Old 09-28-2012, 03:53 PM   #1 (permalink)
Default hard deck install question
the install went fine, but the on set up screen display in only visable for 2 sec and then a blank screen. So wait and it reappers, only for 2 sec then gone again HELP Larry
"You can always tell a pilot,but not much"
Gaui X 5 Phanthom 2
n6nev is offline        Quick reply to this message
Old 09-28-2012, 04:07 PM   #2 (permalink)
That sounds very odd...
You may wish to Email FMA about this,
I haven't had any issues as what your describing
JR9303 / JR9503 / Futaba10CHP
nightflyr is online now        Quick reply to this message
Old 09-28-2012, 04:27 PM   #3 (permalink)
they are closed by now so its monday, rats I can use the irnet hand held device , but I would like to read the info on the screen set up
Gaui X 5 Phanthom 2
Old 09-28-2012, 09:39 PM   #4 (permalink)
Hi:
Sorry for your troubles. We'd like to help you get this sorted out.
1) Have you updated the CPII Computer Module to v2.37 or the latest v2.40? Did you check the update bootstrap check box before you installed the new firmware?
2) What version of Windows are you running?
3) When you say "the screen goes blank" do you mean the text help screen above the menu text and control buttons goes white (no text), or do you mean the whole application shuts down?
4) What happens if you press the ENTER and/or INC/DEC buttons on the CPII Display software. Can you get it to go to other menus. I'm wondering if it's just the welcome screen causing you the problems or all the programming screens?
5) You should install the FUIM3 tester at the following link and make sure the FUIM3 is passing the speed tests.
http://www.revolectrix.com/applicati...ster/setup.exe
When you run this program, you have to apply 4.8v to 6v across the red/blk wires on the JR pigtail, but do not plug this connector into the CPII computer. You can use a 4 cell Ni battery for power if you have one lying around. Pull down and select the COM ports one at a time, then click "Test". The speed test will run at multiple speeds and say PASSED or FAILED. It will only work on one of the COM ports presented, not all of them. Let me know the results of these tests.
6) Do you have a different computer you can use to rule out a USB port problem, or can you try different USB ports on the same computer? Some customers have reported problems with USB 3.0 ports, but not USB 2.0 ports for example.
7) You can also try a different FUIM3 if you have access to one, or you might try a new USB cable between the FUIM3 and the USB port on your PC.
Please email me directly at tim@fmadirect.com. Leave your name and a phone number where you might be reachable. If you can't get it going, we'll see if someone can try to contact you over the weekend.
Tim Marks
President, FMA, Inc.
Revolectrix Partner
Tim Marks is offline        Quick reply to this message
Old 09-29-2012, 08:30 AM   #5 (permalink)
I had the same apparent faulty unit, but it is related to my PC. When I use my almost brand new works laptop I get intermittent behaviour, almost as though my USB lead were faulty. It is just like it is being powered on and off. Jerry suggested that it would be some sort of funky power management issue, preventing the port being kept open. It behaved like this on every USB port of my new Windows 7 PC.
Switching to my older, very reliable, Dell D620, Windows XP laptop, it worked perfectly, straight off the bat, every time. Suggesting that Jerry's assessment of the power manangement issue was probably correct.
My USB ports on my new laptop give me no issues with any other USB devices, but it's not like I have a lot. Usually just a memory stick and an external drive.
I would like to help by messing with my settings, but sadly, since it is my works laptop, I am not to keen on changing bios settings or similar, to see if this will solve it, especially as I already have a working solution with my old laptop anyway.
Cheers
Sutty
Regards, Sutty
sutty is online now        Quick reply to this message
Old 09-29-2012, 10:51 AM   #6 (permalink)
(Yes , the 2.40 installed, and the boot strap is installed)
(Windows 7)
(Just the text screen go blank and then reappears, 20 sec later, only to go away again after 2 sec)
(I can go to the next menu, but its very slow. and only for 2 sec)
(not done yet... no 5 volt available yet)
( I have tried 2 ports and the screen promps COM3 )
( I have a XP stand by unit but no help. the boot strap will not appear on the display and a different USB cable)
but I am able to do the set up with the IRnet controller, I would to see the text screen for more info
( i just did the usb test for com 3 and it passed !
