Old 01-23-2013, 02:14 PM   #21 (permalink)
Default Re: My PL6 & new HP PSU Setup
Originally Posted by Detritus View Post
I've no idea personally but I'll try it out when I'm allowed back in the workshop
Back from the 'shop, just to confirm: No, CC dongle won't work. BeastX will
Detritus is offline        Quick reply to this message
Old 01-24-2013, 11:26 AM   #22 (permalink)
Thanks, would it make sense to use a 2000 watt ps on a pl8
Sake is offline        Quick reply to this message
Old 01-24-2013, 12:20 PM   #23 (permalink)
Possibly, what voltage?
My server PSUs are 1400W I think, 2 in series (modified as necessary) giving about 25v. That's not enough to get the most out of the PL8 though, needs 32v input I think to extract the full output from it. Plenty enough for me though.
Old 01-24-2013, 12:45 PM   #24 (permalink)
I'm thinking on meanwell ps the rsp1500-24 , rsp2000-24 or rsp2000-48
2000 is probly overkill maybe in future put 2 pl8s on it
Old 01-24-2013, 01:03 PM   #25 (permalink)
how fast are you guys really trying to charge ?
http://www.alignrccdn.com/
Mr.Gobler is offline        Quick reply to this message
Old 01-24-2013, 01:22 PM   #26 (permalink)
As fast as possible for 6-5000mah
Old 01-24-2013, 01:29 PM   #27 (permalink)
Approaching 2C here, don't quite get there when the MPA board is fully loaded but close enough and I don't want to go faster.
2 PL8s 8-) There's always someone with a bigger charger..
Old 01-24-2013, 01:51 PM   #28 (permalink)
Default My PL6 & new HP PSU Setup
Originally Posted by itsparks View Post
no I don't. is it worth it? How much is it? I do have a dedicated laptop for my heli and field so...
Sent from my SGH-I747M using Tapatalk 2
Apart from ease of use, the software allows you to log the charge cycle. This, in turn, allows you to monitor the battery aging.
Avi_Y is offline        Quick reply to this message
Old 01-24-2013, 01:59 PM   #29 (permalink)
I just want to use one set of good batteries to fly so I can save $ on battery and many batteries have a high charge rate
Old 01-24-2013, 04:18 PM   #30 (permalink)
Hi Sake,
Play with the calculators at Revolectrix web site: http://www.revolectrix.com/pl8_calcu...PL8_Calc_1.htm
As you can see a 6s-5000 can be charged @ 38A calculated at only 85% efficiency. In reality the PL8 usually performs above 85%. I regularly charge 6s-5000 packs with my PL8 @ 40A. Usually takes less than 10 minutes to charge at this rate.
Jack
Jack Doherty
FMA Beta Tester
CoPilot II HD
PowerLab 8
jdd1 is offline        Quick reply to this message
Old 01-24-2013, 06:35 PM   #31 (permalink)
Originally Posted by jdd1 View Post
Hi Sake,
Jack
10min to charge a 6s5000, is that a single or parallel ?
Old 01-25-2013, 12:41 AM   #32 (permalink)
my guess is 2 packs 10Amp hours that would be 4C at 40Amp
sounds right i tested my PL8 with 4 6S 3000mAh packs at 40amps and got ~14min to charger them
DX8
mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades
AMA#948801
Elios000 is offline        Quick reply to this message
Old 01-25-2013, 09:59 AM   #33 (permalink)
so each 1c is 5amps right ? so for me to do 4 5000 amp packs isn't that 20c ?
Not very good at parallel charging and setting the charge rates yet, hence why im asking
Old 01-25-2013, 10:47 AM   #34 (permalink)
4x 5000mAh packs would be 20amps for 1C rate or 40amps at 2C rate
each pack is 5amp hours and 1C charge would be 5 amps
2 packs 10amp hours and 1C charge would be 10amps
etc
DX8
AMA#948801
Old 01-25-2013, 10:52 AM   #35 (permalink)
1c for 5000mah bat is 5amp, 2c is 10amp, 8c is 40amp charge for 1 batt if you do more batts the amps are shared so 4 5000mah at 40 amp is 2c each batt
Old 01-25-2013, 10:53 AM   #36 (permalink)
is that good ?
Old 01-25-2013, 11:03 AM   #37 (permalink)
Shure it is most modern batterycan take 2c some do over 10c . Its all good less charge time means you only need 2 sets of batteries to keep flyin
Old 01-25-2013, 11:06 AM   #38 (permalink)
my goal is to have 3 x 12s 5000 packs. for flying
Old 01-25-2013, 11:43 AM   #39 (permalink)
you can do all 3 sets at 1.3C 40amps
just do one set at time at up to 4C up to 40 amps
your best plan is 1 set 2 packs at time at 40amps
that should take ~12min to 15 min to charge one set of packs ie one flights worth
figure 5min ish flights + loading / unloading and BSing with the guys should let you fly back to back with the 3 sets of back
at home you can charge all 3 sets at 40amps and have all your packs ready in under a hour
DX8
AMA#948801
