Go Back   HeliFreak > R/C Helicopters > Cyclone Blades - 715, 695, 615, 555, 505
Cyclone Blades - 715, 695, 615, 555, 505 Factory Support and Discussion Forum
Old 12-12-2016, 12:51 AM   #1
em3jefferson
Default To much pitch with cyclones?
hey guys i'm using 695's on my x7. would a high degree of pitch say 13-13.5 on these cause bogging/rpm drop? the reason I ask is because seems like I read somewhere or heard someone say that with the way these are designed that they don't require high degrees of pitch? any thoughts?
Majority response is not a test of validity.
em3jefferson is offline        Reply With Quote
Old 12-20-2016, 07:48 AM   #2
Baedarlboo
Yes, drop the pitch and cyclic.
Baedarlboo is offline        Reply With Quote
Old 12-23-2016, 08:32 AM   #3
LoveToFly1
a HIGH degree of collective pitch is more like 15-16. I think cyclones will be fine with good packs at 13.5.
Gasser Mike
Team Synergy, Team KDE Direct, Rail Blades, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote
Old 12-23-2016, 08:50 AM   #4
fastflyer20
Check your setup, especially the batteries.
I run 13 degrees on a gasser with Cyclone 715's, an electric should easily pull more pitch.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote
