Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 800 Xxtreme
Mikado Logo 800 Xxtreme Mikado Logo 800 Xxtreme Helicopters Discussion
Old 02-21-2012, 08:27 AM   #21 (permalink)
Originally Posted by heliguyG6 View Post
so by your piture this will charge 2x7s packs made up from a 4s and 3s packs?
i have a hyperion charger so would be interested in this setup
No....with this setup you can balance two 7s TP packs. It's a 2 x 7s into 1 adapter.
http://www.progressiverc.com/paralle...e-adapter.html
whytlotus is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 08:32 AM   #22 (permalink)
arent the 7s packs made up from a 4s and 3s (lipos) balance connectors though?
heliguyG6 is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 08:42 AM   #23 (permalink)
They might be configured that way... I really don't know. Like their 6 cell packs, they have 2 balance leads per pack.
Old 02-21-2012, 09:17 AM   #24 (permalink)
Has anyone found any solutions for going the other way around? In my case I have two TP 1010/210 chargers that I can pull out of retirement for charging 7S packs but need to find a tap to convert from JST on the battery to TP taps to go into the 210 balancer,
Not opposed to building my own tap either but still need to locate the 7s connectors. If someone offers a pre-made one that's even better.
Hey Gerry, I know an easy solution. Send me your PL8, i'll send you my 1010s then we won't need to mess with adapters.
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 10:45 AM   #25 (permalink)
Hey Fil,
When we got our first XXtremes and got committed to 7S packs, we had the same dilemma... a bunch of 1010 chargers, and balance plugs on the batteries that wouldn't work with TP stuff. Hate to say it, but we never found a commercially available adapter that went from the JST commonly used on many batteries these days, into the 210 balancer.
)-: Dave
dahld is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 10:56 AM   #26 (permalink)
6 x Optipowers here.
Also a friend brought these http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html but cant balance charge them, anyone know of an adapter that will plug into the PL8?
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 10:57 AM   #27 (permalink)
I sold my 3010 and 208 ichargers and got two 1420 Hyperions. I'd originally bought the ichargers to use with my Xxtreme but was convinced that it is better to charge and balance the whole pack as one. Since these chargers can now be had for as little as US$130 each it was a no brainer compared to $500-600 flight packs. The benefit is you can charge AND balance the whole 14 cells on the one machine and you can get the TP balance adapter that fits the TP 7S split pack.
TP recommend 1C charging so, by my calculations, I can charge two flight packs, on two seperate chargers, both plugged into my Meanwell 600W 24V power supply running off my tiny Kipor IG770 inverter four stroke generator. I got the generator for AU$399, new. I have updated the firmware in the 1420s as there was a smoothing of the cycling of the charging ramp rate to allow the modern inverter generator eco throttles time to catch up.
Regards, Jayson
Logo 800Xx Silverline, Pyro 850-40L, Kosmik 200, 14S, 157 & 256 @ 8v
Logo 400SE Silverline, Pyro 600-09, Jive 80+HV, 8S, 9660A+ 8900G @ 6v
Jays200 is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 11:01 AM   #28 (permalink)
How many of you guys are buying a generator?
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 11:09 AM   #29 (permalink)
Already got one!
All this time spent moving from gas to electric and I still end up with a gasser.
flymustangs is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 11:12 AM   #30 (permalink)
I only bought mine because we have so many 12S helis and large battery planes at our club that our 12v power rail for chargers keeps tripping out. This way I can run my chargers at their maximum output because of my 24V power supply and I don't have to worry about checking my chargers all the time to see if they've tripped off.
I did look at the Hondas and Yamahas but the Kipor is a clone with a reasonable reputation and for the price (770W was $399 and the 1000W $799) I thought I'd give it the benefit of the doubt.
Regards, Jayson
Old 02-23-2012, 10:49 AM   #31 (permalink)
What's the minimum C rating we should consider? I'm looking at combining some Gens Ace 4S and 3S batteries, but it looks like the highest ones suitable are 30C.
Old 02-23-2012, 10:57 AM   #32 (permalink)
Gens Ace 30c are suppose to be underrated. More like a good 45c.
I got sucked in by their 14% off sale over Single Awareness Day.
Washed up has been who should keep his trap shut
BrainDrain_dx is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 11:25 AM   #33 (permalink)
+1.
7s 5800mAh 40c(ish or more) is coming!
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, Gryphon Rotorblades, RCbearings.co.uk,
Nko15 is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 11:31 AM   #34 (permalink)
Originally Posted by Nko15 View Post
+1.
When?
"Coming soon" doesn't really mean a whole lot.
Old 02-23-2012, 12:58 PM   #35 (permalink)
Originally Posted by flymustangs View Post
When?
I should have some prototype packs by the end of march/begin april.
Old 02-23-2012, 01:27 PM   #36 (permalink)
When?
Good things come to those who wait (IOW, those who have the patience!)...
ElectricSheep is offline        Reply With Quote Quick reply to this message
