Old 02-16-2008, 07:38 AM   #1 (permalink)
Default check out this video (brown out problem?) IT IS STATIC!
T500 Static Charge Vid (0 min 52 sec)
http://runryder.com/helicopter/t409185p1/
Here is a post by the person doing the test.
KandB is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 10:45 AM   #2 (permalink)
Yep, Did the same thing a few weeks back. STATIC!!!
https://www.helifreak.com/showthread.php?t=59035&page=4 POST 36
Eyefly is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 11:14 AM   #3 (permalink)
Team Taco VP
Yep... more proof static exists in the tail system.
Bob
Old 02-16-2008, 05:26 PM   #4 (permalink)
I use one of these devices daily. It picks up on an ac current (inductance)
For example , a carpenters skillsaw doesn't work yet the extension cord does. Put the tick (tradename) on the saw cord. If it beeps the neutral is broken , if it doesn't the black (hot) is broken.
Is this implying that the static charge is of an AC (alernating current) ? Someone have a 600n and a beeper ?
My understanding of a static charge is it builds up to a 'flash over' point when it jumps to a better source of ground. (path of least resistance). Kinda like a dc buildup ??
Feel free to correct me if i'm off here.
Keep in mind the 'brushless' motors as we call them in the hobby are the same as a 3phase ac motor (rotating magnetic field with a conductive core). It's been noted and makes sense that the frame may be amplifying the signals via the (ungrounded - floating) motor mount. With 360 polarity changes to be had per second it's no wonder that's going off.
A few things to consider (to get an effective reading from them). Mine has a shirt clip that makes the thing come on, sometimes a poor connection so i rub it up and down my shirt/sleeve to test it's on.
We don't rely on them very much. When were checking to see if a 3phase 1000a service is off (check before sticking hands in) we don't use on of these, we use a meter we trust (with our life).
They will also pick up inductance from another wire closeby. For example on a 3 wire (black/red/white/ground) the red could show it's hot when it's not, but the black one is and is inducing a voltage (usually about 11-25ish) volts.
I use it to verify when i think a wire is hot. or to see if power is present. Pinpointing is left to a meter.
My though is that your picking up on the esc (inverter) and or the motor. I'm not sure how clean the esc runs in terms of varying the frequency/voltage to the motor. I assume it's a basic form as a true variable frequency drive yeilds full hp of the motor at any rpm. The rc grade is best above 80% throttle.
Hopefully that has been helpfull.
I wonder though, if there is a way to get a meter hooked up and get some readings. Maby a lead at each end of the boom ?
My observation so far is that the belt is more likely to rub the boom holder than on a 600 sized. Call it a pulley diameter vs the boom diameter thing if that makes sense. 600n/e 's are dropping out of the sky like crazy. I have got a shock when i've touched my 600e after a flight though. A little silicone oil (truck shock oil) on the belt gets rid if that. But nothing so bad it locksout/brownouts on me.
Martin
rcmarty is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 07:34 PM   #5 (permalink)
Ok, I just did a video of the ESD with the AC Voltage tester. Two things I would like to note. First, I did use silicone on the belt and the main and reduction gears. Second, I have always wondered if the static may have been generated by the combination of the nylon reduction gear and the tail drive gear. you will see as soon as the video uploads, there is a higher signal right at the main gear. I have NOT done the grounding mod to the ESC, Stay tuned........
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep
Donut Connoisseur
HELI-FREAK, You couldn't have picked a better place to land !
ChasHeliCop is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 08:28 PM   #6 (permalink)
We just tested with a Fluke 196C. No images but here are the results. This is with the main blades off and spooling up at zero pitch.
Measurements on the CF Frame
Frame not grounded. 3.5 volts on the frame
Frame grounded at motor mount to ESC negative flatline on the frame.
Measurement on the tail boom
Frame not grounded. 2.3 volts generated at the boom
Frame grounded 2.3 volts generated at the boom
Frame / boom / tailshaft / front pulley all grounded was flatline
We did not spray the belt. I cannot say this was static, only that we got the 2.3 volts reading on the tail boom regardless of grounding frame or not. I also turned the rotor head by hand while measuring and without the blades on I could not get it spinning very fast but was able to reach 1 volt. Under conditions better for static build up I guess the readings on the tail could be higher.
Socal500 is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 08:49 PM   #7 (permalink)
maybe the material that the belt is made of has something to do with it also.....
is there another make/type of belt that can be used on the 500?
PTFlyer is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 09:03 PM   #8 (permalink)
Originally Posted by KandB View Post
This was a great vid. Can you repeat this with a TREX 450, and with the 500 after the belt has been lubed. I'd love to see that.
Also, can you pinpoint the "hot spots" to watch out for when locating electronics.
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 09:06 PM   #9 (permalink)
Ok, here's the video I just finished uploading......
Trex 500 ESD (3 min 5 sec)
Donut Connoisseur
Old 02-16-2008, 09:14 PM   #10 (permalink)
It's just a cool looking and flying Van de Graaff generator with the carbon fiber conducting the electricity.
Terry
MAAC#78357 IRCHA#3269
AlignT-Rex 450 SE V3 2221-8/ Align T-Rex 600N,OS55HZ /
Align T-Rex 600E 12S A123's / Align T-Rex 700N YS91SR/
Bergen Intrepid EB Zenoha 260/
terrybeb is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 09:32 PM   #11 (permalink)
http://www.youtube.com/watch?v=IJ4UFRLdclw
Very interesting vid. Is the belt lubed? Wonder what lubing the nylon gears would do?
Wonder if a 450 is similar.
Rick
Old 02-16-2008, 09:34 PM   #12 (permalink)
I did lube the belt and both gears with silicone....... the 450 video is coming, uploading now. Interesting results. Also I did NOT do the ESC ground mod !
Donut Connoisseur
Old 02-16-2008, 09:36 PM   #13 (permalink)
WOW, so even lubed the ESD is present. I wonder what it would look like with the grounding wires on people are using.
Old 02-16-2008, 09:37 PM   #14 (permalink)
It would be nice to have a meter that shows strength of the ESD for comparison purposes. The blinky blinky works pretty well though! Thanks for posting these!
Rick
Old 02-16-2008, 09:38 PM   #15 (permalink)
I am afraid to fly my 500 now! My problem is that align MUST have had the same problems while testing and didn't say anything or do anything to fix the problem!!! It just doesn't make sense that all of a sudden people are having static problems. It just kind of came out of the blue....
I'm back!!!!!!
Justin911 is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 09:39 PM   #16 (permalink)
Just hang tight, until you see the 450 video..... I think it will surprise you. I really do not feel the ground mod does anything except give the static discharge an easy route to follow. Path of least resistance, it doesn't solve the problem, but I have an idea that might.
Donut Connoisseur
Old 02-16-2008, 09:46 PM   #17 (permalink)
Can you take the belt off the front pulley and try it. Maybe the nylon gears are just conducting the ESD but not generating it.
Old 02-16-2008, 09:47 PM   #18 (permalink)
OK, I'm dying for the answer...drum roll ...
Old 02-16-2008, 09:50 PM   #19 (permalink)
Still uploading, but i think the anticipation is worth it. I have a slow upload speed, but i am not on dialup. i think the vid is 60mb..... the 500 was 120+ I know it's killing you, but just hang tight !
Donut Connoisseur
Old 02-16-2008, 09:50 PM   #20 (permalink)
LOL...hanging
