Old 12-28-2012, 03:59 PM   #41 (permalink)
Originally Posted by 3dplank View Post
It don't matter how there plugged in. If the motor runs backwards just switch two wires till it spins the right way:
Sent from my DROIDX using Tapatalk 2
wait, so it makes no difference how the wires from the motor are connected to the esc?
rpayer is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 04:10 PM   #42 (permalink)
The point 3d is trying to make is, the motor will run if the 3 esc wires are each connected to one of the 3 motor wires. If the motor runs backward, just switch any two wires and it will reverse the rotation of the motor.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- 300X - 130X X3- mCPX brushless X3-Nano cPX X 2- Nano QX
65L88 is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 05:24 PM   #43 (permalink)
so it's a safe assumption to say that i can connect red/red, black/black, and blue/yellow without messing anything up and if it spins the wrong way just swap the red and black?
Old 12-28-2012, 05:35 PM   #44 (permalink)
Yep
3dplank is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 06:17 PM   #45 (permalink)
Yep
awesome! thx!
Old 12-28-2012, 07:37 PM   #46 (permalink)
Hi Y'all,
So I did the "mod" with the Wicked 4800 and 9 tooth pinion last night. Went out to the field today and had a blast. Didn't change any settings at all from the stock setup. Just wish I had more than four batteries ( 1- stock, 3 - Nanotech 1300 45+C). I did have a little issue with the third flight though. Everything was fine until I switched into IU and the heli wanted to bank to the right. It was controllable, but bad enough that after a few tries I decided to just fly the battery out in normal mode which was plenty fun anyway. The 4th battery was fine and I was able to go into IU and do some inverted, a few rolls, and some other odd and unrefined stuff without problems. I called HH and waited forever to talk to a tech about the banking to the right issue, then gave up and called my LHS. He said that the 100, 70, 60, 70 100 throttle curve I was using in IU was likely causing the problem and to just go for a flat 70 throttle. I'll try that tomorrow... He also said to ditch the wood blades and go carbon fiber and then I can set up my TC to 100% and forget about it. Still wonder about how the stock ESC would hold up to that.
OBwan is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 08:19 PM   #47 (permalink)
I agree. I have found that when using a non-governed esc many fbl systems do not like v-curves on idleup and in these cases flatline idleup throttle curves worked best.
Might also be a good idea to check your mainblade balance and maybe tighen up your main blade grips a little bit so the blades are not too loosey-goosey. Firm, so when you hold them hoiz they do not flop down. Too loose and you can get lead/lagging which can effect your fbl system.
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 08:43 PM   #48 (permalink)
I honestly didn't see any V curves for throttle that deep in IU at all in the instructions for the 300X nor in my notes that I've been taking for setting it up for flight. If you are using wood blades, it would send the heli into a tail wag and heavy vibrations when you changed pitch to the extremes which would cause it to possibly tip depending on how you were working the heli and how well the main blades would be balanced.
OXY Heli and Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 08:45 PM   #49 (permalink)
So use a flat 100 curve in IU with stock esc and CF main blades?
/#Team BK Servos//#Team Pulse/#Team AMain Hobbies// /Team Canomod//
Greg Jackson 2017 Team USA F3N https://www.youtube.com/channel/UCci..._R4nja0RYeXykg
GJacksonF3N is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 08:48 PM   #50 (permalink)
Yes.
Old 12-28-2012, 08:56 PM   #51 (permalink)
So can you not run 100% on wood blades?
victorb17 is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 08:57 PM   #52 (permalink)
I'd suggest you get some CF blades quick smart, the woodies don't like where you are going. Even with the stock motor, Blade say keep woodies max TC setting to 75% I think Dylan suggests a governed ESC for the 10 tooth, but 9 tooth with stock ESC is okay. Worth noting if you're going fly in idle up.
Blade mSR, mSRX, 120SR, SR, mCPX (2), 130X, 300X, 450X, NANO CP X & mQX. Witespy HT-FPV Naza Quad DJI Naza F450 Quad
swash@ is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 09:16 PM   #53 (permalink)
You can but it won't be pretty.
Old 12-28-2012, 09:41 PM   #54 (permalink)
There's a warning in the 300X manual iirc.
s
Old 12-28-2012, 09:52 PM   #55 (permalink)
I flew my 300x with woodies at 100% for awhile...but could only do so when the heli was perfectly dialed in (not so often)
FYI - if you are going to get CF blades, many here would agree with me that the Gaui, Edge, SAB blades are much better than the Blade Cf's (especially for about the same price)
mixfisto is offline        Reply With Quote Quick reply to this message
Old 12-29-2012, 08:05 AM   #56 (permalink)
GSPI, that's the curve suggested for IU -1 in the 300x addendum included with the heli. They go on to suggest a flat 75% for IU-2 ... so they agree with you in addition to the V curve (covering all the bases?). The same page says no higher than 75% with the wood blades, and recommends CF blades to go any higher.
Old 12-29-2012, 08:11 AM   #57 (permalink)
OBwan, I'm going to go look in the manual addendum again it just seems strange to me. I can see boosting the throttle curve some at the extreme pitches but not that much with wood blades.
Old 12-29-2012, 11:14 AM   #58 (permalink)
Ok, I might embarrass myself a little... Why are wood blades so bad? I have only had the mcpx with plastic blades so I have no experience other wise. I can assume that cf would be lighter and stronger. Is the worry that the wood blades are going to tear apart?
Old 12-29-2012, 12:19 PM   #59 (permalink)
Nice new motor, and the one extra reason I need to replace my stock ESC which otherwise has a question mark hanging over it since a transient power loss in flight. Just happened once, but a good way to fly helis crash free is to fly only equipment you know is not faulty. Right now I hope my stock ESC is not faulty. Not good enough.
So yeah, I'm in the queue outside of Dylan's shop for this one.
syzygyQ is offline        Reply With Quote Quick reply to this message
Old 12-29-2012, 02:26 PM   #60 (permalink)
Got the new motor installed...barely. Nice of Blade to practically cement the motor mount screws into the stock motor.
lil windy down here today so I was really only able to spin 'er up and hover a little. much smoother and more quite.
