450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
01-09-2010, 07:05 AM | #1 (permalink) |
Crash Kit Advice for a Professional Crasher
Hi Guys,
Well I got this kit from Heliproz fantastic deal and have this $100 gift certificate to deal with. Due to my great ability at impacting the ground I thought maybe I should invest it in repair parts early, as they will certainly be needed. main shafts, feathering shafts, blades, booms etc. pretty much go without saying but are you guys seeing other stuff get torn up? I see a lot of posts about trashed servos so I'd better get a gross of them. Other than that though, any consistent items that you would include in a crash kit? Fly safe... t
"It's not the crash so much as the sudden stop" Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... Team Flybar Team Tail-In wannabe.... |
01-09-2010, 08:37 AM | #2 (permalink) |
Torque tubes
Front TT gear sets (you'll probably go through quite a few of these if you crash regularly) Head blocks are pretty soft as well and easily damaged.
.. ..-. -.-- --- ..- -.-. .- -. .-. . .- -.. - .... .. ... -.-- --- ..- .-. . .- .-.. .-.. -.-- -. . . -.. - --- --. . - .-.. .- .. -.. AMA#1058309 |
01-09-2010, 08:40 AM | #3 (permalink) |
Is that the shaft that drives the tail?
01-09-2010, 08:42 AM | #4 (permalink) |
Member
Add these to the list:
flybar tail rotor shaft landing gear (unless you're using Gorilla Gear)
01-09-2010, 08:45 AM | #5 (permalink) | |
Got me the Phoenix 2.5 on the way hopefully that will help me catch up with these guys....
01-09-2010, 09:23 AM | #6 (permalink) |
[QUOTE=Mon_t;1763072]Torque tubes
Front TT gear sets (you'll probably go through quite a few of these if you crash regularly) Head blocks are pretty soft as well and easily damaged.[/QUOTE I guess that means front torque tube gears.... You mean the ones in the frame? Thx... Tk
01-09-2010, 10:46 AM | #7 (permalink) |
If you want to lower your crash costs...
Invest in a sim.
Jerry Moore, AMA #878954,TARANIS OpenTX- Pantera 600 FB - Pantera .60 FB - Takes a licking and keeps on kicking! KISSAM = Keep It Simple Stupid: Affordable, Maintainable - Visit Early and often - http://open-txu.org |
01-09-2010, 10:05 PM | #8 (permalink) |
Ya I finally sprung for the Phoenix 2.5v . Looking to learn the inverted stuff hopefully with this thing after I get it flying around this week hopefully. I heard on a few threads it was supposed to be pretty good.
So Main, feathering and tail shafts, front gears, blades and boom etc. I appreciate it.. Best regards, Tom
01-11-2010, 10:19 AM | #9 (permalink) |
here's my list of stuff (that you should probably) get:
main shafts*** feathering shafts*** flybars** paddles (they break somewhat easily in crashes with high headspeed)* main bearings** grip bearings (both inners and outers)* main grips* head block* main gears (big drive gear)** Torque tubes (get the ones with two tubes and one boom)** carbon boom (Carbon boom is awesome! Well worth the price IMO)* front torque tube gears (gonna need loads of these)********* tail shafts** tail blades (I recommend K&B's, but stock work great)*** main blades (get the wood blades for learning)*** 12t pinion* Gorilla gear skids (yellow, orange, green....anything but the black ones!)* 410M gears sets (if using Super combo servos)** 520 gear sets (ditto 410M's)* tail grip assy* Spare screws* spare swash-to-head links* That about covers all you are going to need. I marked the more commonly repaired/replaced stuff with ***. Somewhat common gets **, and stuff you want to have just in case, or infrequently repaired but critical to have get a single *.
Tim KBDD TEAM PILOT --Si vis pacem, para bellum-- |
01-11-2010, 12:31 PM | #10 (permalink) |
My advice has nothing to do with specific parts... but if I need a replacement component I *always* buy 2x. I figure if I've broken it once I'm likely to break it again and a second spare means I won't have to wait for UPS before I can fly again after the next crash.
Fly in the street hangar includes: T-Rex 450SEV2, 250SE (MD500), Blade 400, SR & mSR & 120SR & mCPx & mCX & CX2, Walkera 4G6S & SeaCobra Parkzone Sukhoi (& XP), Centurion, Mustang (Micro and BL versions), µBeast, Mosquito
01-11-2010, 01:59 PM | #11 (permalink) |
A lot of it depends on LHS availability. If you have to mail/internet order everything, then you want to have a good stockpile going of specific parts. If you have 3 or 4 shops, then you really don't have to worry as much because you can always just walk in and get it, or they'll have a shipment in soon thereafter.
I try to keep a parts box going according to how often it goes out. Having flown a Trex 450 V1 for nearly 3 years, I had a fair assesment of what to expect in a crash. But when I got to the Pro, the rules got re-written. The Pro easily goes through twice as many parts in a crash, so you have to keep a pretty high stock of everything regardless of LHS support. Seems most of the time I can make it into a shop, they never have everything I need, so it's more of a "get it while the gettin's good!" type of thing. Even though it wreaks havoc on my finances, I can almost never be grounded due to lack of spares. Everyone has to go at their own pace though.
01-14-2010, 12:35 PM | #12 (permalink) |
I've done some shopping for the same thing. I made an excel list with Part #s for easy reference.
450 Pro Parts.xls |
01-15-2010, 03:22 AM | #13 (permalink) |
Is it recommend to have everything Align or Tarot stuff works just as fine. I am guessing for stocking everything align you will need to break bank.
--N |
01-15-2010, 05:31 AM | #14 (permalink) |
Sorry it took so long, The Tarot stuff is just fine, it's what I use.
The Head Block is near as identical to the Align one. http://www.infinity-hobby.com/main/p...oducts_id=4782 The Front Torque Tube gears are theses http://www.infinity-hobby.com/main/p...oducts_id=5036 Torque Tubes http://www.infinity-hobby.com/main/p...oducts_id=4702
01-15-2010, 10:25 AM | #15 (permalink) |
Thanks mate.
D00d 1 r3411y n33d t0 g37 14!d |
01-15-2010, 12:37 PM | #16 (permalink) |
Yeah, Mon_T has the Infinity shopping down to an art. I've never ordered from there, but plan on doing so pretty quick here. Stocking all genuine Align stuff gets really ridiculous on this heli, so you're much better off getting the 'knockoff' stuff (Align actually makes the Tarot so it's virtually identical).
01-15-2010, 09:24 PM | #17 (permalink) |
Long week, hadn't had a chance to get on at all. Hopefully will do the maiden flight Sunday test hover etc. Thx to all the replies so far....
Best regards, Tom
01-17-2010, 12:44 AM | #18 (permalink) |
Well she's almost done, tail to go.... Much thx to Bob for his videos and other helpers on here as well....
Best regards, TomK
01-19-2010, 09:58 AM | #19 (permalink) |
Almost ready for the first power up with weighted skids, finally got the tail done. Figured I'd track and test on the floor as usual. Anybody shop at HeliProz? Looking at the 450 Pro parts it looks like in the pics you get 2 main shafts, 2 feathering shafts etc. for the price. Is this the case?
Best regards, Tom
