Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 01-04-2017, 03:30 AM   #41
cm930
Originally Posted by nightofcarnage View Post
Any one have tips on measuring +/- 10 on collective pitch. Only thing that pop to my head is using the blade length, distance between blades facing in same direction and distance from the ground to each blade and do some trigonometry. I should be able to figure out each blades angle and come up with a table. Anyone else have any other ideas.
There is an app called RC-Heli-Pitch for Android in Google Play store.
It uses your tablet/phone camera to take a picture at maximum pitch, with the blades folded 90 degrees, like a scissor, and will calculate the angle for you, after your set the blade length (120 mm).
cm930 is offline        Reply With Quote
Old 01-04-2017, 11:38 PM   #42
nightofcarnage
Thanks, but the math is so easy
D1 = distance for blade 1 to table
D2 = distance for balde 2 to table
BL = Blade length is actual 123 mm
A = ABS((D1 - D2)/2)
angle = arcsin(A/BL)
so to get 10 deg you need a distance for 42.7174 mm between the blades.
Its a easy calculation
Here is a quick dirty table
| angle | distance in mm (A) |
|0|0|
|0.5|2.1467277326|
|1|4.2932919835717|
|1.5|6.4395292837368|
|2|8.5852761888152|
|2.5|10.730369291873|
|3|12.874645235764|
|3.5|15.017940725575|
|4|17.160092541055|
|4.5|19.30093754905|
|5|21.440312715924|
|5.5|23.578055119975|
|6|25.714001963843|
|6.5|27.847990586905|
|7|29.979858477666|
|7.5|32.109443286133|
|8|34.236582836176|
|8.5|36.361115137884|
|9|38.482878399897|
|9.5|40.601711041727|
|10|42.717451706065|
|10.5|44.829939271068|
|11|46.93901286263|
|11.5|49.044511866631|
|12|51.146275941169|
|12.5|53.244145028773|
|13|55.337959368591|
|13.5|57.427559508553|
|14|59.512786317518|
|14.5|61.593480997393|
|15|63.66948509522|
nightofcarnage is offline        Reply With Quote
