Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-02-2016, 10:14 AM   #1
jujiro85
Default Trex 150x forward drift
Hi Just got the trex 150x up and running after a day or two trying to get it to bind to my old dx7 with a dsm2 receiver .
Now only issue I have is that it drifts forward at all times and i have to correct it ( hold the stick back) 100 percent of the time it's in the air. Was wondering if that was because of the receiver weighing down the front or something else setup wrong .
jujiro85 is offline        Reply With Quote
Old 12-02-2016, 10:09 PM   #2
prairie ville
Do a gyro reset. Level ground powered up heli(not running) and radio. Pull elevator stick all the way down for at least 3 seconds, blue light should flash faster and when finished, blue light will go back to normal.
DX8, Phoenix R/C 5.5 ,Hyperion 720i DUO w/ MW 600 PS, Walkera 4G#6S,Trex 250 se, mCPXv1, mSRX, mSR, Trex 150X, Blade SR
Quote: " If you want someones opinion, make sure their paycheck doesnt depend on it"
prairie ville is offline        Reply With Quote
Old 12-02-2016, 11:35 PM   #3
starryalley
Also make sure you do this gyro calibration every time after you crash. I found it will start drifting again after a hard crash (well I crashed more than 5 times hard..)
starryalley is online now        Reply With Quote
Old 12-26-2016, 06:45 PM   #4
gromitvt10
I have the same problem, drifting forward. I've tried the gyro reset 4 times, still no luck. How did you fix yours? My swashplate level.
JAM-STRIKE-WIN!!
gromitvt10 is offline        Reply With Quote
Old 12-26-2016, 11:59 PM   #5
cm930
If gyro calibration does not fix it, I think the next step is to adjust the accelerometer subtrim using the 150 GRS app.
cm930 is offline        Reply With Quote
Old 12-27-2016, 01:13 AM   #6
bredler
Put a trash can in front of it and just let it drift right in there where it belongs
RCHN #825
Blade 550x, Blade 360 cfx, Blade 180 cfx
bredler is online now        Reply With Quote
Old 12-27-2016, 09:56 AM   #7
krauley
Cant, its full of blade helis and has no more room!
UH-60 EXI 500 DFC/3GX v5.0 ICE 75 Bec Pro w/4 blade main & tail rotors
Align trex 500DFC Pro w/AR7210bx Align trex 150X
Oxy 3 Tareq Edition AR7210bx Edge lite 50 Kst 215's
PL6 w/Bump Controller-24v PS DX8 gen2
krauley is offline        Reply With Quote
