Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 01-19-2008, 02:14 PM   #1 (permalink)
Default First Flying, 30 sec, Front main gear fused, OMG?!
Hi all,
I just broke the first main gear in 30 sec of hovering flying!!!
Can anyone tell me how do to set up the motor mount ?? how much is the distance?
on the manual i can see nothing about that.
I have CF PRO version with 1100kv motor and 14T right now. please help me!
aro75 is offline        Reply With Quote Quick reply to this message
Old 01-19-2008, 02:18 PM   #2 (permalink)
Adjust the motor so that you have a little bit of play. Then rotate the motor, while checking the play. You will find that the gear is not perfectly round, and that one spot will have less play than the rest of the gear. This is the point that you want to adjust the lash. I adjust it so that it when I hold the motor, and try to rotate the gear, it barely clicks back and forth. After tightening the motor down, check it again! Many times tightening the motor down will cause the lash to move on you. Also, have the motor plate bolted in place when you do it. It't a lot of trial and error, and a pain in the but, but getting the lash correct is important.
Eric
GAUI500, V30, Full Metal,9254/401+T600Tail, 500mmCarbons
TRex 450SEV2:HS65MG,3400G+DS760, Neu1107/1.5+11T, JAZZ40
Blade CP, ,RotoFly FP, Blade CX,
Other Blingers:
Deering Golden Era Banjo
LG100ZM competition air rifle w/20-50x60 scope (http://www.compufoil.com/images/eric_on_the_range.jpg)
Mathews SwitchbackXT Bow
CompuFoil is offline        Reply With Quote Quick reply to this message
Old 01-19-2008, 02:28 PM   #3 (permalink)
Also if you are using the Gaui BL motor spin the head and there should not be any type of binding. When I do mine it spins freely and it is smooth. It almost feels like I forgot to put the pinion on because it so smooth. This is how I have mine setup. On the motor mount I have about 1 MM gap from the bolt to the end of the motor mount the end facing the tail. This has been the best setup for me so far and haven't strip or had any issues. I hope this will help you.
xfaega is offline        Reply With Quote Quick reply to this message
Old 01-19-2008, 02:32 PM   #4 (permalink)
Ok thanks for support. Hope i will do the best next time
how did you fix the motor mount??? its so difficult to fix the hex screw! no space to work.
Old 01-19-2008, 02:47 PM   #5 (permalink)
You have to take out the whole motor mount to do it.
Old 01-19-2008, 02:52 PM   #6 (permalink)
Here are Bob's excellent build videos:
https://www.helifreak.com/showthread.php?t=31211
I think he explain it 100 % better than I can write it in English :-/
Here are a direct link to the motor-mount video :
http://video.helifreak.com/?subpath=...name=motor.wmv
/Bjørn
Moving air in severals ways in Denmark :glasses2:
bjosko is offline        Reply With Quote Quick reply to this message
Old 01-19-2008, 04:32 PM   #7 (permalink)
thanks a lot. i will do it.:wink:
Old 01-19-2008, 08:20 PM   #8 (permalink)
I see around this upgrade : CNC Delrin Front Gear 42T
Is this a good choice for prevent stripping? thank for answers.
Old 01-22-2008, 02:36 AM   #9 (permalink)
Get the Gaui "OK" gears, they are both round and will last for ever. We are running Z30´s on these gears without any issues. They are cheap as well.
Put a piece of paper between the pinion and first 42T gear to get the right clearance.
Adjusting the motor is a pain, but there is a simple way to do it.
Tighten the motor screws up just enough so you still can move the motor.
Put the motormount back in the chassie.
Tap on the motor screws untill you get the right play (using the paper between the gears).
Remove the motormount and tighten the motor screws up.
Done...
Tom Viper is offline        Reply With Quote Quick reply to this message
Old 01-24-2008, 03:27 PM   #10 (permalink)
Thanks to all for answers
Now, Which is the best way to change the first main gear in CF frame???
open all the CF frame or huh?! cant see anything different....
