Old 03-18-2013, 08:46 AM   #1 (permalink)
Default Kosmik-TelMe?
Any word on availability or anyone try a TelMe telemetry module yet for Kosmik.
Interested in using one this season with Futaba 14SG telemetry.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 03-18-2013, 09:46 AM   #2 (permalink)
+1... I'm very interested to know if mAh used can be implemented with TelMe and the 14SG. If so I will upgrade to the 14SG from my 8FG.
Diabolo…HC3SX…Gmauro HKIII-4530-450…KOSMIK 200…MKS HLB950/HLB980...Rev 14s 4400 60C
Protos 500 Stretched
…HC3SX…Hyperion 3026-880kv…KOBY 90…MKS DS9670A+/DS-760...TP 6s 3300 65C
mCP X bl...Nano QX...Futaba 8FG
NickBee is offline        Reply With Quote Quick reply to this message
Old 03-18-2013, 09:48 AM   #3 (permalink)
Exactly my plan too.
Old 03-18-2013, 11:00 AM   #4 (permalink)
As far as Im aware they are due any time now and I will have one on its way to me to use with the 14SG.
They may be available before I get mine as Im waiting on some other bits and bobs too but they wont be long
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 03-18-2013, 11:02 AM   #5 (permalink)
Good to hear Jamin!
Has there been any confirmation that we'll be able to see mAh used on the 14SG from this unit? Or is it one of those things that you'll have to wait and see?
Old 03-18-2013, 12:39 PM   #6 (permalink)
Definitely interested to hear your results.
Now just need Futaba/Skookum to get things sorted and I will have one tech'd out machine.
Old 03-18-2013, 03:07 PM   #7 (permalink)
If you go in to the Progdisc now, not 100% sure what setting it is in but I have been told you can set the kosmik to 4ah for example and it will give a rise in RPM to alert you when have used 4000mah
Try it
Then when used with the TelMe and the Bluetooth module I believe it will then be able to give you an alarm on the tx.
But the TelMe will transmit the following*
Temperature
Current
Voltage
BEC voltage
Current
PWM
2 pole rpm (MAY also be able to adjust this with the Bluetooth module to give HS)
*info will be confirmed soon
Old 03-18-2013, 03:45 PM   #8 (permalink)
Try it
If someone can confirm this then I don't even need telemetry, only want it for mAh consumed.
Would be awesome if it's built in, no mention in manual.
Old 03-18-2013, 03:48 PM   #9 (permalink)
My Progdisc is in the office
Old 03-18-2013, 04:41 PM   #10 (permalink)
Mine is in a store somewhere waiting to be purchased.
You'll have yours first. Please let us know.
Old 03-18-2013, 05:25 PM   #11 (permalink)
Will do, I'll be in the office in about 9hrs from now I guess.
I got a sneaky feeling it works lol as the info came to me from Daniel. Just I never tried it myself
Coupled with the BT module and the TelMe if this does send this info to the tx will be friggin awesome!!!
It does give you ah used on the log so it should work no problem
Old 03-18-2013, 07:28 PM   #12 (permalink)
I located it in expert parameters select RPM control then scroll to capacity limit and enter your info. Thanks Jamin
Magneto is offline        Reply With Quote Quick reply to this message
Old 03-18-2013, 07:47 PM   #13 (permalink)
Awesome guy's, ordering ProgDisk now.
Does this have to be most up to date FW for both units?
Old 03-18-2013, 07:56 PM   #14 (permalink)
Good question my Progdisc and Kosmik have the latest FW. BTW the scale is AH so divide by a 1000 I have 4400 packs and I want to be alerted when 3000 mah is discharged so it is set at 3.0 AH.
Old 03-18-2013, 08:09 PM   #15 (permalink)
4Ah for my 5K packs.
So head speed will increase at this threshold, seems backwards?
Either way works for me, very excited to get some air under this Kosmik.
Old 03-18-2013, 08:18 PM   #16 (permalink)
If it decreased some may mistake it for a soft cutoff I would think,Im excited also the kosmik just keeps on getting better and better and a MAH sensor was my most wanted option ,I just recently sold my 8FG and picked up a 14SG and will get a Telme when they come out.
Old 03-18-2013, 08:22 PM   #17 (permalink)
Originally Posted by Magneto View Post
If it decreased some may mistake it for a soft cutoff I would think,Im excited also the kosmik just keeps on getting better and better and a MAH sensor was my most wanted option.
This feature sounds great. So say I am cruising with a 1800 HS, how will this thing increase to tell me I hit my programmed limit?
Looking forward to hearing the results of this!!!
Old 03-18-2013, 10:04 PM   #18 (permalink)
wow, didnt know about this cool feature, will give it a go!
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 03-18-2013, 10:36 PM   #19 (permalink)
Sweet, I will try this tomorrow.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 03-19-2013, 11:56 AM   #20 (permalink)
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
