Old 10-15-2010, 11:58 PM   #81 (permalink)
I have Trex 500 ESP and have a 3G in route with the 2.1 update, should I do this mod before install? Are you guys not happy at all with the performance out of the box? Also just wondering if this Goop or what ever silicone products your putting on the main circuit board will lead to a thermal issue not being able to dissipate heat leading to a possible failure. I really just want a plug and play system but reading through all these threads it sounds like that's not gonna happen. Here's what I gathered so far, tell me if I'm missing something.
-Goop the board linking all three sensors to eliminate vibration to the sensor.
-Use Spartan thick pad then metal plate then thin pad and attach sensor.
-Seal the back of the pins on the white connectors so they don't back out.
-2 bearings in the torque tube to eliminate vibration there
-Add a power bus so power for all the servos is not run solely through the the Aileron power wire.
I think that's it. Jees, that's allot of sh*t Let me know please.
Goblin Kraken 580- KST servos, HW 120A, XNova, Microbeast +
T-Rex 450 Pro- DFC head, AR7200BX, Radix blades
SPEKTRUM DX8
05RAVEN is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 12:56 AM   #82 (permalink)
Just did the mod to my 500 ESP ...
Note of interest: On my 3G sensor purchased a month ago it already had the socket pins epoxied.
Trex 500 ESP 3G - DS510M - Jive 80+HV - BLS251 - I2 + KDE + Edge
Trex 250 - GY520 - s9257 - ds410M - Medusa 5V/2A BEC - Scorpion 3900/15T
4G6 - HP08s - XP-07A MIA 4#3B - HP06s - XP-07A
Ntrospect is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 01:39 AM   #83 (permalink)
Originally Posted by jondabear View Post
Speaking about tapes and such....Im about to REMOVE the plate and go with just a single piece of 4010 w no strap. Ill report back later.
After the mod, the stock tape might also work, can you also test it with the stock tape?
|Michalis|
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 10-16-2010, 02:12 AM   #84 (permalink)
Did you remove those two tabs on the upper casing before assembling or you assembled before the silicone set and let those two tabs go into the silicone ??
mmarian is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 02:14 AM   #85 (permalink)
Better with them gone maybe?
---- JR Vibe SGE12 Hiroki Ito Scorpion Tribunus 200A 4525 Ultimate Spirit FBL—-Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL --- RJX Vector 700 Pyro750-56 Comp Kosmik 200 ——
malc1 is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 02:14 AM   #86 (permalink)
The question was to Ntrospect..
Old 10-16-2010, 03:15 AM   #87 (permalink)
Yes I removed them, I used a very sharp woodcarving chisel & cut them off flush to the case...
Old 10-16-2010, 11:27 AM   #88 (permalink)
about to change tape to single 4010 and remove strap. ill test with old settings then change to stock settings w more swash return. peace!
jondabear is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 11:45 AM   #89 (permalink)
4010 is a WINNER!......Heli just got quicker and quicker. NO NEED for tape and plate combo anymore.....thank GOD!
Felt REALLY locked in and un boggable!
NO STRAP either.
Im gna change settings back to stock and see what happens. Ill post another vid. (better one w a cameraman) after im done testing.PEACE!
Old 10-16-2010, 12:13 PM   #90 (permalink)
Nice!
Representing: Team A Main , Mikado V-Team, Team Xpert, Team Synergy, Team KDE, Team Cool Power, Team Hatori, Team Protek, Eco Power Lipos, TruGlow,
XFC 2006/7/8/11
Leon Luke is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 12:47 PM   #91 (permalink)
Great! I was wondering if you need the strap or not. Man I can't wait to try my 700 out tomorrow!
mdntrex700 is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 01:28 PM   #92 (permalink)
dpa
Default made the mod
this morning, more to report later this evening.
Seems like the problem that's been identified here is that the two vertically mounted sensors are acting like "tuning forks" as previously described. Some parts of the total sensor are moving independently of the others, due to vibrations.
The mod addresses this by gluing all three sensors together, makeing it a better single unit. Whatever vibrations exists are felt by all three sensors -- nobody is moving differently than the whole, which is what the software assumes.
So it's not so much the vibrations being transmitted from the case to the sensors, which seems like it will happen in any case through the mounting screws. That's a problem for mounting tape and maybe plates to address. The solution here seems to be that it's making a solid block out of the sensors so they all move exactly together.
That being said, the right things to do might be just to stuff the case full of silicon and make ithe whole thing a potted module, like one of the previous posts. That's not what I did, mine looks like some of the pictures here. Off to fly.
dpa
Oh yeah, stock Trex 700e, Castle HV 85, (gov 2050 rpm) 12S 5000mAh, also 3300mAh, 3G FBL blades.
dpa is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 02:33 PM   #93 (permalink)
Im flying the LUKE settings now. I like the way it feels a bit more than mine soo im gna keep it that way untill I fly enough to suit it to my style.
Old 10-16-2010, 02:35 PM   #94 (permalink)
That's what I'm thinking also. Might help if it weighs a bit more too, harder to vibrate.
I used some epoxy and filled up my case (enough so it doesnt overflow or ooze out the connector side), put the circuits back in, then put some epoxy on the main board and screwed the base on. It is unitized now
I'm at work so I cant validate the adjustments I made today in windy conditions...but flying my T250 in the windless garage here, I was able to turn up the Lock Gain past where it would get nervous before, it's really locked now . I had nervousness related to headspeed issues also before...not now. Seems like a good mod to me so far.
SidewaysLS4 is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 02:55 PM   #95 (permalink)
Default gamechanger
For those of you that are going to make the glue ooze out of the unit, you can put some tape over the top of the white plug recpticle covering the holes where the glue squeezes out. If you use thin scotch tape you can just leave it there, if you use a stronger tape, you can still pull the tape out after it is all assembed and the glue has dried. This way, the pins stay clean.
XFC 2006/7/8/11
Old 10-16-2010, 03:42 PM   #96 (permalink)
Leon, are any other Team Align pilots using this mod?
helical is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 04:13 PM   #97 (permalink)
WOW this looks like a must do. I have 3 of them to do!
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 04:56 PM   #98 (permalink)
Now you tell me! I was wondering why the cable wouldnt go back in
Old 10-16-2010, 04:57 PM   #99 (permalink)
Heh, 2 more to go for me. 1 I know is in a horrible vibe heli...just the extra weight of the glue I'm sure will help a ton.
Old 10-16-2010, 05:55 PM   #100 (permalink)
Going to go out & test my modded unit shortly, I also ended up putting silicone on the base of the rudder sensor as well. Up until now I've been having issues with vibration induced tail drifting & battling with decent gain settings without the usual tail wag rearing it's head...can't wait to try it out
