Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 02-17-2013, 05:57 PM   #1 (permalink)
Default MKS DS95 output shaft
Does anyone have any tips on how to remove the output shaft from a DS95 servo?
I stripped one yesterday.
The upper case half came off as normal, the bearing is still on the shaft. should I use a puller on the bearing? After that is is easy to get the shaft out?
Diabolo 550 Vbar NEO : Diabolo 600 Vbar NEO : Diabolo 700 Vbar NEO: OXY 5 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is offline        Reply With Quote Quick reply to this message
Old 02-19-2013, 02:26 PM   #2 (permalink)
it should just pop out. May need a tiny bit of force to seperate.
KBDD
MKS Servos
Scorpion Power Systems/Batteries
Spartan RC
John Cook is offline        Reply With Quote Quick reply to this message
Old 02-22-2013, 01:39 PM   #3 (permalink)
Yes it did after I pulled hard enough.
Man those things are tiny and fun to put back together.
thanks
Old 02-24-2013, 02:04 PM   #4 (permalink)
I did a vid on this at one point. I'll see if I can find it.
Cullen Colapietro is offline        Reply With Quote Quick reply to this message
Old 02-24-2013, 02:06 PM   #5 (permalink)
[ame]http://vimeo.com/31450703[/ame]
Old 03-23-2014, 02:14 PM   #6 (permalink)
I just changed mine out for the first time. The video was helpful - thank you. I decided to leave the bearing in the case (not the top bearing but the one at the bottom), mainly because I didn't know how to extract it. Please - how do you do so? I don't know what a bearing extractor is. Any tips? Thanks! (P.S. At $10 a pop, I'm curious why the shaft breaks. Isn't the point of titanium to not break? If it's a sacrificial part, then why use an exotic and expensive metal in the first place?)
matthewcornell is offline        Reply With Quote Quick reply to this message
Old 03-23-2014, 04:48 PM   #7 (permalink)
They break the shaft to make sure nothing else is damaged in the gear train. It can be a pain trying to find every last broken bit of gear in some servos, and if you miss a small piece it can cause a in flight failure.
I have found the lower bearing to come out with the shaft but if it gets stuck i would likely check its ok and just reuse it.
waxman is offline        Reply With Quote Quick reply to this message
Old 03-23-2014, 05:10 PM   #8 (permalink)
+1
The break away is a clean fuse.
A flying buddy had a nasty cyclic jerk when he reached a certain pitch, quite strong and scary indeed. When he checked the heli, one servo had a tiny bit of a plastic gear stuck in another gear. It may get stuck in the grease and come unnoticed.
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 03-23-2014, 07:19 PM   #9 (permalink)
Thanks, guys.
