Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-07-2016, 07:03 AM   #1
TR450ZS
Default New TT front drive gear set
New on the align store, still with same number of teeth so no improvement in drive ratio, but as per spec : "Utilizes newly developed, highest spec and superior anti-wear material to increase the overall strength and durability for torque tube drive gear. Effectively minimize gear striping and crash damage."
This is the 0.8mod gear, they also have a new red 0.6mod gear for the older ESP version.
Name:	600 pro red gears.jpg
ID:	679209   Click image for larger version
Name:	600 pro red gears pack.jpg
Allan
TR450ZS is offline        Reply With Quote
Old 11-07-2016, 09:17 AM   #2
Number
They should have gone mod 1 and 4.5:1 or so :/
Disappointed to be honest. I don't fly 2400rpm on a 600, I need higher than 3.85....
Number is offline        Reply With Quote
Old 11-07-2016, 09:41 AM   #3
TR450ZS
Yeah I'm with you. All we can do is hope that Align have a 600X on the way. They have come up with some nifty things lately......imagine a full set of adjustable turnbuckles for the new 470L. So let's hope someone has switched the lights on in their offices and is doing some thinking.
Allan
Old 11-07-2016, 10:16 AM   #4
Number
Hell, I only flew 2350 on my 550... lol
Old 11-07-2016, 02:07 PM   #5
Heli.Maniac
That's just a big disappointment...
Andreas (formerly known as anmatheextreme)
Compass 7HVU
Logo 600SX CF
Blade 450X
Heli.Maniac is offline        Reply With Quote
Old 11-07-2016, 04:48 PM   #6
Gtamas90
For thoose who dont fly high hs, there is a 3 blade tail. Or longer blades. 3,85 ratio is ok i think. Of course they shod have a higher ratio option too. But a 550 or 600 for 3d comes alive at 2300-2500 rpm. And max tail speed allowed vy the blades is 10.000 rpm, so....
Protos Max v2 Spirit Pro, MKS X8, Edge 160A, 800MX
T-rex 550X Dominator stock, with Spirit Pro
450L Dominator 6S Spirit (red), TGY-306HV, YEP 90A
JETI DS-16
Gtamas90 is offline        Reply With Quote
Old 11-07-2016, 04:50 PM   #7
Number
2500 on a 600????
I flew my 6HVU at 2250 and it did everything I could ask for and I don't just do mild 3D...
Old 11-07-2016, 04:53 PM   #8
Gtamas90
Ok, for 600 its maybe the top, but for 550, it is very good speed. I dont have a 600, but my friend used to run 2400-2500 on snyergy e6. It was a screamer.
My 550X will arrive tomorrow, so soon i will try 2500-2700 rpm
Btw 2600 on 550 is the same blade tip speed that a 700 heli has at 2050. And 2050 is considered as normal speed on 700 machines.
JETI DS-16
Old 11-07-2016, 05:22 PM   #9
Number
Tip speed is literally 0% relevant to how a helicopter performs lol
Old 11-07-2016, 05:24 PM   #10
Gtamas90
Why do you think that?
JETI DS-16
Old 11-07-2016, 05:28 PM   #11
Number
Because we fly from lift, not tip speed...
Old 11-07-2016, 05:32 PM   #12
Number
Maybe not 0% but if you're looking at tip speed alone you're doing something wrong
Old 11-08-2016, 05:15 AM   #13
Gtamas90
I am not looking only tipspeed, but at least it is a comparable numer.
i will try to find more or less the same feel, then see if it was comparable
JETI DS-16
Old 11-08-2016, 08:10 AM   #14
Grumpy_Old_Man
No, tip speed shouldn't be the same as the heli scales up or down. For example if that were the case and taking 2050RPM as a 'norm' for a 700 then a 450 (325mm blades) would run 4500RPM.. and a Blade 180 would run 8000RPM!
The reason tip speed doesn't remain the same is because weight scales to the cube of linear scale but disk area scales to the square. Therefore larger helis (all other things being equal) have higher disc loading and so need higher blade velocity to make more lift per unit disc area.
Allowing for this difference 2600RPM on a 550 would equate to more like 2300RPM on a 700... which would be pretty high.
KDS Agile 7.2 | Goblin 770 Carb. Comp | Goblin 630 Comp | Trex 600Pro (626 stretch) | Kasama Dune 600 | Compass 7HV U | Trex 700X | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 11-09-2016, 07:22 AM   #15
Gtamas90
OK, i see, thanks for makeing it clear
I'm halway trough the building of the 550X, hopefully i can do the maiden at the weekend if the weather allows it.
JETI DS-16
Old 11-11-2016, 03:48 PM   #16
satgod
I went with slightly longer tail blades
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote
Old 11-11-2016, 03:53 PM   #17
Number
I'd rather stick to shorter cheaper blades that stay out of the ground
Old 11-11-2016, 04:49 PM   #18
Grumpy_Old_Man
Without doing a stretch you are very limited in how much bigger you can safely go on tailblades. 105mm isn't safe, there are documented cases of blade clash, about 100mm is the maximum which is only a 5mm increase over stock.
Old 11-11-2016, 05:57 PM   #19
cobieg
+1 on the stretch. Chop 100mm off a 700 boom and tt, do the 600 nitro auto gear and front tt gear. Put a set of 640 Zeals on it and 95 mm tails then rock and roll!
I didn't crash. I just ran out of airspeed, altitude, and idea's all at the same time.
cobieg is offline        Reply With Quote
Old 11-11-2016, 11:32 PM   #20
TR450ZS
Is the nitro auto gear and front TT gear mod a direct drop in or do you need to slot the frame holes?
Allan
