Go Back   HeliFreak > R/C Helicopters > Low Head Speed Helicopters
Low Head Speed Helicopters Low Head Speed Helicopter Setups and Flying info
Old 10-10-2016, 11:57 AM   #1
Koopyetz
Default 450 with 2s lipo
Upon the suggestion of others I have just started using 2s lipo for my 450. Using TC @ 98 as a start did a brief hover . Tail authority is good. I have upsized tail blades when necessary. Will be experimenting with different TC and slowly increasing flying time to see how she reacts. Thanks to Nikki5 and others for their help.
Koopyetz is offline        Reply With Quote
Old 10-10-2016, 03:23 PM   #2
Magnumeng
Look forward to how this turn out.... what size blades are you running?
Chad
TDR, Kosmik Cool 200, Pyro 750-56, Futaba HV, Futaba CGY750
Team KBDD
Magnumeng is offline        Reply With Quote
Old 10-10-2016, 04:32 PM   #3
Koopyetz
The blades are 325's that came with kit. Will see what she can do .
Old 10-14-2016, 04:41 PM   #4
Koopyetz
First day of multiple hovers using 2s lipo with 450 .
Did 3 - 1 minute hovers today . Full pack read 8.36 at beginning and ended with lipo reading of 7.92. Head speed reading using helitach at beginning was 2117 and 2058 at end. No tail wagging or bobbing. Will start to do continuous flight to see how many seconds I can get past 3 minute mark for TC as it is now and then lower TC and start again.
Old 10-19-2016, 03:19 PM   #5
Koopyetz
Currently at TC 0, 65,65,65,65. Flew two 1min 30 sec flights hover and ff. Full pack reading 8.36v ended at 8.00v. Motor slightly warm. HS unknown. Could not get reading from helitach. No tail wagging or bobbing.
Old 10-25-2016, 02:35 PM   #6
Turbojoe
Subscribed. I may have to pick up some 2S packs to try out just for grins. I've been playing with a Blade 180CFX on 2S and it works great. Dropping from 3S to 2S really helps tame that wicked little beast!
Joe
(1) EXI 500 GT, (5) Beam 450's, (3) Align 450's, (1)180CFX, (3) MCPX, (1) MCPX BL,(2) MCX2, (1) MSRX, (1) NCPS. All these helis and I can't fly ANY of them worth a damn!
Turbojoe is offline        Reply With Quote
Old 10-25-2016, 02:57 PM   #7
learnedthehardway
Interesting. So this is to tame it down instead of just running a lower TC on 3s plus dual rates??
Imagine 2s will tame it way down like a gearing change+lower TC+dual rates???
Interested to see what kind of performance and flight time you get. Tried 3s in my 6s 450 to see if I could get some long low hs flights but it could barely lift off the ground. ..lol
Thought about trying 4s but just ran a low TC since my esc has active freewheeling and learned that I don't like low hs anyway but always find new experiments interesting.
Once in a while you find something everyone says will never work that ends up working great
x2 Mini Protos 6s stretch-SK540/KDS Chase 360-SK540/180cfx/UMX Pitts
I'm a rocker, I'm a roller, I'm a right out of controller, I'm a wheeler, I'm a dealer, I'm a wicked woman stealer, I'm a boozer, I'm a user....I'm a rock and rollin man...
learnedthehardway is offline        Reply With Quote
Old 10-25-2016, 07:11 PM   #8
Turbojoe
The 180CFX has been a relatively easy 2S conversion for me. On the 450 it may or may not be as easy. I don't know yet. Only dropping the TC using 3S means something has to absorb the heat from running at part throttle all the time and that will be the ESC. Also you'll never find a pinion small enough to be able to run the 3S motor efficiently at 2S RPM using a 3S pack. I've cooked a few ESC's trying this. I always learn the hard way.
I've got a pile of Align and clone 450's that I was going to get rid of. They could now become 2S test mules as I don't care if they crash and I have a mess of parts for them. If it all works out I may convert some of my beloved Beam 450's to 2S. Due to my thumb physical limitations high performance and 3D are the LAST thing I'm concerned about. 2S sounds real good to me.
Joe
Old 10-26-2016, 12:00 PM   #9
Wargamer
In my experience, it totally depends on the ESC. I routinely run the Oxy+/Eox on 4s at an FBL-governed HS that is equivalent to 40% throttle. I took it down to 35% quite a few times during initial testing. The HW50A (v3 so no AFW) does not even get warm. Absolutely no issues. Flight times are also on par with what folks get with theoretically more efficient set-ups.
Compass Atom 5.5 - Oxy 3+
Blade 230S - nano CPS - XK K110/K120
Wargamer is online now        Reply With Quote
Old 10-26-2016, 01:48 PM   #10
Koopyetz
Very interesting information you posted. Wonder if my statement on stopping at 60% TC might be re-evaluated . With my plans not to push helicopter might be able to lower TC . Did 4 minute flight today. Motor slightly warm and nothing significant on ESC.
Old 10-29-2016, 04:13 AM   #11
Kap'n Krunch
Funny subject I've gotten 7 minutes (before the low voltage took over yes over discharged) on a 6 s setup with low throttle curve and flying smooth 3D but can get 5 minutes easy
Kap'n Krunch is offline        Reply With Quote
Old 10-29-2016, 04:29 AM   #12
Grumpy_Old_Man
^^Similar to my experience.
Personally I'm sure what the objective of all this low cell count / very low headspeed stuff is? Is the idea just to hover for the maximum time possible?.. Sounds extremely boring if so.
If all you want to do is hover for ages connect a long wire to the heli and a big old RV battery on the ground... you could hover all day.
KDS Agile 7.2 | Goblin 770 Carb. Comp | Goblin 630 Comp | Trex 600Pro (626 stretch) | Kasama Dune 600 | Compass 7HV U | Trex 700X | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 10-29-2016, 02:47 PM   #13
trillian
Joe
I have two Beam 450s, one flybarred and one FBL and they both need to run pretty much flat-out for any aerobatic flying. (both are 3s and I think the headspeed is around 3000 and it just seems to require that kind of hs for them to work properly for me)
When I was flying a Trex 450 I used to get about 8 minutes of gentle circuits just by running a lower throttle curve on 3s.
2009 TDR, Compass Knight 3D, Kasama Dune and Faifa
Robbe Futura SE and Dyna-X, Minicopter Triabolo 700, RMJ Raptor gasser
Beam E4 and Avantgarde, JR E8 leggero, Suzi Laos
trillian is offline        Reply With Quote