XP boot strap solved , but same problem, 2 sec on then off..............
Gaui X 5 Phanthom 2
Old 09-29-2012, 02:42 PM   #7 (permalink)
After using the IRnet module for the HD set up , the CP2 remains on in all 3 positions.
what I am after is
position 2 HD
position 1 cp2
and the center postion should be off be not so
and the set is a 3 way swithch that works find with just the cp2 alone
Gaui X 5 Phanthom 2
Old 09-29-2012, 03:04 PM   #8 (permalink)
what I am after is
position 2 HD
position 1 cp2
Do you have the HD module installed?
Did you assign flight modes to the switch positions???
Old 09-29-2012, 03:14 PM   #9 (permalink)
yes and yes
off is in the center
up is CP2
down is HD
but alas, the cp2 is always on
just redid bird #2 for non HD and the cp now turn off as it should
bird #1 ??????
Gaui X 5 Phanthom 2
Old 09-29-2012, 03:18 PM   #10 (permalink)
Perhaps having the off position at either the top or bottom switch position will work for you..that is how mine is setup
Old 09-29-2012, 03:20 PM   #11 (permalink)
I tried that also but it did not work
Gaui X 5 Phanthom 2
Old 09-29-2012, 03:32 PM   #12 (permalink)
yes and yes
up is CP2
down is HD
bird #1 ??????
Hi n6nev,
I have used the three position switch just as you describe and it worked OK on my DX8 Tx.
Question, if you have the programer in the preflight mode and move the switch to the center position, does it say off or does it show another flight mode? If it show another flight mode, what flight mode?
If the remote switch is in the up position does it show "Level Flight" mode? And if down does it now show "Level in Hard Deck"?
I am assuming that you have the auto trim changed from 6 to off. If not then CPII still have a little input even when the remote is in the off position. Is that possibly what you are seeing to make you believer CPII is always on or is it the IR Programmer?
Jack Doherty
FMA Beta Tester
CoPilot II HD
PowerLab 8
jdd1 is offline        Quick reply to this message
Old 09-29-2012, 03:42 PM   #13 (permalink)
Originally Posted by jdd1 View Post
Hi n6nev,
it shows off
yes
auto trim is 0
and the CP is always on,
Gaui X 5 Phanthom 2
Old 09-29-2012, 03:47 PM   #14 (permalink)
Just double checked my setup..V 2.40
JR9503
AUX2 3 way switch Position 0 (full up) CPII off
Position 1 (center) LEVEL FLIGHT
Position 2 (full down) LEVEL in Hard Deck
Old 09-29-2012, 03:49 PM   #15 (permalink)
I will give it one more go...............more to follow
Gaui X 5 Phanthom 2
Old 09-29-2012, 03:49 PM   #16 (permalink)
auto trim is 0
If your center switch position shows "OFF" on the hand held programmer why do you say CPII on????
Old 09-29-2012, 03:55 PM   #17 (permalink)
I did it your way and same problem
Gaui X 5 Phanthom 2
Old 09-29-2012, 03:58 PM   #18 (permalink)
because when I am all done and plug in the main sensor the cp is on
Gaui X 5 Phanthom 2
Old 09-29-2012, 04:04 PM   #19 (permalink)
Question...
Why are you disconnecting the main sensor during setup?
Old 09-29-2012, 04:06 PM   #20 (permalink)
I will state my problem, with the main sensor disconneted, I program the center position to off, the up for CP2 and Down for HD. then when I am done, I plug in the main sensor and the CP is always on...........hope this helps
Gaui X 5 Phanthom 2
