Go Back   HeliFreak > R/C Helicopters > Zeal Rotor Blades
Zeal Rotor Blades Zeal Rotor Blades Support and Discussion
Old 08-19-2016, 07:20 PM   #1
Bm421
Default What do y'all think internal damage?
Trying to get some input I've been inspecting my blade after reading all of this and one of my 600mm blades has an odd mark at the the have never been nicked crashed abused and flown around 1500-1600 lhs setupClick image for larger version
Bm421 is offline        Reply With Quote
Old 08-19-2016, 07:23 PM   #2
jverhaeren
Not seeing what your looking at
I like this flying stuff.
Blade 180CFX, Blade 230S, Blade 600X, Trex 600E, Diabolo 700 LHS, Goblin 770C
jverhaeren is offline        Reply With Quote
Old 08-19-2016, 07:37 PM   #3
Bm421
At the edge of the top blade it has what almost looks like scuff but it isn't goes from front edge then cuts up toward the tip at the rear
Old 08-19-2016, 07:58 PM   #4
jverhaeren
Ah, I see what your looking at, I cant tell. I would think it to be a polish mark. Go with your gut.
Old 08-21-2016, 11:23 AM   #5
vtown nick
Looks like a clear issue, the ones that failed the most were the 690 energy's really.
TmkaRc1Hobby Team Support
Team MSH USA -
Cyclone Blades
MSH Prtos 380 Brain 2
vtown nick is offline        Reply With Quote
Old 08-21-2016, 12:32 PM   #6
Bm421
It seems to be surface but it's like it follows a exact path... This old girl has never been crashed, the worst that's happened to her is a rough ride in Bertha (suburban) and scratch the canopy
Old 08-23-2016, 09:26 AM   #7
Seasick78
Not correct. There have been failures of various sizes etc. the main thing to look for is delamination on the trailing edge. Any pin holes or voids in the trailing edge and they should be discarded. The seam should not have ANY holes or slices/voids or you will be susceptible to a delam.
You can also hold the root and tip of the blades and impose a twisting force on them to see if the blades hold up to the strain. The forces on those blades in flight is much greater than you will produce by twisting with your hands.
Team - "Self Interests" -
Seasick78 is offline        Reply With Quote
Old 08-26-2016, 06:59 PM   #8
Bm421
They survived the twist test and have flown the since. But I have a pair of rails I just painted to match the bird. The zeals will become back up blades. Click image for larger version
ID:	668445 cg and weight matched and ready to go on.
Old 09-10-2016, 08:58 AM   #9
nabl74
How did you paint your rails?
Trex 500l Dominator-HW100A Pro / i2rc tail blade holders / Gpro
Trex 600l dominator- BRAIN / edge 80 / 750MX
E7se 700 - BRAIN / edge 120 / gryphon bec/ 800MX / 815 &855 cyclics and tail/ halo 700s
nabl74 is offline        Reply With Quote
Old 09-10-2016, 11:04 AM   #10
Bm421
Airbrush, scale, tape and time. Taped and 800 sand paper where I wanted the paint. Cleaned with alchole. Weighed the paint Counted my strokes and tried to stay the same speed throughout. Balanced and cg stayed very good at the end but I was going to use more paint to get them to Match if they didn't.
Old 09-10-2016, 12:01 PM   #11
UCPharmD
Those rails look very good. Great job on em.
My airbrush skills are lacking far behind yours lol.
Goblin 380 / 500 / 700C / 700KSE / ZMR250/ QAV180/ VAS Banshee/ VAS Wraith Micro/ MSH Brain FBLs/ HW ESCs/ XNOVA Motors/ Jeti DS-14
UCPharmD is offline        Reply With Quote
Old 09-10-2016, 02:17 PM   #12
Bm421
Thank you! I'm sure you could do if you have the basics of air brushing. I'm no wizard with one. Main thing is don't rush a paint job.
