P6e Quattro on 4S
Long story short, I am new to helis and wanted a head speed/flight time combo that would fit my current ability. The conclusions/discoveries/experiments were an outgrowth of this thread. http://helifreak.com/showthread.php?t=747289
Video or it didn't happen, right? Here is the heli flying.
600mm FRP blades. I used old 230s mains cut down to 115mm in the video to regain tail authority. I am currently flying at a 95mm length, but I think 100-105mm is probably best, I am having to use high settings in the iKON FBL to keep a flyable tail with the 95mm length.
The video I flew with a ESC governed HS of approx. 1100RPM.
I now use the external iKON gov with a HS set to 1070 RPM. I have hovered around 925-950RPM.
Flight times are 7:00. With landing voltages of 15.0V per pack. Based on a 7.7 to 8 mah/sec use I could push to 8min or so.
Battery is a 4S 5000mah 45C Glacier.
Promodeler 120HV ESC
So far so good, I can fly this until I decide what I want to do next. I have tinkered with 6S, and that will probably a better overall blend.
Thanks for watching!
0nemildot is offline        Reply With Quote
Old 08-11-2016, 01:02 AM   #2
0nemildot
I forgot to post the following. I am using the Pmax 720kv motor, and fly with a 2600mah 2S Lipo receiver pack.
If I stick with this setup, I can shed some weight with switching to a more appropriate ESC/BEC combo.
Based on amp draw, I could potentially get 5 min flights with a 3300mah 4S pack. May try that next.
Old 08-11-2016, 12:40 PM   #3
KB3TUO
That sound is FANTASTIC!
"I don't care that they stole my idea, I care that they don't have any of their own" - Nikola Tesla
KB3TUO is offline        Reply With Quote
