Go Back   HeliFreak > R/C Helicopters > Low Head Speed Helicopters
Low Head Speed Helicopters Low Head Speed Helicopter Setups and Flying info
Old 11-02-2016, 10:45 PM   #1
technut
Default LHS HEAD SHAKE
My Trex 700 e flybar shakes at LHS. Is this because of hard head dampners or mains being too tight. Doesn't shake at higher speeds. I know someone has the answer!
technut is online now        Reply With Quote
Old 11-03-2016, 06:36 AM   #2
trillian
It can sometimes be due to the blades being tight. It can also be the swash gain in your FBL unit. I have had the occasional wobble in a hover and cured it by lowering the gain a bit.
2009 TDR, Compass Knight 3D, Kasama Dune and Faifa
Robbe Futura SE and Dyna-X, Minicopter Triabolo 700, RMJ Raptor gasser
Beam E4 and Avantgarde, JR E8 leggero, Suzi Laos
trillian is offline        Reply With Quote
Old 11-05-2016, 06:10 PM   #3
im4711
I noticed that hard dampers do not do to well for low rpm. So maybe you want to play with softer dampers.
also -> for the blades run it initial spool up a bit higher so they straighten out and than go to the low rpm. If blades are to loose you can easy run into issues where under harder collective input they fold back and ... boooooom
I have been there already.
Kontronik, Switch Blades, Bavarian Demon, HD-Helicopters, TDR, Diabolo, HeliBaby, Takumi and Banshee
im4711 is offline        Reply With Quote
Old 11-05-2016, 10:01 PM   #4
Dennis P
Being that you are flybarred I would guess that they may be to hard but I have also found if they are not greased up well this can happen. I really try and have them lubed up well for lower headspeed stuff and it helps a lot .
Team Renegade R/C Heli Flyers
Dennis P is offline        Reply With Quote
Old 11-09-2016, 05:20 PM   #5
technut
TY for all the suggestions. I'm installing the red dampners and recheck everything else. Will let yall know results
Old 11-14-2016, 10:47 PM   #6
technut
Greased up red dampners and installed. Checked main blade tightness and flew her. No more head shake. TY to all who helped!!!
