Like Tree2Likes
Old 09-08-2011, 10:56 PM   #561 (permalink)
Thanks Bob, I watched all of them, more than once, must of missed that somehow.
Anyway, as luck would have it... I had cyclics up first
Thanks again
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 11:04 PM   #562 (permalink)
Team Taco VP
I think.... as I recall... it was explained on the channel assignment screen area.
Don't ask me to remember my vids from a year ago
I sometimes have to watch my own vids if I have not done something in a long time. Seriously.... My own vids help me sometimes answer a question when I need to and don't remember 100%....
I am getting older and cannot remember everything like I use to
Bob
Old 09-09-2011, 07:09 AM   #563 (permalink)
Originally Posted by Finless View Post
OK sounds good and your putting the channels in the radio in the right priority for less latency. So whats the question?
Realize all radios at end point or travel adjust at 100 is 100. Or darn close to it. The A9 is no different. If the FBL unit tells you to set the travel adjust or end points to something, you should do it just like JR or Futaba.
Make sense?
Bob
Yes, exactly why I set the channels like that. I did it on my 450 and it worked out great.
No question, just wanted to be specific to make sure my settings were okay.
Makes perfect sense.
Thanks Bob
Fierce is offline        Reply With Quote Quick reply to this message
Old 10-05-2011, 05:15 AM   #564 (permalink)
Thumbs up Great Job
Cheers Bob
I am a newbies to RC Heli and i found you Aurora 9 Vids Extremely helpful as i had just purchased one and set it up on my mini titan without a hicup.
Cheers
Adam
spotswoodfitness is offline        Reply With Quote Quick reply to this message
Old 10-05-2011, 12:45 PM   #565 (permalink)
Team Taco VP
Glad I could help.
Happy flying,
Bob
Old 10-18-2011, 12:14 PM   #566 (permalink)
Hi, I have a problem with the telemetry of my Aurora.
I connected my optima 9 via channel 3 to my esc, which has got an internal ubec. The esc is powered with my 3s lipo.
My Aurora now shows the voltage of my ubec, which is 5,2 v. But im more interested in the voltage of my lipo.
Is there a work around?
Thx
Gerbaum is offline        Reply With Quote Quick reply to this message
Old 10-18-2011, 12:18 PM   #567 (permalink)
If you want the voltage of your 3S Lipo to be displayed on the A9, you need to connect the 3S lipo directly to the SPC port on the optima 9 instead of the jumper.
Now you will get the telemetry of the Lipos voltage not the BEC.
ESC remains connected the way you have it to power the servos.
But the receiver part of the Optima 9 is now powered directly by the Lipo
You should of received with the Optima 9 a wire with only red and black wires and a servo connection on one end. That wire is supplied to power the SPC port directly from your Lipo... Note the SPC port can handle up to 35 volts.
BUT ONLY the SPC port can handle up to 35 volts, so make sure you plug high voltages to the SPC port only.
Old 10-18-2011, 12:33 PM   #568 (permalink)
Great, thats it!
Thx.
Old 10-19-2011, 10:24 AM   #569 (permalink)
Over the past 2 weeks, I've been downloading and reviewing all Finless Bob videos on the Aurora 9. There is an amazing wealth of information in the videos. I had no idea the A-9 was this capable and I've had it for almost 18 months! I'm sure Hitec has sold a ton of A-9's just based on this thread! Thanks Finless!
falcon7a is offline        Reply With Quote Quick reply to this message
Old 12-05-2011, 06:33 PM   #570 (permalink)
Thanks Bob for this great video for A9. it really made my heli setup easier as a newbie in this rc category.
+100 to you sir......
Epal is offline        Reply With Quote Quick reply to this message
Old 12-31-2011, 03:27 PM   #571 (permalink)
First off a massive thank you for the setup vids for the A9 they are great.
My question, I'm flying T-Rex 550 on 3G with the stock GP780. I'm getting tail wag when pushing into idle up (80% throttle and above) I've tried adjusting gain via the radio from 51% all the way up to 80% in 5% increments but nothing changes, do I need to adjust the gyro end points on the travel adjust, or is there something else I'm missing?
