Go Back   HeliFreak > R/C Helicopters > Low Head Speed Helicopters
Low Head Speed Helicopters Low Head Speed Helicopter Setups and Flying info
Old 09-28-2016, 05:24 PM   #1
johncclayton
Default 780 Align blades on MSH Protos V2 - Spirit FBL
Hi All,
Anyone flying 780 align's or similar (e.g. 766 rails) on Protos V2 with Spirit FBL?
Just curious ... I moved from 710 Switches (love those!) at 1950 RPM to Align 780's at 1400 RPM for kicks and to try something different.
Not bad at all - but not very "locked in" right now. I have to be careful with collective of course, elevator wobble is present and I can get the tail to deviate from its heading hold position on full deflection of the cyclic - e.g punch out / rainbow @ full noise.
I'd appreciate knowing if anyone else is running the Spirit - maybe we can swap rough guidelines for setup.
Cheers - keep those blades AWAY from mother earth!
Goblin 570, Protos Max V2's - Brain 2 / Spirit FBL goodness on each, with Jeti DS-14 telling it all what to do...
And remember - If it ain't broke, you need to tinker with it.
johncclayton is offline        Reply With Quote
Old 09-28-2016, 05:58 PM   #2
OnTheSnap
Mine is Brain, but I fly at 1350 for 9 minutes and it's incredible. Same blades.
MSH USA
Xnova
Xpert
OnTheSnap is online now        Reply With Quote
Old 09-29-2016, 02:38 AM   #3
johncclayton
Yup - makes sense. Before I did the Protos V2 I had a Synergy E7SE on a similar setup - 10 minutes no problem at lower head speeds, I also flew that on 6S quite a bit - very different experience (in fact I recall I maidened it on 6s - lol).
The Synergy E7SE now sits on the wall - its internals were ripped out to put into a Protos Max V2 - as somehow the E7 didn't grab me and make we want to fly it.
Old 09-29-2016, 06:30 PM   #4
KSKen
Are you using the Spirit for gov?
MSH Protos Evoluzione 800- MSH Protos Evoluzione 770
MSH Protos Max V2 700
Xnova XTS, Brain 2, Xpert, DX9
MSH Protos 500
KSKen is offline        Reply With Quote
Old 09-30-2016, 03:16 AM   #5
johncclayton
Nope. I've seen too many people having problems with that. I'm experimenting with Brain 2 now that it has Jeti and rescue.
