Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-27-2016, 07:40 PM   #1
GenericGuy
Default Trex 150X Configuration Lost
Hello,
I have a new Align Trex 150X. After configuring and saving via APP, the Trex150X does not respond to the transmitter.
I performed the following:
Upgraded 150 GRS firmware to version 1.1.1
Reconnect battery and bind Spectrum DX6i transmitter to Spectrum DSMX satellite (solid light),
Calibrate stick travel including throttle,
Set parameter to beginner,
Save configuration setting on 150 GRS APP,
Save and confirm configuration on APP,
The Trex 150X moves the swash down-up-down, emits 2 beeps and responds to DX6i transmitter controls as expected (GRS 150 light is aqua flashing).
Here’s the problem: If I disconnect and reconnect the the Trex 150 X battery with the transmitter power on, the Trex 150X emits 3 beeps and GRS flashes red/blue. It does not respond to transmitter controls. The satellite LED is sold.
Work around: Launch the iPhone APP and connect to the Trex 150X via Bluetooth, then move the transmitter throttle stick save and disconnect the APP. The Trex 150X responds to the transmitter as expected.
What am I doing wrong? Is the Trex 150X defective?
Transmitter: Spektrum DX6i
Satellite Receiver: Spektrum 9645 DSMX
iPhone 6s running 150 GRS APP: 1.1
Firmware version: 150GRS_v1.1.1.grs
GenericGuy is offline        Reply With Quote
Old 12-28-2016, 09:50 PM   #2
cm930
Originally Posted by GenericGuy View Post
Hello,
Does this happen to firmware v1.0.2? Could you revert to v.1.0.2 and try?
When I upgraded from v1.0.2 to v.1.1.1, I also found that sometimes my configuration got lost:
1) One time the heli did not respond to the transmitter, and I found the configuration had changed to DSM2 sat instead of DSMX sat.
2) Heli responded really slowly to stick input. Found configuration had changed to beginner mode instead of expert mode.
So I changed back to v1.0.2 and both of the above problems disappeared.
cm930 is offline        Reply With Quote
Old 12-29-2016, 12:34 AM   #3
starryalley
I'm using DX6i with 150X.
Also try turning on throttle hold beginning at 10% in the throttle curve setting in DX6i. Try increasing or decreasing it a little bit once a time and see if 150X starts successfully. Mine should be at 11% or 150X won't start at all. This is on both V1.0.2 and V1.1.1 for me.
starryalley is offline        Reply With Quote
Old 12-31-2016, 01:22 PM   #4
GenericGuy
I rolled back to v1.0.2 and observed the same issue. Thanks for the suggestion.
Old 12-31-2016, 01:30 PM   #5
GenericGuy
I tested this solution by setting throttle hold between -10 and +15. Unfortunately the GRS150 failed to respond to the transmitter (flashing red-blue), the satellite receiver light was glowing solid.
Old 01-16-2017, 01:57 PM   #6
joanpeca
I'm having the same problem with FUTABA S-FHSS. First it gave up responding to rudder and aileron channel. Then I tried to rebind, and now I'm not able to bind to the transmitter again (flashing red-blue). Did you find any solution to this issue?
ALZRC TRex 450 Pro DFC
ALIGN TRex 500 ESP DFC
ALIGN TRex 600E PRO DFC (Power booster)
Goblin 500
joanpeca is offline        Reply With Quote
Old 01-16-2017, 09:13 PM   #7
GenericGuy
I contacted my retailer for support. After all attempts failed, the retailer agreed to replace the 150X. I just shipped the 150X to the retailer Saturday, 1/14/2017. It may take a couple weeks to get a replacement. I'll update HF concerning the replacement.
Old 01-17-2017, 06:12 AM   #8
joanpeca
I'm afraid I'll have to do the same. Succeeded in rebinding again but still no activity in aileron channel (rudder came to life again).
I'll keep you updated.
Goblin 500