Cheers.
simon737 is offline        Reply With Quote Quick reply to this message
Old 12-31-2011, 03:44 PM   #572 (permalink)
Hey all i was just wondering if anyone could help me out i just got an aurora 9 and i am having some issues getting my gyro to work
i have the gyros single wire rudder ch5 j4
i have the gyros three wires gyro ch 4 null
the gyro turns on but i have no function if i make both channels say j4 i get function with the sticks but do not get a reactive movment when i move the tail ? I have been watching these videos and yet i still just dont see whats wrong
piranhafreak is offline        Reply With Quote Quick reply to this message
Old 12-31-2011, 09:50 PM   #573 (permalink)
Cheers.
Disconnect the link off the tail servo and see how much effort is require to change the tail pitch slider from one end to the other. There should be very little effort required. My tail pushrod guides were causing binding, so I replaced it with the V2 carbon pushrod.
http://www.readyheli.com/H55036-Alig...y_p_37856.html
Also the blade links to the pitch slider were binding, and I read about problems with the pitch slider bush, so I replaced the pitch slider and control arm with the CNC Helicopter 500/600 parts.
http://www.cnchelicopter.com/servlet...600-CNC/Detail
http://www.cnchelicopter.com/servlet...500-CNC/Detail
I hope this helps.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 01-01-2012, 01:04 AM   #574 (permalink)
Old 01-01-2012, 03:25 AM   #575 (permalink)
Thanks, I already have the carbon pushrod as the first metal pushrod just seemed to bend and not be very efficient, I've just stripped the tail links and you were right, I have lock tite in the bushings, so they've been replaced and I'm off out for a test flight, will report back.
Old 01-01-2012, 09:59 AM   #576 (permalink)
Hi
Well ,............... I have accomplished a goal .
Here was the plan .
I modified and assembled a TopFlite Giant P-51. RTF , except for the radio programing . For my servises , I accepted an Align 450 SE , Heli . I purchaced , second hand radio for the heli . The customer had the radio programed to the heli , for a first time flyer . That was it , I was hooked . I enjoyed going out to the back yard and fly , I didn,t have to pack everything up , and go to the field ( which , sometimes was a pain ) . It,s a plug and go fly situation , I loved it . I bought an Align 450 Sport Combo , last January . ( It,s still in it,s original box ) To-gether with an AirWolf ( Bell 222 ) fusaloge . I also bought a Hobby King 450 heli , that I didn,t pay very much for . The reason for the Hobby King heli , was to set it up , to my Aurora 9 . This was to learn the programming and to acustom myself with heli programming . After much reading and understanding of the mechanics of a heli , I have succesfully programed my Aurora 9 to the Hobby King heli . AND IT HOVERED FOR THE FIRST TIME, ON THE FIRST TRY [][][][][][] I also did some scale curcuits . I still have some vibrations to remove , but I,m over the hill . Fine tunning is all thats left
This is a testement to how easy the radio was to program . One of the , " MAIN " reasons why I bought it . Hitec took the pain out of programming . I could have , " NEVER " done this with the other makes , forget it .
I feel better now [][]
BTW ,..... a lot of this success go.s to Finless Bob ( Bob White ) of Heli freaks
Happy New Year
Michel
michel gravelle is offline        Reply With Quote Quick reply to this message
Old 01-02-2012, 09:10 AM   #577 (permalink)
Is it possible to use cross trims on Aurora 9 ?
gelatmi1 is offline        Reply With Quote Quick reply to this message
Old 01-02-2012, 09:28 AM   #578 (permalink)
Reporting back. All is good, tail wag is gone in idle up, amazing that such a small amount of locktite can cause such a big wobble!
Thanks for your help!
Old 01-02-2012, 05:03 PM   #579 (permalink)
Glad to hear it's sorted. Have fun!
Old 01-05-2012, 01:41 PM   #580 (permalink)
Aurora 9 - Cross Trims or Re-Assign Thr<>Elev Trims, Throttle Stick Rev,Sub Trims & Trim C & S problems.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers & Telemetry - FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline        Reply With Quote Quick reply to this message
