Like Tree89Likes
Old 08-15-2012, 01:05 AM   #2401 (permalink)
Still have to order batteries though.. Will be a while bedore i maiden. I'm still reading up on the vbar and the jive too. First time using those.
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6
-kenny- is offline        Reply With Quote Quick reply to this message
Old 08-23-2012, 11:14 PM   #2402 (permalink)
edited
Blink 182 is offline        Reply With Quote Quick reply to this message
Old 09-03-2012, 07:10 PM   #2403 (permalink)
Default 500SE Beauty Shots
I took a few photos of my 500SE under construction. It looks so clean and simple without the electronics. Maybe I should leave it that way... nah.
ID:	345971   Click image for larger version
ID:	345972   Click image for larger version
ID:	345973   Click image for larger version
dswitkin is offline        Reply With Quote Quick reply to this message
Old 09-04-2012, 03:55 PM   #2404 (permalink)
Lightbulb
This is photo Logo 800 XXTERME by my friend Tim Procter and my treatment photo:
For you 16:9 monitor!
In full size: http://heli-spb.ru/images/Logo_800_X..._2560x1440.jpg
Aleksey Nezdayminov is offline        Reply With Quote Quick reply to this message
Old 09-06-2012, 10:39 AM   #2405 (permalink)
Thumbs up Logo 600 3d
Here's mine at the park.
Name:	Fly Boy 076.jpg
ID:	346709   Click image for larger version
Name:	Fly Boy 099.jpg
No changes are permanent but...change is.
badastinner is offline        Reply With Quote Quick reply to this message
Old 09-09-2012, 05:35 AM   #2406 (permalink)
Here's my logo lookin' good at the field today. I,ve added some extra vents in the canopy because the motor runs real hot.
Old 09-09-2012, 06:58 AM   #2407 (permalink)
What motor you using then?
Yes I miss the odd screw, so what
Trex 700N Vbar, Mikado LOGO 600SX, Trex 450 SportV2, Trex 250se-dfc, MCPX ...DX8...
kiwianaBrad is offline        Reply With Quote Quick reply to this message
Old 09-09-2012, 02:05 PM   #2408 (permalink)
Scorpion 4035 - 500kv
Can't touch it for more than 3 seconds after a 5 minute, 2180rpm flight. It has been hot out everytime i've flown it though... First flights were at 2000 rpm, temperature was way lower then.
Old 09-10-2012, 03:03 AM   #2409 (permalink)
Finally a friend with a decent camera
600 SE Carbon framed.
Pyro + Scorp 130 @ 12S
4000mAh GensAce x 2
Savox BLS HV servo set
full size Vbar
beat up canopy
ID:	347888   Click image for larger version
www.flyfreak.net - Croatian RC forum
wespen is offline        Reply With Quote Quick reply to this message
Old 09-10-2012, 09:32 AM   #2410 (permalink)
Sounds like gearing, or to much binding. What blades are you using ?
http://www.alignrccdn.com/
Mr.Gobler is offline        Reply With Quote Quick reply to this message
Old 09-10-2012, 11:03 AM   #2411 (permalink)
Oil those motor bearings every 6 flights.
Is the pinion getting hot? If so maybe the gear mesh is too tight.
maarset is offline        Reply With Quote Quick reply to this message
Old 09-10-2012, 01:22 PM   #2412 (permalink)
There is just a tiny amount of slop between the main gear and the pinion. I'll try loosening a bit more thanks.
Ok back on topic don't mean to hijack the thread
Old 09-10-2012, 01:34 PM   #2413 (permalink)
If you have a tiny bit of movement between main gear and pinion that is ok.
At the high point of the gear you should have pretty much zero slop.
Next time you fly see if the pinion is getting hot. In 90F and above weather I can't touch my scorpion for over a couple of seconds.
Old 09-10-2012, 01:53 PM   #2414 (permalink)
I'm pretty sure the mesh isn't bad.. The manual said to have NO slop between gear and pinion but i found that strange. I've made sure to have a tiny bit of slop.
It was around 25 degrees celsius over the past days.. I noticed a considerable temperature increase going from 2080 to 2180 headspeed though. At 2080 it wasn't nearly as hot.
Old 09-12-2012, 08:18 AM   #2415 (permalink)
HF MR Support
Back on thread topic - sort of....
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 09-13-2012, 12:02 PM   #2416 (permalink)
There's one heli that doesn't "belong"...
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 09-13-2012, 09:04 PM   #2417 (permalink)
My birds:
Logo 600 CF, V5.3pro,PowerJive120hv+Scorpion 4035-500kv HKIII, savox sc1257TG, bls251, 12s3300mAh, edge 623mm+95mm
Logo 400 miniV 5.3pro-gov,HW 80a Plat, Hyper. 3026 1400kv, ds510m, bls251.
corsac is offline        Reply With Quote Quick reply to this message
Old 09-15-2012, 11:35 PM   #2418 (permalink)
Originally Posted by martn1sw View Post
What kind of metal head is that? An RJX head?
Do you guys think running a metal head on 690's will allow you to run a headspeed of 2100?
Patric
RCFlyer88 is offline        Reply With Quote Quick reply to this message
Old 09-15-2012, 11:55 PM   #2419 (permalink)
Patric
Is definitely a Sexy head!
Seems a RJX to me....
Oxy2 - Oxy 3 -Oxy 4 - Oxy 4MAX - Oxy 5 MEG - Oxy 5HF - Nitroxy -Flash700
scoio is offline        Reply With Quote Quick reply to this message
Old 09-16-2012, 02:30 AM   #2420 (permalink)
Hellyeah It's a sexy head
But will the sexiness allow it to go past 1850 rpms?
Patric
