Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-12-2016, 07:14 AM   #21
cobieg
Originally Posted by TR450ZS View Post
Is the nitro auto gear and front TT gear mod a direct drop in or do you need to slot the frame holes?
Slot the frame holes. A little round file does the trick. You can do it the KDE way, they send a drill bit and a c&c bling piece for the outside of the frame.
I prefer to use the file, it is much easier to control and washers on the outside painted flat black. Once the gear mesh is set, it will fly sweet. I fly my stretched ones at 17&1900 rpm on the head.
I didn't crash. I just ran out of airspeed, altitude, and idea's all at the same time.
cobieg is offline        Reply With Quote
Old 11-12-2016, 07:30 AM   #22
TR450ZS
Ok thanks cobieg.
Allan
TR450ZS is offline        Reply With Quote
Old 11-12-2016, 08:25 AM   #23
Grumpy_Old_Man
Or if you are doing a stretch anyway just allow for larger tail blades. 105mm blades make a huge difference.
KDS Agile 7.2 | Goblin 770 Carb. Comp | Goblin 630 Comp | Trex 600Pro (626 stretch) | Kasama Dune 600 | Compass 7HV U | Trex 700X | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 11-12-2016, 10:50 AM   #24
Number
4.5:1. Not sure if you need to slot the frame or not.
http://www.aligntrexstore.com/M06-To...AX_p_4648.html
"must with H60020AA":
http://www.aligntrexstore.com/180T-M...A-_p_2584.html
Number is online now        Reply With Quote
Old 11-12-2016, 02:39 PM   #25
cobieg
To get the correct gear lash, yes.
Old 11-12-2016, 02:46 PM   #26
cobieg
Yeah, that works too. I ran 105's on it when it was a stock 600. The tail blades would take out front tt gears from the grass cutting. I went with the Auto gear mod and 95mm tails, no more blow out or stripped gears.
Old 11-12-2016, 03:48 PM   #27
Heli.Maniac
The solution to the 105s and ground clearance is to get the 700E skid (the stock one is the F3C version) and replace the stock rear one only. That will raise the tail quite a bit and prevent some of the gear stripping when landing.
Andreas (formerly known as anmatheextreme)
Compass 7HVU
Logo 600SX CF
Blade 450X
Heli.Maniac is offline        Reply With Quote
Old 11-12-2016, 04:03 PM   #28
Island Heli
Or buy this set....
http://shop.align.com.tw/product_inf...oducts_id=5824
I Am Spartan V4 Thrice +1.....TT Raptor E820....E755.......Synergy E7SE........Align 600E Pro .....neXt
Island Heli is offline        Reply With Quote
Old 11-12-2016, 04:09 PM   #29
cobieg
I actually put the old style nitro skids on mine. I re-enforced the back side with 1/8" piano wire. It stands up off the ground good and has some spring on not so smooth landings.
Old 11-12-2016, 04:19 PM   #30
Number
Originally Posted by Island Heli View Post
Yup, love them on my 700n
Old 11-12-2016, 08:06 PM   #31
cobieg
Niiiiice!
Old 11-23-2016, 12:04 PM   #32
BigEddie
Getting back on topic> Has anyone used the Red 34t front gears on the 600EFL and if so how are they holding up?
Align 600 EFL Pro/ Ikon ,700Goblin Comp/ Ikon, Protos Max V2/ Brain2 and HK K110 Blast all with Futaba 18SZH!
BigEddie is online now        Reply With Quote
