Old 11-16-2016, 06:34 PM   #1
rodneymueller
Default bought used tsa 600 n new to nitro helys
i bought a used tsa 600n on here its in grate shape bought a bad os50 moter and fixed it and i have 3 new spectrom servos on swash need to know what servos to use on tail and the os 50 carb
rodneymueller is offline        Reply With Quote
Old 11-17-2016, 07:12 AM   #2
meowguy
Assuming you are running a low voltage setup (5 to 6 volts), an Align DS-650 would be a good choice. Which Spektrum servos are you using on cyclic?
meowguy is offline        Reply With Quote
Old 11-17-2016, 10:29 PM   #3
rodneymueller
im using align 5.1 stepdown regulater the swash servos are spetrumh6200hv
Old 11-18-2016, 06:02 AM   #4
meowguy
In that case I would go with the Spektrum 6210 HV tail servo. That way you can upgrade to a full high voltage setup in the future. On average HV servos running at 7-8 volts are 25% more powerful and faster than when running at low voltage.
Old 11-18-2016, 11:42 AM   #5
jiminator
I just bought one of these to try as a throttle servo on my Fury 55
http://www.audacitymodels.com/Produc...3/Default.aspx
jiminator is offline        Reply With Quote
Old 11-19-2016, 07:59 AM   #6
meowguy
The Spektrum 6210 claims to be almost twice as fast. I would put the Spektrum on throttle and tail. However I am just not in the mood to spend over $500 to outfit my 700 with them just yet. My first step was to replace the AR7200 with an iKon2 controller.
