Old 12-16-2009, 10:52 PM   #1 (permalink)
Default Mega Power Gemini-2014 DUO 300W+300W
Bought from this shop http://www.heli-pro.com/product_info...roducts_id=967.
With two max 20A outputs which is 300W + 300W = 600W.
Any suggested power supply? Thanks.
Futaba 10C mode 3
T-REX 500 | 6616 flights
T-REX 700N | 158 flights
T-REX 700E | 217 flights
forth is offline        Reply With Quote Quick reply to this message
Old 12-16-2009, 11:42 PM   #2 (permalink)
Wow nice description first sentence.
"MEGA POWER GEMINI-2014 DUO is the world's most prominent Korean models used charger in the business design and production, the global 70 percent of models used charger are its factory production, including Germany, France, Britain, the United States, Japan, a line manufacturers are using such products quality and performance has been deeply the love users are certain that the product adopts double-the-designed two group terminal at the same time for two battery, and two battery without specifications, each group terminal may be the lithium polymer (Li-Poly 1-7 S), lithium-ion (Li-ion 1-7 S), lithium iron (Li-Fe 1-7 S) and nickel-cadmium (Ni-Cd 1 ~ 18 cell), nickel-hydrogen (Ni-MH 1 ~ 18 cell, lead accumulator batteries (Pb 2~24 V) and the most used batteries, whether for battery power, transmitters and receivers battery can a machine out single terminal with 20 A/300 W (total and power 600 W) super-strong charging power to make your charging more efficient."
- Chris
TJinTech heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote Quick reply to this message
Old 12-16-2009, 11:49 PM   #3 (permalink)
That's definitely machine translated LOL.
Futaba 10C mode 3
Old 12-19-2009, 01:44 PM   #4 (permalink)
Mega Power chargers are made by SJ ProPo in Korea as are others with the same features. You'll probably see this same charger under a few different labels this coming year.
RC Accessory is offline        Reply With Quote Quick reply to this message
Old 01-08-2010, 11:42 PM   #5 (permalink)
Midlands helicopters has a 600 watt power supply..
Goblin 770 4540 395 Sig 16S YGE 160UHV VBar (gov)
Goblin 700 4530 540 LE 12S Ice 2 160HV VBar (gov)
Brushless MCPX
Brett74 is offline        Reply With Quote Quick reply to this message
Old 01-09-2010, 01:02 AM   #6 (permalink)
http://www.rivergatedist.com/bulldog_45_amp.htm
600W, Baaaayybeee. The next step up is 750W, if you want to account for the expected inefficiencies.
Would anyone with the Mega Power charger be kind enough to write a review? The specs are far better than the "other," more expensive DUO.
"There's no such thing as gravity. The earth just sux"
T-Rex 250, Align FBL, T-Rex 250 DFC
500 ESP, RJX FBL
Skookum SK-720
airnoob is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 03:42 AM   #7 (permalink)
My problem with these chargers (including the new megapower duo) is that they do not appear to display the battery IR. I use that for keeping track of the status of the batteries. The hyperion chargers show that right after the charge so I will probably end up waiting for the hyperion DUO or get the new fmadirect 1000w charger.
StatiC is offline        Reply With Quote Quick reply to this message
Old 02-17-2010, 10:18 AM   #8 (permalink)
I am using the Gemini-2014 Duo charger for 6S batteries for Atom 500 . The charger do display the internal resistance during charging / discharging . I like the charger big display and show info. of both channels at the same time . The real 20A charging ports can charge the 2600mAh at around 22Min. ( 2C charging rate ) . I have four packs and cycle them for all day flying with no stopping .
TT_Felix is offline        Reply With Quote Quick reply to this message
Old 02-25-2010, 09:56 AM   #9 (permalink)
How is this charger after a few weeks of usage? Does it feel like a quality, durable charger? Spec wise it looks like a top notch charger, but one has too many surprises with the quality of products these days.
3Dmuse is offline        Reply With Quote Quick reply to this message
Old 07-15-2010, 03:02 PM   #10 (permalink)
Hi, I'd like to buy this charger... Have someone had any trouble with this??
mikiko is offline        Reply With Quote Quick reply to this message
Old 07-15-2010, 03:27 PM   #11 (permalink)
see http://www.rcgroups.com/forums/showt...ghlight=gemini
Old 07-01-2011, 01:25 PM   #12 (permalink)
Hi Guys...i just purchased tis charger..
how do i use BALANCE CHARGE?
normal i wl just move the cursor to under CHARGE. Select the amps then i will hold the enter button then hold the button again to charge..BUT i noticed
if one of the cell is at 4.20 it wl end the charging eventhough 5 other cells still at 4.18/4.19
just dun feel tat tis is balance charging...or i setup or press wrongly? pls adv
bennyooi is offline        Reply With Quote Quick reply to this message
