Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Velocity 50 Nitro
Outrage Velocity 50 Nitro Outrage Velocity 50 Nitro Helicopter Factory Support Forum
Old 08-10-2013, 04:49 AM   #1 (permalink)
Default OS 55hz Moter temps
I am wandering what temps I should be running on my OS 55 right now when I put it back on the ground it is about 116 to 120 degrees what is a good tep to run the Moter
Rotary wing team pilot, halo team pilot.
Thrumpness is offline        Reply With Quote Quick reply to this message
Old 08-10-2013, 08:32 AM   #2 (permalink)
Depends on where you pull the temp.
I temp mine at the head on the bottom. I look for 210F, approximately.
If you are temping the back plate, it's more like in the 100's plus. But I haven't pulled a temp from there for so long. I can't really say..
But, the engine, fuel type, percent nitro, fan efficiency, and fuel brand make a difference when it comes to temp. And don't forget about the glow plug.
Old Guys Rule
Zaneman007 is offline        Reply With Quote Quick reply to this message
Old 08-10-2013, 08:06 PM   #3 (permalink)
I fly mine really hard and I am shooting for around 240. I took it easy today and maxed out at 222 F with an average of around 210 F. Its a good mixture and I am actually running a little richer than other guys at the field to keep my temps in check when I start hammering on it.
Spartan Vortex, Scorpion Motors, ExperienceRC Batteries, OMG Servos
FrSky Taranis
DaveHolland is offline        Reply With Quote Quick reply to this message
Old 08-11-2013, 04:22 AM   #4 (permalink)
Cool I need to start taking my temp from my head and not my backplate
Old 08-12-2013, 03:09 PM   #5 (permalink)
I was just pulling 222 F max this last weekend. It was high humidity and it felt a little too rich. My backplate is always warm to the touch, but then again, ambient temps are usually around 100 F.
FrSky Taranis
Old 08-12-2013, 06:38 PM   #6 (permalink)
Just switched to a dubros line and it was a little smaller in diameter. Had great power and max temp touched 240 F, it had nice power for tic tocs and wasnt soggy like yesterday. After warming it up I was around 190-200 F in a hover @ 2100 head speed. The smaller line I am not sure if it was the smaller line or the air quality today, it was hotter today but less humid. If the line helped lean it out then I suspect that will be a problem on a cooler day where I need more fuel...
FrSky Taranis
Old 08-19-2013, 09:18 AM   #7 (permalink)
I had the engine way to lean. I was running it and topping around 220-240. Well yesterday I decided I was not getting enough power and had to do something about the tune. I richened up the mixture about 12-14 clicks on the high needle and 10 clicks on the mid....and a big wow. Now it will hold the power instead of instantly dying off when the pitch gets added. Kicker is I am still pulling around 220 F. Dont know what the internals are looking like after running it that lean, but I am sure they arent good. I didnt blow the piston but I am thinking of replacing the piston, ring and sleeve this winter after running it that lean.
FrSky Taranis
Old 02-04-2014, 07:57 PM   #8 (permalink)
I pull temp with a telemetry unit, off the 2nd fin clocked 90 to the exhaust port. I run my motor around 220f.
XL Power 700v2 Nitro NME - OS 105HZR - Power Tune - Rail 716/106 - Brain2 HD
Sowa is offline        Reply With Quote Quick reply to this message
Old 02-05-2014, 04:39 PM   #9 (permalink)
I'm getting about 210 to 220 when I land about 240 to 250 in the air
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 02-16-2014, 08:34 PM   #10 (permalink)
Around 210 measured by telemetry. Sensor is located between closest two fins to the head.
700 size scale Bell Jet Ranger 206BIII, 450 size scale UH-1N, 180 size fpv race/freestyle quad w/Fatshark Dominator V3 goggles, mCPX BL, some edf jets and a plank or two, DX8, AMA# 923167, Clubs: Silver Hills RC, Coeur D Alene Modelers Association
JasonJ is offline        Reply With Quote Quick reply to this message
