Go Back   HeliFreak > R/C Helicopters > R/C Helicopter Tools and Supplies
R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters
Old 08-17-2016, 05:00 PM   #1
faisalmalik
Default Question regarding oils and greases
Dear All
After loosing my patience on publicity of lots of oils and greases, I desperately ordered a huge cache of items as felt necessary. I would like to have guidance on your experiences regarding items that I just bought. They are listed below:
a. Triflow pinpoint lubricator (Not the red grease lubricator)
b. Hudy bearing grease Premium.
c. Heli Option Bearing Oil (with Nano Titanium Particles)
d. Formula 560 Canopy Glue (I usually do normal repairs myself)
e. Triflow Synthetic grease with PTFE Big tube.
d. DryFluid extreme Heli Fluid.
f. Dry fluid extreme Heli gear lube
g. Triflow superior Dry lubricant.
Don't think this purchase is only for the hobby, but I have other uses too, therefore please give your comments on best usage of these items. The description of lots of items is somewhat same on their web page, however only people who have experience of best use can tell the difference.
faisalmalik is offline        Reply With Quote
Old 08-18-2016, 01:56 PM   #2
kayakboy69
Everything has a place ... Meaning I can't coment because I don't know where your going to use on wich part.
IE tail slider if you grease it it will binde because the grease is to thick.
If you oil you bearings you will have to spend a great amount of time inspecting and re oiling them. There usually lubed for there lifetime when built using other lube can actually dry them out so If you do lube them your going to need to keep your eyes on them from that point on.
You choices are all top tier if used for the correct application
Sent from my SM-G900V using Tapatalk
kayakboy69 is online now        Reply With Quote
Old 08-18-2016, 02:03 PM   #3
oliver1071
Funny I guess I'm roughing it haha I just pulled the dipstick on my car for a drop of oil when I was flying at lunch because the tail slider was a little dry
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is online now        Reply With Quote
Old 08-23-2016, 07:28 AM   #4
faisalmalik
I still wait for any more replies. Please suggest
Old 08-23-2016, 09:39 AM   #5
ic-racer
HiSky HCP60, Trex-100, Trex-150, Trex-250, Trex-450L, Trex-550X
ic-racer is offline        Reply With Quote
